Appendix Thread. ( Codes for other Threads, etc.) Event Coding Drpdown Data validation
Grid coordinates for a Range using [ ] and Evaluate(" ") through a named Range
Obtaining grid coordinates for an Area of contiguous cells in a Spreadsheet using [ ] and Evaluate(“ “) through the use of a Named Range for that Area
Aka ' It is a Range Name Test : Its n Range Name Test : 's 'n Rng Name Test : s n Rg Name Testie : snRg.Name = "snRgNme"
This code is in support of other Posts in various Threads. ( I will edit the Links as I reference this post )
For example:
http://www.excelforum.com/showthread...t=#post4400666
The code takes in a hard coded Range, A1:E10.
That Range is given a Name as held in the Names Register of a Worksheet.
Various code lines are developed which reference this Named Range and return the Grid Coordinates.
These coordinates are held within the following Long Type Variables
Cs is the start column
sClm is the column count
stpClm is the stop column
Rs is the start row
sRw is the rows count
stpRw is the stop row
'10 ' It is a Range Name Test : Its n Range Name Test : 's 'n Rng Name Test : s n Rg Name Testie : snRg.Name = "snRgNme"
Sub snRgNameTest() ' Inspired by.. snb .. " array [ ] " ' http://www.excelfox.com/forum/showthread.php/2083-Delete-One-Row-From-A-2D-Variant-Array?p=9714#post9714
20 ' Worksheets Info
30 Dim ws As Worksheet ' ' Preparing a "Pointer" to an Initial "Blue Print" ( or a Form, or a Questionnaire not yet filled in, a template etc.) in Memory of the Object ( Pigeon Hole with a bit of paper or code lines on that can be filled in to refer to a specific Object of this type ) . This also us to get easily at the Methods and Properties through the applying of a period ( .Dot) ( intellisense )
40 'Set ws = ThisWorkbook.Worksheets("NPueyoGyanArraySlicing") 'The worksheets collection object is used to Set ws to the Sheet we are playing with, so that we carefull allways referrence this so as not to go astray through Excel Guessing inplicitly not the one we want... ' Values are filled at the memory locations and the directions there are specified in the variable "Blue Print "Pointer". In this case a Filled in Blue Print is passed. http://www.excelforum.com/excel-programming-vba-macros/1138804-help-understanding-class-instancing-cant-set-ws-new-worksheet-intellisense-offers-it-4.html#post4387191
50 Set ws = ActiveSheet ' Alternative to last line, make code apply to the current active sheet, - That being "looked at" when running this code '
60 Dim vTemp As Variant ' To help development when you are not sure what type is retuned. "Suck and see what comnes out!" Highlight it and Hit Shift+F9 to see it in the imediate Window
70 ' Named range referrencing Invoke Pike Evaluate Rabbit Rabbit. How's the Bunny ? Bunnytations Banters
80 Dim snRg As Range: Set snRg = ws.Range("A1:E10")
90 Dim sName As String: Let sName = "snRgNme" '
100 Let snRg.Name = "snRgNme" ' It is a Range Name me - " 's 'n Range Name me " .. "snRgNme" ;) This name appears permanentlly in then sheet. It remains referrencing this range unless the name iis deleted or the range referrenced is overwritten by a similar code line which has a different range in it on RHS of = http://www.thespreadsheetguru.com/blog/2014/6/20/the-vba-guide-to-listobject-excel-tables
110 Let snRg.Name = sName ' Identical to last line
120 Dim ReturnedsnRgName As String
130 Let ReturnedsnRgName = snRg.Name ' The returned name is full, like "NPueyoGyanArraySlicing!$A$1:$E$10". This will not work in the Address Formulas
140 Dim NameOnly As String: Let NameOnly = Replace((snRg.Name), "!", "", (InStr(1, (snRg.Name), "!"))): Debug.Print snRg.Name: Dim pos&: pos = InStr(1, (snRg.Name), "!"): NameOnly = Replace((snRg.Name), "!", "", pos) ' We had ---- "NPueyoGyanArraySlicing!$A$1:$E$10" so here I return a string that starts at the position of the ! and which replaces in that truncated shortened string - "!$A$1:$E$10" the "!" with nothing
150 Let NameOnly = Replace((ReturnedsnRgName), "!", "", (InStr(1, (ReturnedsnRgName), "!")))
160 If InStr(NameOnly, "!") > 0 Then MsgBox prompt:="NameOnly is " & vbCr & """" & NameOnly & """" & vbCr & "so will chop off up to and including the ""!""": Let NameOnly = Replace((NameOnly), "!", "", (InStr(1, (NameOnly), "!"))) ' Just to demo that you need to do this if you are not sure that a ! is there, or the code line would error if no ! was in there..
