Results 1 to 10 of 24
Thread: Version Info using VBA and registry quirks. InterRegional Settings GmbH
    Later
    Post #16 https://www.excelfox.com/forum/showt...ll=1#post25010
    https://www.excelfox.com/forum/showthread.php/2986-Version-Info-using-VBA-and-registry-quirks-InterRegional-Settings-GmbH?p=25010&viewfull=1#post25010
    https://www.excelfox.com/forum/showt...age2#post25010
    https://www.excelfox.com/forum/showthread.php/2986-Version-Info-using-VBA-and-registry-quirks-InterRegional-Settings-GmbH/page2#post25010
    My object creating abortion
    In the coding of mine, ( Public Sub ListCLSIDs_Me() or Sub ListCLSIDs() ) , I only got the list of the 36 characters in the squiggly bracket , { curly bracket quid/Clsid stuff } things. ( I did not know for sure how to get the name )
    But I was interested in the name thing. So as I was not sure how to do it, I wrote , back then, that second program, Sub CLSIDsValueNames() to try and get that name somehow. It basically creates the object, or tries to, and if it is successful, it tries to get the TypeName( object ) of that object.
    It works just on the selection you make in column A, the 36 characters in the squiggly bracket , { } things.
    Back then, I did a few . but, I broke off from doing it for all the 6527 things, as after doing a few, some applications started appearing after a computer restart, and I had to tank them from the Task Manager.
    But for the ones I did do so far, there is some similarity between what I get for my
    ____ = TypeName( the created object )
    , and what Mike effectively gets from these 2 lineyMike’s
    RegObject.getstringvalue &H80000000, "CLSID" & entryArray(ExRowCnt) & "\ProgId", "", KeyValue
    Prog = KeyValue
    Here, just as example, some of the first results
    https://i.postimg.cc/2jGKt0dz/Mine-a...al-results.jpg
    https://i.postimg.cc/htkym6n0/Mine-a...al-results.jpg
    https://i.postimg.cc/ncwwFMwg/Mine-a...al-results.jpg
    https://i.postimg.cc/tgFrNkCG/Mine-a...al-results.jpg
    https://i.postimg.cc/76DKszfG/Mine-a...al-results.jpg
    Check out also the worksheet named CLSIDsOldVista4810TZG in this file
    CLSDsUndClassNames.xls - https://app.box.com/s/nkjwti5yym9j0v634hrxerz4x7n1o90w
    Here again that abortion of a coding
     Sub CLSIDsValueNames() '
    Dim Ws As Worksheet: Set Ws = Me ' Set Ws = ActiveSheet
    Dim RngSel As Range:  Set RngSel = Selection
        If RngSel.Cells.Count = 1 Then MsgBox prompt:="Please select at least 2 cells in column A": Exit Sub
        If RngSel.Cells.Columns.Count <> 1 Then MsgBox prompt:="Please select at least 2 cells in only column A": Exit Sub
        If Not RngSel.Cells.Column = 1 Then MsgBox prompt:="Please select at least 2 cells in column A": Exit Sub
    Dim stearCel As Range
        For Each stearCel In RngSel
         Let Ws.Range("B" & stearCel.row & "").Value = "Tried" ' To indicate I tried - this can be useful to see where it crashed
        Dim OOPObj  As Object
        On Error GoTo EyeEyeSkipper
         Set OOPObj = CreateObject("New:" & stearCel.Value & "")
         Let Ws.Range("D" & stearCel.row & "").Value = TypeName(OOPObj)
         Let Application.DisplayAlerts = False
         ThisWorkbook.Save ' This is done to save all got so far incase Excel crashes on next loop or below
         Let Application.DisplayAlerts = True
        OOPObj.Close
        Set OOPObj = Nothing
    EyeEyeSkipper:
        On Error GoTo -1
        Next stearCel
  1. ADS info via VBA 64bit
    By TML59 in forum Excel Help
    Last Post: 07-13-2024, 03:43 PM
  2. Replies: 26
    Last Post: 07-17-2013, 11:42 AM
  3. Office Version Independent Non-Activex Date Time Picker Using Form Controls
    Last Post: 07-17-2013, 12:27 AM
  4. Info: different Value !
    By PcMax in forum Excel Help
    Last Post: 04-22-2012, 04:13 PM
  5. Version 2003 to 2007
    Last Post: 11-23-2011, 07:52 PM
