Results 1 to 10 of 24
Thread: Version Info using VBA and registry quirks. InterRegional Settings GmbH
  1. #12
    Dec 2022 https://www.eileenslounge.com/viewto...301534#p301534 2 Clipboard Trim Eval Range
    https://www.eileenslounge.com/viewto...301761#p301761 2 Hans knatsch
    Feb 2023 https://www.eileenslounge.com/viewto...304976#p304976 2 Do While Clipboard Gather unique values in one row for each unique key
    May 2023 https://www.eileenslounge.com/viewto...307826#p307826 2 clipboard ramble
    Jan 2023 https://www.eileenslounge.com/viewto...303007#p303007 2 Clipboard opps a vbCr & vbLf OopsAvbCr&vbLf.xls
    Jan 2023 https://www.eileenslounge.com/viewto...303039#p303039 2
    The .Copy method puts a copy of the object you are referencing onto the clipboard, in this case a Range.- and then synthesizes all the supported formats. including the Text format (which it does as the synthesized CF_TEXT format , which always ends CR LF [in fact it is even more clever than that, in that it actually separates Rows with CR LF and columns by Tab])
    The DataObject's .SetText method exposed to VBA, on the other hand, expects a straightforward text string
    The .Copy is going to tell the Clipboard that it …. ( it being VBA I think in this case, or possibly Excel as the controlling/"owning thing") …. this it is in charge of the clipboard for the time being. This it is a deferred render entry thing, but if and when it does actually put stuff in The ( Microsoft Windows ) Clipboard, then in the case of a range it is gonna be quite a few formats, (maybe about 30 ) or maybe not?: I mean, as its a deferred render entry thing it might decide to put different things in The ( Microsoft Windows ) Clipboard depending on what is done later to trigger the thing to do what it is deferring doing when it’s the controlling/ "owning thing" ?
    So that is maybe something close to what the .Copy is doing.
    .SetText and .PutInClipboard
    ( I am not sure if this is a deferred entry thing or not ? ).
    This can’t do anything much other than put text somewhere since that is all you give it: You give it a simple text string. That’s it.
    _.___________________________________________I am not 100% sure what you are saying by your reference synthesized CF_TEXT format.
    This is my guess as to what you are saying. :
    If I use the .GetFromClipboard and .GetText() from within VBA, then what I get will depend on what was the controlling "owning" thing of the The ( Microsoft Windows ) Clipboard at the time ….
    Let me consider the 2 cases relevant here…
    _ case1
    If .Copy was the owning controlling thing of The ( Microsoft Windows ) Clipboard, then, when it sees the request of .GetFromClipboard from within VBA, it may not quite have the format requested. ….I am trying to understand that link you gave ….. I will take a guess that what is going on in this case1 is this:
    It takes one of the formats on the first column from that link you gave which it does have* (*or will have – its deferred entry ....) . It than either makes one of the formats on the second column from that link, or maybe makes one that is not listed there. I don’t know. I do know, and agree with this bit that you said…. it actually separates Rows with CR LF and columns by Tab…..
    _ case2
    If the DataObject is the owning controlling thing of The ( Microsoft Windows ) Clipboard, ( in other words you did the .SetText and .PutInClipboard thing to put text in The ( Microsoft Windows ) Clipboard) , then …..you put a text in and you will get with the .GetFromClipboard and .GetText() the same text back. Simple as that. ( I am still not sure what of the CF_ things are used though in this case either )
    Clsid
    https://eileenslounge.com/viewtopic....314950#p314950 Mike GUID list CLSIDs skids SCIDs
    https://eileenslounge.com/viewtopic....289020#p289020 2 GUIDS CLSIDs in the { } as in CreateObject("New:" & “{aksjjfhaskj}” & "") Oct 2021
    https://eileenslounge.com/viewtopic....286708#p286708 3 CLSID .NET 3.5
    https://eileenslounge.com/viewtopic....289020#p289020 2 clsid Oct 2021 Feb 2016
    https://chandoo.org/forum/threads/cl...6/#post-223256
    API alternative
    2012 Looks like first report of it https://web.archive.org/web/20200806...d?forum=isvvba
    opened a support case with Microsoft as suggested by Kirk Beller…..MS determined the cause to be 'most likely a flaw in our product'. So far, I have had no notification of when or if it might be fixed - MS helped me develop a robust workaround using native Windows API calls instead of a DataObject. These are documented in the following articles:
    > http://msdn.microsoft.com/en-us/libr.../ff192913.aspx (How to: Send Information to the Clipboard); - Cant find on archive, but the original gets redirected to a new one from 2022, archived at similar date https://web.archive.org/web/20240421...-the-clipboard
    > http://msdn.microsoft.com/en-us/libr.../ff194373.aspx (How to: Retrieve Information from the Clipboard). – original archived
    2013 https://web.archive.org/web/20130113.../ff194373.aspx The original gets redirected to one from 2022 , archived at a similar date https://web.archive.org/web/20221203...-the-clipboard
    So far no MS article does the 64bit even though the original article has a post 2019 telling about it
    2015 https://www.spreadsheet1.com/how-to-...xcel-vba.html# VBA does not offer a clipboard object, although Visual Basic 6 did. …. copies just two questions marks to the clipboard when used under Windows 8 and 10 (as tested in September 2015)
    2015 https://wellsr.com/vba/2015/tutorial...d-paste-clear/ Mac as well like Rory’s 2018 Update: With the rollout of Windows 8 and Windows 10, this solution no longer works reliably,
    2018 https://web.archive.org/web/20191220...-the-clipboard difference between the DataObject and the Clipboard
    2018 https://chandoo.org/forum/threads/cl...6/#post-223256 Masterbasdor API Post
    Mar 2019 My last post is best, https://eileenslounge.com/viewtopic....247809#p247809 , giving further links
    Rory’s Tools https://eileenslounge.com/viewtopic....246708#p246708
    Some random links not looked at yet
    I don't have a Telekom anscluss
    <font color="#FFFFFF">EileensLongeCl...line.de</font>
    CumOnEileen.!*
    26 6 1945
    NS Storm Fuhrer - beruf großvaters
    015780900790 +4915780900790
    Passwort für E-Mail-Programme SendCum.!*
    Eileen CumHappy
    CumOnAbox971.!*
    Mar 2019 https://eileenslounge.com/viewtopic....247809#p247809 3 (Clipboard API alternative) array overflow date value Yasser rory
    Oct 2019 ht tps://social.msdn.microsoft.com/Forums/en-US/48e8c30c-24ee-458e-a873-a4e6e13f5926/dataobject-settext-and-putinclipboard-sequence-puts-invalid-data-hex-63-characters-in-clipboard?forum=isvvba not working so did archive org below which works
    htt ps://web.archive.org/web/20200806111619/h ttps://social.msdn.microsoft.com/Forums/en-US/48e8c30c-24ee-458e-a873-a4e6e13f5926/dataobject-settext-and-putinclipboard-sequence-puts-invalid-data-hex-63-characters-in-clipboard?forum=isvvba
    That seems to give > ht tp://msdn.microsoft.com/en-us/library/office/ff192913.aspx (How to: Send Information to the Clipboard); which is still as new but it is a redirect 2022 htt ps://learn.microsoft.com/en-us/office/vba/access/Concepts/Windows-API/send-information-to-the-clipboard there as new, and captures first start at Sep 2023 ??
    An old capture from Oct 2013 – htt ps://web.archive.org/web/20131003213600/http://msdn.microsoft.com/en-us/library/office/ff192913.aspx
    > htt p://msdn.microsoft.com/en-us/library/office/ff194373.aspx (How to: Retrieve Information from the Clipboard). Its dated 2022 currently as redirect htt ps://learn.microsoft.com/en-us/office/vba/access/Concepts/Windows-API/retrieve-information-from-the-clipboard
    A archive org from 2013 htt ps://web.archive.org/web/20130113075556/http://ms dn.microsoft.com/en-us/library/office/ff194373.aspx
    Maybe this was Rory’s cheat sheet from about 2015 ht tps://www.spreadsheet1.com/how-to-copy-strings-to-clipboard-using-excel-vba.html# VBA does not offer a clipboard object, although Visual Basic 6 did. …. copies just two questions marks to the clipboard when used under Windows 8 and 10 (as tested in September 2015)
    Hans wrong https://www.eileenslounge.com/viewto...art=20#p246887
    docs.microsoft.com instead of learn.microsoft.com
    https://learn.microsoft.com/en-us/ar...3-a4e6e13f5926
    https://docs.microsoft.com/en-us/arc...3-a4e6e13f5926
    https://social.msdn.microsoft.com/Fo...d?forum=isvvba
  1. ADS info via VBA 64bit
    By TML59 in forum Excel Help
    Last Post: 07-13-2024, 03:43 PM
  2. Replies: 26
    Last Post: 07-17-2013, 11:42 AM
  3. Office Version Independent Non-Activex Date Time Picker Using Form Controls
    Last Post: 07-17-2013, 12:27 AM
  4. Info: different Value !
    By PcMax in forum Excel Help
    Last Post: 04-22-2012, 04:13 PM
  5. Version 2003 to 2007
    Last Post: 11-23-2011, 07:52 PM