170 '
180 ' Count, Start, and Stop of columns in an Area of contiguous cells in a Spreadsheet
190 Dim sClm As Long 'Variable for ColumnsCount. -This makes a Pigeon Hole sufficient in construction to house a piece of Paper with code text giving the relevant information for the particular Variable Type. VBA is sent to it when it passes it. In a Routine it may be given a particular “Value”, or (“Values” for Objects). There instructions say then how to do that and handle(store) that(those). At Dim the created Paper is like a Blue Print that has some empty spaces not yet filled in. Long is very simple to handle, final memory "size" type is known (13.456, 00.001 have same "size" computer memory ),so an Address suggestion can be given for when the variable is filled in. (Long is a Big whole Number limit (-2,147,483,648 to 2,147,483,647). If you need some sort of validation the value should only be within the range of a Byte/Integer otherwise there's no point using anything but Long.-upon/after 32-bit, Integers (Short) need converted internally anyway, so a Long is actually faster)
200 Let sClm = Evaluate("columns(snRgNme)") ' = 5
210 'Let sClm = Evaluate("columns(RetunedsnRgName)") 'Run time Error as expected
220 Let sClm = [columns(snRgNme)] ' = 5 'Is this Most Powerful Command in VBA?, or what ... http://www.ozgrid.com/forum/showthread.php?t=52372 http://www.mrexcel.com/forum/excel-questions/899117-visual-basic-applications-range-a1-a5-vs-%5Ba1-a5%5D-benefits-dangers.html
230 'Let sClm = [columns(RetunedsnRgName)] 'Run time Error as expected
240 Let sClm = [columns(A1:E10)] ' = 5
250 Let vTemp = Evaluate("column(snRgNme)") ' Reveals an Array {1, 2, 3, 4, 5} - 1 Dimension "pseudo Horizontal" Array
260 Dim Cs As Long 'Variable for Start Column
270 Let Cs = Evaluate("column(A1:E10)")(1)
280 Let Cs = Evaluate("column(snRgNme)")(1) ' = 1
290 Let vTemp = [column(snRgNme)]: vTemp = vTemp(1) ' Anololie erklart: http://www.excelforum.com/showthread.php?t=1141369&p=4398930&highlight=#post4398930 http://www.excelforum.com/showthread.php?t=1141369&p=4398966#post4398966
300 Let Cs = [column(A1:E10)]()(1)
310 Let Cs = [column(snRgNme)]()(1)
320 '
330 Dim stpClm% ' Variable for Stop column Number ' ( % is shorthand for As Long ..http://www.excelforum.com/showthread.php?t=1116127&p=4256569#post4256569
340 Let stpClm = Cs + (sClm - 1) ' = 5
350 ' [ ]
360 Let stpClm = [column(snRgNme)]()(1) + ([columns(snRgNme)] - 1)
370 Let stpClm = [column(snRgNme)]()(1) + ([columns(snRgNme)] - 1)
380 ' In between step [ ] and Evaluate(" ")
390 Let stpClm = [column(snRgNme)]()(UBound([column(snRgNme)]))
400 ' Now Full Evaluate(" ")
410 Let stpClm = Evaluate("column(snRgNme)")(1) + (Evaluate("columns(snRgNme)") - 1)
420 Let stpClm = Evaluate("column(snRgNme)")(UBound(Evaluate("column(snRgNme)")))
430 '
440 ' Start, Count and Stop of rows in an Area of contiguous cells in a Spreadsheet
450 Dim sRw As Long 'Rows Count
460 Let sRw = Evaluate("rows(snRgNme)")
470 Let sRw = [rows(snRgNme)]
480 Let sRw = [rows(A1:E10)]
490 Let vTemp = Evaluate("row(snRgNme)") ' = {1; 2; 3; 4; 5; 6; 7; 8; 9; 10}
500 Dim Rs As Long 'Start Row
510 Let Rs = Evaluate("row(A1:E10)")(1, 1) 'Note a 2 Dimensional, 1 column, "vertical" Array is returned : ' vTemp = {1; 2; 3; 4; 5; 6; 7; 8; 9; 10}
520 Let Rs = Evaluate("row(snRgNme)")(1, 1)
530 Let vTemp = [row(snRgNme)]: vTemp = vTemp(1, 1)
540 Let Rs = [row(A1:E10)]()(1, 1)
550 Let Rs = [row(snRgNme)]()(1, 1)
560 '
570 Dim stpRw% 'Stop Row
580 Let stpRw = Rs + (sRw - 1)
590 Let stpRw = [row(snRgNme)]()(1, 1) + ([rows(snRgNme)] - 1)
600 Let stpRw = [row(snRgNme)]()(1, 1) + ([rows(snRgNme)] - 1)
610 '
620 Let stpRw = [row(snRgNme)]()(UBound([row(snRgNme)], 1), 1) 'UBound([row(snRgNme)], 1) is Ubound first ( "row" ) dimension. UBound([row(snRgNme)], 2) would be the second dimension ( "column" ) count
630 '
640 Let stpRw = Evaluate("row(snRgNme)")(1, 1) + (Evaluate("rows(snRgNme)") - 1)
650 Let stpRw = Evaluate("row(snRgNme)")(UBound(Evaluate("row(snRgNme)")), 1)
660 '
' Delete One Row From A 2D Variant Array
"Opened up" Rick code:
' To Test Function, Type some arbitrary values in range A1:E10, step through Test Code in F8 Debug Mode in VB Editor, and examine Worksheet, Immediate Window ( Ctrl+G when in VB Editor ), hover over variables in the VB Editor Window with mouse cursor, set watches on variables ( Highlight any occurrence of a variable in the VB Editor and Hit Shift+F9 ) , etc.. and then you should expected the required Output to be pasted out starting Top Left at cell M17
(_... Original Code:
' http://www.excelfox.com/forum/showth...=9658#post9658
' http://www.excelfox.com/forum/showthread.php/2083-Delete-One-Row-From-A-2D-Variant-Array?p=9658#post9658
Sub Rick()
Dim sp() As Variant
Dim DataArr() As Variant: Let DataArr() = Range("A1:E10").Value
Let sp() = Fu_Rick(DataArr(), 5)
Range("M17").Resize(UBound(sp(), 1), UBound(sp(), 2)).ClearContents
Let Range("M17").Resize(UBound(sp(), 1), UBound(sp(), 2)) = sp()
Required Function_...
Function Fu_Rick(ByRef arrIn() As Variant, ByVal RowToDelete As Long) As Variant
_... in next Post
' Delete One Row From a ... group of contiguous cells in a Spreadsheet
"Opened up" snb Code
(_.. Original code here
http://www.excelfox.com/forum/showth...=9714#post9714
_........)
