From Mike > that list is perhaps derived from a registry list ,
HKEY_CLASSES_ROOT\TypeLib
OK, Let's take a look….
There is a bit of an awkward thing with sub Folders with different numbers on. Here is the first few
https://i.postimg.cc/k4Jm9RQ6/Type-L...-0-Library.jpg
Probably those numbers are in the range 1.0 to 6.0 or there abouts. Never mind, I am sure my high levels of VBA skillture will get me over that little hurdle ….. here we go then …. Hold ya butts ….
[EDIT This coding is a pile or Wank ,
( You may want to revisit your code, as it seems to be dropping some names. )
, hopefully these pages will do better
https://www.excelfox.com/forum/showt...registry/page2
https://www.excelfox.com/forum/showt...ngs-GmbH/page3
EDIT This coding is a pile or Wank ,Code:Public Sub ListQuid() ' https://eileenslounge.com/viewtopic.php?p=326180#p326180 ' https://powershell.one/wmi/root/cimv2/stdregprov-EnumKey ' https://www.vbforums.com/showthread.php?552899-Getting-all-sub-keys-from-a-registry-value https://www.vba-tutorial.de/apireferenz/registry.htm Dim Ws As Worksheet: Set Ws = ThisWorkbook.Worksheets("CLSIDsOldVista4810TZG") ' set ws = Set Ws = Me ' Set Ws = ActiveSheet Dim RegObject As Object, MeQuids() As Variant, QuidsNmbrValue As Variant Set RegObject = GetObject("winmgmts:\\.\root\default:StdRegProv") RegObject.EnumKey 2147483648#, "TypeLib", MeQuids() ' https://powershell.one/wmi/root/cimv2/stdregprov-EnumKey Dim Cnt As Long, ExRowCnt As Long: Let ExRowCnt = 1 ' ============================================== For Cnt = LBound(MeQuids()) To UBound(MeQuids()) Let Ws.Range("K" & ExRowCnt + 1 + 1 & "") = MeQuids(Cnt) ' RegObject.getstringvalue 2147483648#, "TypeLib\" & MeQuids(Cnt) & "\2.0", "", QuidsNmbrValue ' as example this is the first one, https://i.postimg.cc/k4Jm9RQ6/Type-Lib-Microsoft-Active-X-Data-Objects-2-0-Library.jpg ' This extra loop stuff could probably be done better ' ---------------------------------------- Dim strQuidNmbr As String, QuidNmbr As Single For QuidNmbr = 1 To 6 Step 0.1 Let strQuidNmbr = Format(QuidNmbr, "0.0") RegObject.getstringvalue 2147483648#, "TypeLib\" & MeQuids(Cnt) & "\" & strQuidNmbr & "", "", QuidsNmbrValue If IsNull(QuidsNmbrValue) Then Else Let Ws.Range("L" & ExRowCnt + 1 + 1 & "") = QuidsNmbrValue Let ExRowCnt = ExRowCnt + 1 End If Next QuidNmbr ' ---------------------------------------------------------------------------- If Ws.Range("K" & ExRowCnt + 1 + 1 & "").Value <> "" Then Let ExRowCnt = ExRowCnt + 1 ' This will make sure we also go down a lins for any Quid with no name Next Cnt ' ============================================================================= End Sub Sub SortIt() ' This will help to get a similar order to that seen in the VB Editor referrence list Dim Ws As Worksheet: Set Ws = ThisWorkbook.Worksheets("CLSIDsOldVista4810TZG") Ws.Range("M3:N666") = Ws.Range("K3:L666").Value Ws.Range("M3:N666").Sort Key1:=Ws.Range("N3:N666"), Order1:=xlAscending End Sub ' https://eileenslounge.com/viewtopic.php?p=326198#p326198 https://eileenslounge.com/viewtopic.php?p=326198&sid=6f3fd375f6153093b306e77e56d88af9#p326198 ' HKEY_CLASSES_ROOT (2147483648#) (&H80000000) ' HKEY_CURRENT_USER (2147483649#) ' HKEY_LOCAL_MACHINE (2147483650#) ' HKEY_USERS (2147483651#) ' HKEY_CURRENT_CONFIG (2147483653#)
Re arranged in alphabetical order in column N of uploaded file, and compared, - there is very close agreement:
https://i.postimg.cc/28kgC7XD/Good-C...eferrencee.jpgGood Correlation Quid from HKEY_CLASSES_ROOT TypeLib to referrencee.JPG
