Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Test
    Test
    These posts are to assist me in answering other Threads
    I hope it is OK for me to do this. Please do not delete"
    Molly
    Testing.
    Black
    BlackAlmost black blue - Darkest Blue in PalletBlack
    BlackDark BlueBlack
    BlackSecond Darkest Blue in PalletBlack
    BlackNavyBlack
    BlackBlueBlack
    BlackForum BlueBlack
    Black
    BlackDark BlueBlack
    BlackNavyBlack
    BlackBlueBlack
    Almost black blue - Darkest Blue in PalletNavyAlmost black blue - Darkest Blue in PalletNavyAlmost black blue - Darkest Blue in PalletNavyAlmost black blue - Darkest Blue in Pallet
    from ......... http://www.excelfox.com/forum/showth...=9821#post9821
    http://www.excelfox.com/forum/showth...de-Table/page5
    https://www.excelforum.com/tips-and-...ml#post4642554
    http://www.excelforum.com/the-water-...ml#post4109080
    _____ Workbook: LibroSoci.xls ( Using Excel 2007 32 bit )
    Ciao
    Worksheet: LibroSoci
    This post is to help me answering here:
    http://www.excelfox.com/forum/showth...2177#post12177
    Download both uploaded files
    ( Save them in the same place )
    Open file
    OpenAndRunMemacros.xls
    Run macro Sub MeMacroClitbored()
    That should cause the file LibroSoci.xls to be opened. It looks like this
    Ciao
    That should do _ some things with the variable NTes
    _ The variables contents appear in a message box
    LibroSociMsgBox.JPG : https://imgur.com/pEnKG7u
    _ The code lines,
    rowNo = xlBook.Worksheets("LibroSoci").Range("C:C").Find(What:=NTes, LookIn:=xlValues).Row
    xlBook.Worksheets("LibroSoci").Cells(rowNo, 4) = Year(Date)
    are used.
    So LibroSoci.xls changes to this:
    UseCodeLine.JPG : https://imgur.com/11g5OHX
    Ciao
    2020
    Coding in
    "LibroSoci.xls"
    ThisWorkbookCodeModuleLibroSoci.jpg: https://imgur.com/WYo3jrJ
    Private Sub Workbook_Open()
    'Stop
    Dim objDataObject As Object: Set objDataObject = GetObject("New:{1C3B4210-F441-11CE-B9EA-00AA006B1A69}")
    Dim NTes As String
     objDataObject.GetFromClipboard: Let NTes = objDataObject.GetText()
     MsgBox prompt:=NTes
    Dim xlBook As Workbook
    'Dim xlSheet As Excel.Worksheet
    'Dim xldata As Excel.Range
    'Dim ExcelPath As String
    Dim rowNo As Long
    ' ExcelPath = ThisWorkbook.Path & "\" ' CurrentProject.Path & "\"
    ' Set xlapp = CreateObject("Excel.Application")
    ' Set xlBook = xlapp.Workbooks.Open(ExcelPath & "LibroSoci.xls")
     Set xlBook = ThisWorkbook
    ' Set xlSheet = xlBook.Worksheets("LibroSoci")
    ' xlSheet.Select
    ' xlSheet.Activate
       ' With ActiveSheet
     Let rowNo = xlBook.Worksheets("LibroSoci").Range("C:C").Find(What:=NTes, LookIn:=xlValues).Row
     Let xlBook.Worksheets("LibroSoci").Cells(rowNo, 4).Value = Year(Date)
    '        If Me.Nuova_TessElett <> "" Then
    '            xlBook.Worksheets("LibroSoci").Cells(rowNo, 37) = Me.Nuova_TessElett
    '        End If
       ' End With
    Coding in
    "OpenAndRunMeMacros.xls"
    Dim NTes As String: Let NTes = "Ciao"
     objDataObject.SetText NTes
     objDataObject.PutInClipboard
     Application.OnTime EarliestTime:=Now(), Procedure:="AggiornaLibroSoci"
    Sub AggiornaLibroSoci()
    Dim xlapp As Excel.Application
    Dim xlBook As Excel.Workbook
    'Dim rowNo As Long
     Let ExcelPath = ThisWorkbook.Path & "\"  ' CurrentProject.Path & "\"
     Let xlapp.Visible = True
    ' xlSheet.Select
    ' xlSheet.Activate
    '       ' With ActiveSheet
    '        rowNo = xlBook.Worksheets("LibroSoci").Range("C:C").Find(What:=NTes, LookIn:=xlValues).Row
    '        xlBook.Worksheets("LibroSoci").Cells(rowNo, 4) = Year(Date)
    '    '        If Me.Nuova_TessElett <> "" Then
    '    '            xlBook.Worksheets("LibroSoci").Cells(rowNo, 37) = Me.Nuova_TessElett
    '    '        End If
    '       ' End With
    '     xlBook.Save
     xlBook.Close
     xlapp.Quit
    ' Set xlSheet = Nothing
     Set xlBook = Nothing
     Set xlapp = Nothing
    It is a similar idea as in the last post. The only difference is that the text information is passed via a text file.