' To Test Function, Type some arbitrary values in range A1:E10, step through code in F8 Debug Mode in VB Editor, and examine Worksheet, Immediate Window ( Ctrl+G when in VB Editor ), hover over variables in the VB Editor Window with mouse cursor, set watches on variables ( Highlight any occurrence of a variable in the VB Editor and Hit Shift+F9 ) , etc.. and then you should expected the required Output to be pasted out starting Top Left at cell M17
Sub snb_()
Dim sp() As Variant
Let sp() = Fu_snb(Range("A1:E10"), 5)
Function Fu_snb(ByVal sn As Range, ByVal y As Long) As Variant
_...in next Post
Delete One Row From A 2D Excel Range Area
Main Test Code ( Required Function given a couple of Posts down )
' Delete One Row From A 2D Excel Range Area
Sub Alan()
Dim sp() As Variant
'Dim DataArr() As Variant: Let DataArr() = Range("A1:E10").Value
Let sp() = FuR_Alan(Range("A1:E10"), 5)
'Let sp() = FuRSHg(Range("A1:E10"), 5)
'Let sp() = FuRSHgDotT(Range("A1:E10"), 5)
'Let sp() = FuRSHgShtHd(Range("A1:E10"), 5)
_............
For no particular reason I am considering this as my Input "Area"
Using Excel 2007 32 bit
| Row\Col |
A |
B |
C |
D |
E |
F |
| 1 |
0 |
10 |
20 |
30 |
40 |
| 2 |
2 |
12 |
22 |
32 |
42 |
| 3 |
4 |
14 |
24 |
34 |
44 |
| 4 |
6 |
16 |
26 |
36 |
46 |
| 5 |
8 |
18 |
28 |
38 |
48 |
| 6 |
10 |
20 |
30 |
40 |
50 |
| 7 |
12 |
22 |
32 |
42 |
52 |
| 8 |
14 |
24 |
34 |
44 |
54 |
| 9 |
16 |
26 |
36 |
46 |
56 |
| 10 |
18 |
28 |
38 |
48 |
58 |
| 11 |
| Sheet: NPueyoGyanArraySlicing |
_.......
Expected Output shown in next Post
Grid coordinates for a Range using [ ] & Evaluate(" ") through a Named Range. Code 2
Second Code with further lines to overcome extra () required for start row and star column codes
Obtaining grid coordinates for an Area of contiguous cells in a Spreadsheet using [ ] and Evaluate(" ") through the use of a Named Range for that Area
Aka ' It is a Range Name Test 2: Its n Range Name Test 2: 's 'n Rng Name Test 2: s n Rg Name Testie 2: snRg.Name = "snRgNme"
That Range is given a Name as held in the Names Register of a Workbook ( Workbooks Scope ).
Cs is the column count
sClm is the start column
Rs is the rows count start row
sRw is the start row
' Code 2
'10 ' It is a Range Name Test 2: Its n Range Name Test 2: 's 'n Rng Name Test 2: s n Rg Name Testie 2: snRg.Name = "snRgNme"
Sub snRgNameTest2() ' Inspired by.. snb .. " array [ ] " ' http://www.excelfox.com/forum/showthread.php/2083-Delete-One-Row-From-A-2D-Variant-Array?p=9714#post9714
70 ' Named Range referrencing ' Workbooks ( Default ) Scope Invoke Pike Evaluate Rabbit Rabbit. How's the Bunny ? Bunnytations Banters
120
130 '== DANGER: === Pitful: Above we gave the Range Object a Name, but now see what "Name" or "Name" 's comes back "!" !
131 Dim clms() As Variant 'Array to take returned Variant type Field of sequential column numbers
132 Dim retRefstrName As String, retObjName As Object
133 Let retRefstrName = snRg.Name: Set retObjName = snRg.Name: Debug.Print snRg.Name 'something of the form "NPueyoGyanArraySlicing!$A$1:$E$10" is reveald in Immediate ( Ctrl+G when in VB Editor ) Window
134 'Let clms() = Evaluate("column(=NPueyoGyanArraySlicing!$A$1:$E$10)") 'Let clms() = Evaluate("column(" & retRefstrName & ")")' Rintime Error 13: Incompatiblee types
135 Let clms() = Evaluate("column(NPueyoGyanArraySlicing!$A$1:$E$10)") 'Works
137 Dim NameOnly As String: Let NameOnly = Replace((snRg.Name), "!", "", (InStr(1, (snRg.Name), "!"))): 'Debug.Print snRg.Name: Dim pos&: pos = InStr(1, (snRg.Name), "!"): NameOnly = Replace((snRg.Name), "!", "", pos) ' We had ---- "NPueyoGyanArraySlicing!$A$1:$E$10" This is a String referrece returned when the Name Object is used directly or set to a String Variable. so here I return a string that starts at the position of the ! and which replaces in that truncated shortened string - "!$A$1:$E$10" the "!" with nothing
138 Let clms() = Evaluate("column(" & NameOnly & ")"): Let clms() = Evaluate("column(" & Replace((snRg.Name), "!", "", (InStr(1, (snRg.Name), "!"))) & ")")
139
140 Dim strName As String: Let strName = snRg.Name.Name: Debug.Print strName: Let strName = retObjName.Name: Debug.Print strName ' returns our original "CoN"
142 Let clms() = Evaluate("column(" & strName & ")")
150 Dim rngF1G2 As Range: Set rngF1G2 = Range("F1:G2"): Let Range("F1:G2").Value = "From Line 150"
151 Let Range("=NPueyoGyanArraySlicing!F1:G2").Value = "From Line 151"
152 Let rngF1G2.Name = "snFG": Let Range("snFG").Value = "From Line 152"
153
154
159 '===============
160 Let clms() = Evaluate("column(snRgNme)"): Let clms() = [column(snRgNme)] ' Full and "shorthand" Simple 1 D "pseudo horizontal" Array of column Indicies.
170 '
190 Dim Cs As Long 'Variable for ColumnsCount. -This makes a Pigeon Hole sufficient in construction to house a piece of Paper with code text giving the relevant information for the particular Variable Type. VBA is sent to it when it passes it. In a Routine it may be given a particular "Value", or ("Values" for Objects). There instructions say then how to do that and handle(store) that(those). At Dim the created Paper is like a Blue Print that has some empty spaces not yet filled in. Long is very simple to handle, final memory "size" type is known (13.456, 00.001 have same "size" computer memory ),so an Address suggestion can be given for when the variable is filled in. (Long is a Big whole Number limit (-2,147,483,648 to 2,147,483,647). If you need some sort of validation the value should only be within the range of a Byte/Integer otherwise there's no point using anything but Long.-upon/after 32-bit, Integers (Short) need converted internally anyway, so a Long is actually faster)
200 Let Cs = Evaluate("columns(snRgNme)") ' = 5
210 'Let Cs = Evaluate("columns(RetunedsnRgName)") 'Run time Error as expected
220 Let Cs = [columns(snRgNme)] ' = 5 'Is this Most Powerful Command in VBA?, or what ... http://www.ozgrid.com/forum/showthread.php?t=52372 http://www.mrexcel.com/forum/excel-questions/899117-visual-basic-applications-range-a1-a5-vs-%5Ba1-a5%5D-benefits-dangers.html
230 'Let Cs = [columns(RetunedsnRgName)] 'Run time Error as expected
240 Let Cs = [columns(A1:E10)] ' = 5
260 Dim sClm As Long 'Variable for Start Column
270 Let sClm = Evaluate("column(A1:E10)")(1)
280 Let sClm = Evaluate("column(snRgNme)")(1) ' = 1
290 Let sClm = [column(A1:E10)]()(1)
300 Let sClm = [column(snRgNme)]()(1)
301
302 Let sClm = Evaluate("=MIN(column(snRgNme))"): Let sClm = [=MIN(column(snRgNme))] 'Alternative using Spreadsheet Functions to avoid having to VBA ()( ) after the Evaluate
329 '
340 Let stpClm = sClm + (Cs - 1) ' = 5
350 ' [ ]
360 Let stpClm = [column(A1:E10)]()(1) + ([columns(A1:E10)] - 1)
421
430 Let stpClm = Evaluate("=MIN(column(snRgNme))") + (Evaluate("columns(snRgNme)") - 1) ''Alternatives using Spreadsheet Functions to avoid having to VBA ()( ) after the Evaluate
431 Let stpClm = [=MIN(column(snRgNme))] + ([columns(snRgNme)] - 1)
432 Let stpClm = [=MIN(column(snRgNme)) + (columns(snRgNme) - 1)]
439 '
450 Dim Rs As Long 'Rows Count
460 Let Rs = Evaluate("rows(snRgNme)")
470 Let Rs = [rows(snRgNme)]
480 Let Rs = [rows(A1:E10)]
500 Dim sRw As Long 'Start Row
510 Let sRw = Evaluate("row(A1:E10)")(1, 1) 'Note a 2 Dimensional, 1 column, "vertical" Array is returned : ' vTemp = {1; 2; 3; 4; 5; 6; 7; 8; 9; 10}
520 Let sRw = Evaluate("row(snRgNme)")(1, 1)
530 Let sRw = [row(A1:E10)]()(1, 1)
540 Let sRw = [row(snRgNme)]()(1, 1)
541
550 Let sRw = Evaluate("=MIN(Row(snRgNme))"): Let sRw = [=MIN(Row(snRgNme))] '''Alternatives using Spreadsheet Functions to avoid having to VBA ()( ) after the Evaluate
560
580 Let stpRw = sRw + (Rs - 1)
590 Let stpRw = [row(A1:E10)]()(1, 1) + ([rows(A1:E10)] - 1)
610 '
630 '
660 '
670 Let stpRw = Evaluate("=MIN(Row(snRgNme))") + (Evaluate("rows(snRgNme)") - 1) ''''Alternatives using Spreadsheet Functions to avoid having to VBA ()( ) after the Evaluate
680 Let stpRw = [=MIN(Row(snRgNme))] + [rows(snRgNme)] - 1
690 Let stpRw = [=MIN(Row(snRgNme))] + [rows(snRgNme)] - 1
700 Let stpRw = [=MIN(Row(snRgNme)) + rows(snRgNme) - 1]
Alternative Codes using [ ] shorthand
' To Test Function, Type some arbitrary values in range A1:E10, step through Main Test Code in F8 Debug Mode in VB Editor, and examine Worksheet, Immediate Window ( Ctrl+G when in VB Editor ), hover over variables in the VB Editor Window with mouse cursor, set watches on variables ( Highlight any occurrence of a variable in the VB Editor and Hit Shift+F9 ) , etc.. and then you should expected the required Output to be pasted out starting Top Left at cell M17
' "Short hand", ShtHd, version using []
' requires snb and kalak "neat trick" so you can to all intents and purpose do very close to doing vba Un Hard coded in [ ] - http://www.excelfox.com/forum/showthread.php/2083-Delete-One-Row-From-A-2D-Variant-Array?p=9714#post9714 http://www.mrexcel.com/forum/excel-questions/899117-visual-basic-applications-range-a1-a5-vs-%5Ba1-a5%5D-benefits-dangers.html#post4331217
' and Evaluate [ ] Properties , AloPerties, Methods - Alan Dynamic Coding Wonks http://www.excelforum.com/excel-programming-vba-macros/1141369-evaluate-and-differences-evaluated-array-return-needs-extra-bracket-for.html#post4400666
Function FuR_AlanShtHd(ByVal rngIn As Range, ByVal FoutRw As Long) As Variant
1 Let rngIn.Name = "snRgNme"
5 Dim vTemp As Variant 'A varyable to fill with something and "suck and see" what you get
10 ' use "neat magic" code line arrOut() = Application.Index(arrIn(), rwsT(), clms()) ' http://www.excelforum.com/excel-new-...ba-arrays.html http://www.mrexcel.com/forum/excel-q...ml#post4375354
20 ' BUT in Cells form arrOut() = Application.Index(Cells, rwsT(), clms()) ' http://www.excelforum.com/excel-prog...t-range-2.html
40 Set ws = rngIn.Parent ' Values are filled at the memory locations and the directions there are specified in the variable "Blue Print "Pointer". In this case a Filled in Blue Print is passed. http://www.excelforum.com/excel-prog...ml#post4387191
50 ws.Range("K30").ClearContents: ws.Range("K30").Value = "Here I am, in this Worksheet!"