    So as before, both files should be downloaded to the same place.
    File "OpenAndRunMeMacros.xls" should be opened and this time the macro Sub MeMacroTextMies() should be run.
    ( You do not need to do anything about the text file. That will be made the first time Sub MeMacroTextMies() is run , and subsequently it will be overwritten by each further run of Sub MeMacroTextMies(). )
    Sub MeMacroTextMies() running should cause "LibroSociTextMies.xls" to be opened, and as before a similar set of events should take place:
    A message box pops up:
    LibroSociTextMiesMsgBox.JPG : https://imgur.com/5sAvqPP
    and then the file "LibroSociTextMies.xls" is modified:
    UseCodeLine2.JPG : https://imgur.com/SKeW4MQ
    Coding in "OpenAndRunMeMacros.xls"
    Dim strcFileName As String: Let strcFileName = "Timer.txt"
    Dim intFile As Long: Let intFile = FreeFile
    Open ThisWorkbook.Path & "\" & strcFileName For Output As #intFile
    Write #intFile, NTes
    Close intFile
     Application.OnTime EarliestTime:=Now(), Procedure:="AggiornaLibroSociTexties"
    Sub AggiornaLibroSociTexties()
     Set xlBook = xlapp.Workbooks.Open(ExcelPath & "LibroSociTextMies.xls")
     xlBook.Close
     xlapp.Quit
     Set xlapp = Nothing
    Coding in "LibroSociTextMies.xls"
    Open ThisWorkbook.Path & "\" & strcFileName For Input As #intFile
    Dim NTes As String
    Input #intFile, NTes
    Close intFile
     MsgBox prompt:=NTes
    Dim rowNo As Long
    ... Feeling horny..
    C ja later
    x
    Screenshots I need to help answer the post that is just here:
    http://www.excelfox.com/forum/showth...-to-put-remark
    If column I is sell then see the value of column K & if column K is Greater than sheet2 of column E then put the remark in sheet3 in the stock name from column B
    If column I is buy then see the value of column K & if column K is lower than sheet2 of column F then put the remark in sheet3 in the stock name from column B
    remark will be in series like 1,2,3,4,5,6 and so on
    vba is palced in a separate file
    all files are located in same place
    and after putting the remark clear sheet 1 and sheet 2
    J
    K
    L
    NSE ACC EQ
    13
    SELL
    11.247
    1100.947
    NSE ADANIENT EQ
    BUY
    1.334
    130.734
    Worksheet: Sheet1
    NSE ACC EQ
    18
    NSE ADANIENT EQ
    129
    Worksheet: Sheet2
    Symbol
    ACC
    ADANIENT
    remark I have puuted 1 bcoz series start with 1
    and next time when I will run the macro
    then it will start with 2
    and again when I will ran the macro then it will start with 3
    Worksheet: Sheet3
    arrS1()
    NSE ACC EQ
    13
    SELL
    11.247
    1100.947
    NSE ADANIENT EQ
    BUY
    1.334
    130.734
    arrS2()
    NSE ACC EQ
    18
    NSE ADANIENT EQ
    129
    arrS3()
    Symbol
    ACC
    ADANIENT
    Symbol
    ACC
    ADANIENT
    Your data ?????