60 'clms()
70 Dim sClm As Long, Cs As Long 'Variable for Count of, Start Column. - This makes a Pigeon Hole sufficient in construction to house a piece of Paper with code text giving the relevant information for the particular Variable Type. VBA is sent to it when it passes it. In a Routine it may be given a particular "Value", or ("Values" for Objects). There instructions say then how to do that and handle(store) that(those). At Dim the created Paper is like a Blue Print that has some empty spaces not yet filled in. Long is very simple to handle, final memory "size" type is known (13.456, 00.001 have same "size" computer memory ),so an Address suggestion can be given for when the variable is filled in. (Long is a Big whole Number limit (-2,147,483,648 to 2,147,483,647). If you need some sort of validation the value should only be within the range of a Byte/Integer otherwise there's no point using anything but Long.-upon/after 32-bit, Integers (Short) need converted internally anyway, so a Long is actually faster)
80 Let sClm = [=MIN(column(snRgNme))] '###Not needed now. Alternative using Spreadsheet Functions to avoid having to VBA ()( ) after the Evaluate
90 Dim clms() As Variant ' Evaluate Function used below returns a Field of Variant Element Types so the Array Elemments must be Declared appropriately. Must be adynamic Array to accept and be effectivelly sized by the Field size assigned to it.
95 Let clms() = [column(snRgNme)] ' snb Range Name equivalent so ### 'Let clms() = Evaluate("column(" & CL(sClm) & ":" & CL(sClm + (Cs - 1)) & ")")
100
160 'rwsT()
170 Dim sRw As Long, Rs As Long, stpRw As Long '
180 Let sRw = [=MIN(Row(snRgNme))] '''Alternatives using Spreadsheet Functions to avoid having to VBA ()( ) after the Evaluate ' Let sRw = rngIn.Areas.Item(1).Row
190 Let Rs = [rows(snRgNme)] 'Let Rs = rngIn.Areas.Item(1).Rows.Count
191 Let stpRw = [=MIN(Row(snRgNme)) + rows(snRgNme) - 1] '''Alternatives using Spreadsheet Functions to avoid having to VBA ()( ) after the Evaluate
200
240 'Get Full row indicies convenientally ( As 1 D "pseudo horizontal" Array ) from Spreadsheet Column() Function
250 Dim rws() As Variant: Let rws() = Evaluate("column(" & CL(sRw) & ":" & CL(sRw + (Rs - 1)) & ")")
251 Let vTemp = [CL(1)]: vTemp = [CL(MIN(Row(snRgNme)))] 'Both Return "A"
252 vTemp = [CL(MIN(Row(snRgNme)) + rows(snRgNme) - 1)] 'Returns "J"
254 Let rws() = [column(A:J)] ' Works
257 'Let rws() = [column(CL(1):J)] ' Fails - Bug in Excel ! ? !
258 'Let rws() = [column(CL(MIN(Row(snRgNme))):CL(MIN(Row(snRgNme)) + rows(snRgNme) - 1))] ' Fails - Bug in Excel ! ? !
260 Let rws() = Evaluate("column(" & [CL(MIN(Row(snRgNme)))] & ":" & [CL(MIN(Row(snRgNme)) + rows(snRgNme) - 1)] & ")")
270
280 'Get full sequential row indicies in a string.
290 Dim strRws As String: Let strRws = VBA.Strings$.Join(rws(), "|") ' 'The VBA strings collection such as Join in there basic form must not returnn a string, they can also return for example Null, a special type of variant. That lies within it's "powers. - It will coerce even an Empty, or Null to a variant type and return that. That takes extra ( unecerssary work here ). If the result of a function is used as a string or assigned it to a string variable, use the $ form of the function. This results in faster executing code, because a conversion from a variant to a string is unnecessary. http://www.excelforum.com/excel-new-...ml#post4084783 I believe that without $ a Strings collection Function coerces the first parameter into Variant, with $ does not - that's why $ is preferable over no $ , it's theoretically more efficient. http://www.xoc.net/standards/rvbacc....rSignFunctions
300
330 'Get String with missing row
340 Dim strrwsD As String: Let strrwsD = Replace(strRws, "|" & FoutRw & "", "", 1, -1)
350
360 'Get Array ( 1 D Pseudo Horizontal ) of required row indicies
370 Dim rwsS() As String ' The VBA Strings Collection Function, Split, used below returns a Field of String Element Types so the Array Elemments must be Declared appropriately. It must be adynamic Array to accept and be effectivelly sized by the Field size assigned to it.
375 Let rwsS() = VBA.Strings$.Split(strrwsD, "|", -1)
380 'final Transposed Array for "magic neat" code line
390 Dim rwsT() As String: ReDim rwsT(0 To (UBound(rwsS())), 1 To 1) ' Both the type and size of Array is known so can be decared initially appropriatelly. Re Dim must be used as Dim only takes values, not variables
400 Dim Cnt As Long
410 For Cnt = 0 To UBound(rwsS())
420 Let rwsT(Cnt, 1) = rwsS(Cnt)
430 Next Cnt
440 'Output Array
450 Dim arrOut() As Variant
460 Let arrOut() = Application.Index(ws.Cells, rwsT(), clms()) '"Magic neat" Code line in Cells first argument Form
470
480 Let FuR_AlanShtHd = arrOut()
490
500 ' . Transpose
510 Dim rwsDotT() As Variant ' Transpose Function used below returns a Field of Variant Element Types so the Array Elemments must be Declared appropriately. Must be adynamic Array to accept and be effectivelly sized by the Field size assigned to it.
520 Let rwsDotT() = Application.Transpose(rwsS())
530 Let arrOut() = Application.Index(ws.Cells, rwsDotT(), clms())
540
550 Let FuR_AlanShtHd = arrOut()
Array List Sort of Referrences
Referrences in suppost of this post:
http://www.excelfox.com/forum/showth...=9985#post9985
and solution to this post
http://www.excelforum.com/excel-prog...ml#post4507157
' http://www.snb-vba.eu/VBA_Arraylist_en.html
' http://www.snb-vba.eu/VBA_Arraylist_en.html#L_11.3
' https://usefulgyaan.wordpress.com/20...1/#comment-587
' https://usefulgyaan.wordpress.com/20...1/#comment-515
' https://usefulgyaan.wordpress.com/2013/06/12/vba-trick-of-the-week-slicing-an-array-without-loop-application-index/comment-page-1/#comment-587
Sub M_snbSortof() ' http://www.snb-vba.eu/VBA_Arraylist_en.html#L_11.3
Dim rngVoll As Range: Set rngVoll = Tabelle3.Range("A1:E10")
Dim snAll() As Variant, Sported() As Variant
Let snAll() = rngVoll.Value
Dim j As Long, jj As Long
With CreateObject("System.Collections.Arraylist")
For j = 1 To UBound(snAll(), 1)
.Add snAll(j, 3)
.Sort
Let Sported() = .ToArray
.Clear
For j = 0 To UBound(Sported())
For jj = 1 To UBound(snAll(), 1)
If snAll(jj, 3) = Sported(j) Then
' Use Range to overcome Array size Limits of Worksheets Functions
'Dim Clm As Range: Set Clm = Application.Index(rngVoll, jj, 0)
' .Add Clm.Value
' .Add (Application.Index(rngVoll, jj, 0).Value)
' Use Cells to overcome Array size Limits of Worksheets Functions
Dim LB As Long, UB As Long '…User Given start and Stop Column as a Number
Let LB = LBound(snAll(), 2): Let UB = UBound(snAll(), 2)
Dim strLtrLB As String, strLtrUB As String '…Column Letter corresponding to Column Number
'There are many ways to get a Column Letter from a Column Number – excelforum.com/tips-and-tutorials/1108643-vba-column-letter-from-column-number-explained.html
Let strLtrLB = Split(Cells(1, LB).Address, "$")(1) 'An Address Method
Let strLtrUB = Replace (Replace(Cells(1, UB).Address, "1", ""), "$", "") 'A Replace Method
'Obtain Column Indicies using Spreadsheet Function Column via VBA Evaluate Method
Let clms() = Evaluate("column(" & strLtrLB & ":" & strLtrUB & ")") 'Returns 1 D “pseudo” Horizontal Array of sequential numbers from column number of LB to UB
'Or
clms() = Evaluate("column(" & Split(Cells(1, LB).Address, "$")(1) & ":" & Replace (Replace(Cells(1, UB).Address, "1", ""), "$", "") & ")")
.Add (Application.Index(Tabelle3.Cells, jj, clms()))
'Let snAll(jj, 3) = ""
Exit For
Next jj
Next j
For j = 0 To .Count - 1
Tabelle3.Cells(j + 1 + 10, 1).Resize(, UBound(snAll, 2)) = .Item(j)
Next j
Sub M_snb()
Dim sn, sp, j As Long, jj As Long
sn = Tabelle3.Range("A1:E10")
For j = 1 To UBound(sn)
.Add sn(j, 3)
.Sort
sp = .ToArray
.Clear
For j = 0 To UBound(sp)
For jj = 1 To UBound(sn)
If sn(jj, 3) = sp(j) Then
.Add Application.Index(sn, jj)
sn(jj, 3) = ""
Exit For
Tabelle3.Cells((j + 1) + 10, 1).Resize(, UBound(sn, 2)) = .Item(j)
'Rem Ref
' http://www.excelforum.com/excel-programming-vba-macros/1139207-how-to-move-a-userform-and-module-from-one-book-to-another-2.html
' http://www.excelforum.com/excel-programming-vba-macros/1138300-vba-userform-value-check-if-user-form-buttons-checked-not-working-check-button-on-open.html
' http://www.excelforum.com/excel-programming-vba-macros/1139742-workbooks_open-crashes-when-file-opened-with-code-manually-open-ok-userform-issue.html
' http://www.excelfox.com/forum/showthread.php/2130-Sort-an-array-based-on-another-array-VBA?p=9985#post9985
' http://www.excelforum.com/showthread.php?t=1154829&page=4#post4502593
' http://www.excelforum.com/excel-programming-vba-macros/1160648-how-to-create-a-pop-up-notification-for-two-different-conditions-at-the-same-time.html#post4507157
http://www.excelforum.com/showthread...=4#post4502593
Second Code for Nelson using Admin Formula Idea
Second Code for nelson
Post 9
http://www.excelfox.com/forum/showth...0070#post10070
Sub IJAdjustKAddTotalAllWorksheet() ' http://www.excelfox.com/forum/showthread.php/2144-Code-Required-to-calculate-number-of-days-worked-normal-overtime-and-holiday-overtime?p=10060#post10060
Rem 1) Workbooks Info.