    SELL is K=1100.947 , sheet 2 column E is 1102 … so K is NOT > column E ---- so no output – no remark
    BUY is K = 130.734 , sheet 2 column E is 129 … so K is NOT < column E ----- so no output – no remark
    _.....see next post............._
    _...........from last post
    Try this data:
    _____ Workbook: Merge2.xls ( Using Excel 2007 32 bit )
    J
    K
    L
    NSE ACC EQ
    13
    SELL
    11.247
    1234
    NSE ADANIENT EQ
    BUY
    1.334
    125
    Worksheet: Sheet1
    Sub HidnInLisWb() '
    Rem 1 Worksheets info
    Dim Wbm As Workbook, Ws1 As Worksheet, Ws2 As Worksheet, Ws3 As Worksheet
     Set Wbm = Workbooks("Merge2.xls")
     Set Ws1 = Wbm.Worksheets("Sheet1"): Set Ws2 = Wbm.Worksheets("Sheet2"): Set Ws3 = Wbm.Worksheets("Sheet3")
    Rem 2 data Input
    Dim arrS1() As Variant, arrS2() As Variant, arrS3() As Variant
     Let arrS1() = Ws1.Range("A1").CurrentRegion.Value: arrS2() = Ws2.Range("A1").CurrentRegion.Value
    '2b
     ReDim arrS3(1 To UBound(arrS1(), 1)) ' A 1 dimension array of arrays
    ''2b(i)
    ' Let arrS3(1) = Ws3.Range("A" & Ws3.Range("A1").CurrentRegion.Columns.Count & "") ' header row as a one dimensional array
    ''2b(ii) data rows array output
    Rem 3
    Dim cnt
        For cnt = 2 To UBound(arrS1(), 1) '  "row" count, cnt
        '2b)(ii)
        Dim Lc As Long: Let Lc = Ws3.Cells.Item(cnt, Ws3.Cells.Columns.Count).End(xlToLeft).Column ' last column in this row cnt
         Let arrS3(cnt) = Ws3.Range("A" & cnt & ":" & CL(Lc + 1) & cnt & "").Value ' - returns an array of 1 "row" into this element of the array of arrays
         Select Case arrS1(cnt, 9) ' column I
          Case "SELL" 'If column I is sell
            If arrS1(cnt, 11) > arrS2(cnt, 5) Then ' if column K is Greater than sheet2 of column E then
             Let arrS3(cnt)(1, UBound(arrS3(cnt), 2)) = UBound(arrS3(cnt), 2) - 1 ' Put in a value in last array "column"
          Case "BUY"  'If column I is buy
           If arrS1(cnt, 11) < arrS2(cnt, 6) Then  ' if column K is lower than sheet2 of column F then
        '3b) output "row"
         Let Ws3.Range("A" & cnt & "").Resize(1, Lc + 1).Value = arrS3(cnt)
        Next cnt
    Rem 4    ....and after putting the remark clear sheet 1 and sheet 2
     Ws1.cells.Clear
     Ws2.cells.Clear
    'then see the value of column K &
    'if column K is Greater than sheet2 of column E then put the remark in sheet3 in the stock name from column B
    'If column I is buy
    'see the value of column K &
    'if column K is lower than sheet2 of column F then put the remark in sheet3 in the stock name from column B
    'remark will be in series like 1,2,3,4,5,6 and so on
    'vba is palced in a separate file
    'all files are located in same place
    'and after putting the remark clear sheet 1 and sheet 2
    '     http://www.excelfox.com/forum/showthread.php/1546-TESTING-Column-Letter-test-Sort
    From last post
    J
    K
    L
    M
    N
    O
    P
    Q
    R
    Symbol = arrS3(1) arrS3(1)(1, UBound(arrS3(1), 2)) = Symbol
    ACC
    = arrS3(2) arrS3(2)(1, UBound(arrS3(2), 2)) =
    ADANIENT
    = arrS3(2) arrS3(3)(1, UBound(arrS3(3), 2)) =
    arrS3()= { arrS3(1) , arrS3(2) , arrS3(3) }
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    Worksheet: Sheet3 (2)
    J
    K
    L
    M
    N
    O
    P
    Q
    R
    ACC
    ADANIENT
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    Some notes to help me in solving this Thread:
    http://www.excelfox.com/forum/showth...te-conditional
    _____ Workbook: 1.xlsx ( Using Excel 2007 32 bit )
    J
    K
    L
    NSE
    25
    50000
    A GTT
    NSE
    22
    10000
    A GTT
    NSE
    15083
    70000
    A GTT
    NSE
    17388
    20000
    A GTT
    NSE
    100
    170000
    A GTT
    Worksheet: Sheet1 (4)
    If column B of 2.xlsm match with column B of 1.xls then paste the data from column C of 2.xls as 1,2,3,4,5 and so on....
    If column B of 2.xlsm doesn't match with column B of 1.xls then delete all the data from column C of that row
    _____ Workbook: 2.xlsm ( Using Excel 2007 32 bit )
    Symbol
    ACC
    22
    ADANIENT
    25
    ADANIPORTS
    15083
    ADANIPOWER
    17388
    AMARAJABAT
    100
    ASIANPAINT
    236
    cells highlighted in red colour doesn’t match with 1.xls show the data from column C will be cleared so 1,2 will be erased
    13
    cells highlighted in green colour matches with 1.xls show we will paste the data from column C
    but if column C has data then we will paste to column D
    and if column D also has data then column E and so on….
    14
    highlighted colour is only for understanding purpose in actual file there will not be any highlighted colour data
    15
    Worksheet: Sheet1
    Continued from previous post
    I will answer this similar to the last question for consistency to help in understanding, and also do it in a way that might not be the most efficient, but may help in further modifications or similar requirements that I would not be surprised might follow…
    Regardless of, and before any checks for meeting the match criteria are done I will make an array of arrays as previously, arr3()
    This will be a one dimensional array. For the test data from the previous post this will have a size of 6 main elements, ( 7 incl. Header - arr3(0) not used ) , each of which is a single row, 2 dimensional array of the original data in 2.xlsm with the addition of an extra last element.
    ACC
    22
    ADANIENT
    25
    ADANIPORTS
    15083
    ADANIPOWER
    17388
    AMARAJABAT
    100
    ASIANPAINT
    236
    [ _____ Workbook: 2.xlsm ( Using Excel 2007 32 bit )
    arr3() = { arr3(1) , arr3(2) , arr3(3) , arr3(4) , arr3(5) , arr(6) }
    arr3(1) = ACC
    22
    arr3(2) = ADANIENT
    25
    arr3(3) = ADANIPORTS
    15083
    arr3(4) = ADANIPOWER
    17388
    arr3(5) = AMARAJABAT
    100
    arr3(6) = ASIANPAINT
    236
    Macro for
    '  http://www.excelfox.com/forum/showthread.php/2465-copy-paste-conditional
    Sub CopyPasterConditionalToPutRemark_1_2_3_etc() '
    Dim Wb1 As Workbook, Wb2 As Workbook, Ws1 As Worksheet, Ws2 As Worksheet
     Set Wb1 = Workbooks("1.xlsx")
     Set Wb2 = ThisWorkbook   '   macro will be placed in 2.xlsm
     Set Ws1 = Wb1.Worksheets.Item(1): Set Ws2 = Wb2.Worksheets.Item(1)
    Rem 2 data Input
    Dim arr1() As Variant, arr2() As Variant, arr3() As Variant
     Let arr1() = Ws1.Range("A1:K" & Ws1.Range("A1").CurrentRegion.Rows.Count & "").Value
     Let arr2() = Ws2.Range("A1").CurrentRegion.Value                                     ' Current region will not work for arrS1() because columns G to J are empty
    '2b
     ReDim arr3(0 To UBound(arr2(), 1)) ' A 1 dimension array of arrays , ( the first element arr3(0) we will not use )
    ''2b(i)
    Rem 3
    Dim Cnt
        For Cnt = 2 To UBound(arr2(), 1) '  "row" count, Cnt from after heading untill last row in  2.xlsm ( Ws2 )
        '2b)(ii) make and fill the row element array inside the current arr3(cnt) element
        Dim Lc As Long: Let Lc = Ws2.Cells.Item(Cnt, Ws2.Cells.Columns.Count).End(xlToLeft).Column ' last column in this row cnt
         Let arr3(Cnt - 1) = Ws2.Range("A" & Cnt & ":" & CL(Lc + 1) & Cnt & "").Value ' - returns an array of 1 "row" into this element of the array of arrays. It has one more element than filled columns - this empty last element is filled in the next line
         Let arr3(Cnt - 1)(1, UBound(arr3(Cnt - 1), 2)) = UBound(arr3(Cnt - 1), 2) - 2 ' this puts the next integer in the last, currently empty element
        '3a) Check for match criteria
        Dim mtchRes As Variant
         Let mtchRes = Application.Match(arr2(Cnt, 2), Ws1.Range("B1:B" & UBound(arr1(), 1) & ""), 0)
            If IsError(mtchRes) Then  '  If the last line errored than we did not find a match, so from the 3rd up to the last element need to be rtemoved from the array for this row
            Dim Empt As Long
                For Empt = 3 To UBound(arr3(Cnt - 1), 2)
                 Let arr3(Cnt - 1)(1, Empt) = ""
                Next Empt
            ' a match was found, so we do not need to remove the  1   2   3   etc...
        '3c) Paste out row
         Let Ws2.Range("A" & Cnt & "").Resize(1, Lc + 1).Value = arr3(Cnt - 1)
        ' Ws1.Cells.Clear
        ' Ws2.Cells.Clear
    Share ‘1.xlsx’ : https://app.box.com/s/0yc8icxb03i4vs1h11n20l43frmd52qa
    Share ‘2.xlsm’ : https://app.box.com/s/ry312xpb04kwef4wufvvx54qpv1mwai0
  1. Test
    Last Post: 03-30-2020, 07:20 PM
  2. test
    By EFmanagement in forum Test Area
    Last Post: 09-29-2019, 11:01 PM
  3. This is a test Test Let it be
    By Admin in forum Test Area
    Last Post: 05-30-2014, 09:44 AM
  4. Test
    Last Post: 07-05-2011, 01:51 AM