Dim Wb As Workbook ' Dim: For Object variabls: Address location to a "pointer". That has all the actual memory locations (addresses) of the various property values , and it holds all the instructions what / how to change them , should that be wanted later. That helped explain what occurs when passing an Object to a Call ed Fucntion or Sub Routine By Val ue. In such an occurance, VBA actually passes a copy of the pointer. So that has the effect of when you change things like properties on the local variable , then the changes are reflected in changes in the original object. (The copy pointer instructs how to change those values, at the actual address held in that pointer). That would normally be the sort of thing you would expect from passing by Ref erence. But as that copy pointer "dies" after the called routine ends, then any changes to the Addresses of the Object Properties in the local variable will not be reflected in the original pointer. So you cannot actually change the pointer.)
Set Wb = ActiveWorkbook ' Set: Fill or partially Fill: Setting to a Class will involve the use of an extra New at this code line. I will then have an Object referred to as an instance of a Class. At this point I include information on my Pointer Pigeon hole for a distinct distinguishable usage of an Object of the Class. For the case of something such as a Workbook this instancing has already been done, and in addition some values are filled in specific memory locations which are also held as part of the information in the Pigeon Hole Pointer. We will have a different Pointer for each instance. In most excel versions we already have a few instances of Worksheets. Such instances Objects can be further used., - For this a Dim to the class will be necessary, but the New must be omitted at Set. I can assign as many variables that I wish to the same existing instance
Dim wsStear As Worksheet ' Used for each Worksheet counting Tabs from left from 1 To Total
Rem 2) varables for some totals ;)
Const TDays As Long = 30 'Total days just taken as 30 ' Long is very simple to handle, - final memory "size" type is known (123.456 and 000.001 have same "size" computer memory ) , and so a Address suggestion can be given for the next line when the variable is filled in. '( Long is a Big whole Number limit (-2,147,483,648 to 2,147,483,647) If you need some sort of validation the value should only be within the range of a Byte/Integer otherwise there's no point using anything but Long.--upon/after 32-bit, Integers (Short) need converted internally anyways, so a Long is actually faster. )
Dim Dte As Date, DteNo As Long ' I am hoping Dte will sort out getting a date in a format that I can use the Weekday function to see what week day it is and get that as a nuumber to check for..
Rem 3) Loop through worksheets and give some Totals
Dim Cnt As Long ' Loop Bound variable count for going through all worksheets
'3a) main Loop start=====================================================
For Cnt = 1 To Wb.Worksheets.Count ' The Worksheets collection Object Property returns the number of worksheet items in the Workbook
Set wsStear = Wb.Worksheets.Item(Cnt) ' At each loop the variable is set to the current Worksheet counting from the Cnt'ths tab from left
Dim lr As Long ' Used for last row number in column E
Let lr = wsStear.Range("E" & Rows.Count & "").End(xlUp).Row ' The Range Object ( cell ) that is the last cell in the column of interest (CHOOSE a column typically that will always have a last Entry in any Data) ,( Row Number given by .Count Property applied to ( any Worksheet would do, so leaving unqualified is OK here, ) Spreadsheet Range Rows Property) has the Property .End ( argument "Looking back up" ) appled to it. This Returns a new Range ( cell ) object which is that of the first Range ( cell ) with something in it "looking back up" in the XL spreadsheet from that last Cell. Then the .Row Property is applied to return a long number equal to the Row number of that cell: Rows.Count is the very last row number in your Worksheet. It is different for earlier versions of Excel. The End(xlUp) is the same as pressing a Ctrl+UpArrow key combination. The final ".Row" returns the row where the cursor stops after moving up.
Dim FstDtaCel As Range: Set FstDtaCel = wsStear.Range("A1") ' Worksheets Range(" ") Property used to return Range object of first cell in second row
'3b) Data arrays from worksheet. We need columns E H I J .... Date ( Column E ) and Total hrs ( Column H ) are required to use in calculations
Dim arrInNorm() As Variant, arrInOver() As Variant ' In the next lines the .Value2 or .value Property is applied a Range object which presents the Value or Value2 value or values in a single variable of appropriate type or a field of member Elements of varaint types.We are expecting the latter, so declare ( Dim ) a dynamic Array variable appropriately. It must be dynamic as its size will be defined at that assignment
Let arrInNorm() = FstDtaCel.Offset(0, 8).Resize(lr, 1).Value2 ' I ' Normal Hrs ( Column I ) are needed as they must be set to zero for Holy ?? Holidays ?? Friday ??
Let arrInOver() = FstDtaCel.Offset(0, 9).Resize(lr, 1).Value2 ' J ' Overtime ( Column J ) is needed as it will be changed and then used in calculations
Dim arrTotHrs() As Variant ' ,' ## ' arrDteClr() As Variant
Let arrTotHrs() = FstDtaCel.Offset(0, 7).Resize(lr, 1).Value ' H ' ' One thing you pick up when learning VBA programming is that referring to cells from one to another via an offset is both fundamental and efficient. That makes sense as Excel is all about using the offsets mentioned above. So like if you use them you can “cut out the middle man”. ( The middle man here might be considered as, for example, in VBA, using extra variables for different Range objects: A fundamental thing to do with any cell ( or strictly speaking the Range object associated to a cell ) is the Range Item Property of any range Object, through which you can “get at” any other Range object. http://www.excelforum.com/showthread.php?t=1154829&page=13&p=4563838&highlight=#post4563838 ( It is often quicker than using a separate variable for each Range object – probably as all the variable does is hold the offset , so you might as well use the offset in the first place.. )
' Similarly Another thing you pick up along the way is that the cells ( or strictly speaking the Range objects associated with it ) can be organised into groups of cells which then are also called Range objects and are organised in their constituent parts exactly the same as for the single cell Range object. Once again this is all an indication of organising so that we get at information by sliding along a specific amount ( offset value). The Offset and Resize properties therefore return a new range object. I use the .Value 2 here as i seemed to get it for .Value anyway, not sure why yet, - so i thought be on the safe side , get it always and work somehow with that for now and convert as necerssary. Also 1 breadth Arrays due to Alan Intercept theory are held in such a ways as to be very effient in usage of values within
Dim arrK() As String 'I know the size, but must make it dynamic as Dim declaration only takes numbers, and so I use ReDim method below wehich can also take variables or formulas
ReDim arrK(1 To UBound(arrInNorm(), 1), 1 To 1) ' Any array first dimension ("row") will do
'This will not work. ' ## ' Let arrDteClr() = FstDtaCel.Offset(0, 4).Resize(lr, 1).Interior.Color ' because .Interior property for a Range object shows only one value for the entire range which seems to be zero unless all the cells have a colour
Dim arrDteClr() As Double, rngDts As Range
Set rngDts = FstDtaCel.Offset(0, 4).Resize(lr, 1)
Dim Rws As Long: ReDim arrDteClr(1 To lr, 1 To 1) ' so must loop in each Interior color value
For Rws = 1 To UBound(arrDteClr(), 1) Step 1 'InnerLoop for dates background colors
Let arrDteClr(Rws, 1) = rngDts.Item(Rws, "A").Interior.Color
Next Rws
'3c) Inner loop for rows
Dim ShtCnt As Long ' Loop Bound Variable Count for hours columns looping
For ShtCnt = 1 To UBound(arrDteClr(), 1) Step 1 '------------------- For "rows" in data arrays
'3d) We need to check Interior color Adjust columns I and J so that column I has no hours for holiday day and total hours goes to over time hours with criteria 9 or less than 9 hrs all total hours added overtime, 10 or above 10 hrs one hour deducted from total hours and added to column J ..... and add a H or N in helper column K
If arrDteClr(ShtCnt, 1) = 65535 Then
If (arrTotHrs(ShtCnt, 1) * 24) <= 9 Then '(i) If Total Hrs are less than or equal to 9 ,Then all Total Hrs are added to Overtime Hrs
Let arrInOver(ShtCnt, 1) = arrTotHrs(ShtCnt, 1) ' Given To ' Added to arrInOver(ShtCnt, 1) + arrTotHrs(ShtCnt, 1)
ElseIf (arrTotHrs(ShtCnt, 1) * 24) > 9 Then ' (ii) If Total Hrs are less greater than 9 , Then ( Total Hrs - 1 ) are added to Overtime Hrs
Let arrInOver(ShtCnt, 1) = arrTotHrs(ShtCnt, 1) - 1 / 24 ' Given To ' arrInOver(ShtCnt, 1) + arrTotHrs(ShtCnt, 1) - 1 / 24 'Added to 1 hr less overtime for more than 9 hrs worked
Let arrInNorm(ShtCnt, 1) = Empty ' (iii) As array is variant type can empty Remove normal Hrs Array for(Column I) is then set tom zerow for this "row"o
Let arrK(ShtCnt, 1) = "H" ' Give string, "" value of H for Holiday in Admin's help column K
Else ' No Holy Holiday
Let arrK(ShtCnt, 1) = "N" ' give string N for normal
'3e) ' from last code, is not now used to calculate totals
Next ShtCnt '--------------------------End Inner loop for rows-----
'3f) Paste out final Totals and days to current Worksheet
Let wsStear.Range("G35").Value = "=SUMIF(K1:K" & lr & ",""N"",J1:J" & lr & ")*24"
Let wsStear.Range("J35").Value = "=SUMIF(K1:K" & lr & ",""H"",J1:J" & lr & ")*24"
Let wsStear.Range("C34").Value = TDays ' The constant value of Total days is simply added to cell C34
'3g) Normal Hrs ( Column I ) and Overtime Hrs ( Column J ) are changed ' And can paste out help column if you like
Let FstDtaCel.Offset(0, 9).Resize(lr, 1).Value2 = arrInOver() ' J ' The required spreadsheet cells range has its Range Object .Value2 values filled an allowed direct assignment to an array of values
Let FstDtaCel.Offset(0, 8).Resize(lr, 1).Value2 = arrInNorm() ' I
Let FstDtaCel.Offset(0, 10).Resize(lr, 1).Value2 = arrK() ' K
Next Cnt '==End main Loop==============================================
Post 22 Before ( BB Code )
http://www.excelfox.com/forum/showth...0090#post10090
| Row\Col |
C |
D |
E |
F |
G |
H |
I |
J |
1 |
121 |
TEAM LEADER |
21.Dec.16 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
2 |
121 |
TEAM LEADER |
22.Dec.16 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
3 |
121 |
TEAM LEADER |
23.Dec.16 |
7:00 |
15:00 |
8:00 |
9:00 |
0:00 |
4 |
121 |
TEAM LEADER |
24.Dec.16 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
5 |
121 |
TEAM LEADER |
25.Dec.16 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
6 |
121 |
TEAM LEADER |
26.Dec.16 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
7 |
121 |
TEAM LEADER |
27.Dec.16 |
7:00 |
17:00 |
10:00 |
9:00 |
1:00 |
8 |
121 |
TEAM LEADER |
28.Dec.16 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
9 |
29.Dec.16 |
10 |
30.Dec.16 |
11 |
31.Dec.16 |
12 |
121 |
TEAM LEADER |
1.Jan.17 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
13 |
121 |
TEAM LEADER |
2.Jan.17 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
14 |
121 |
TEAM LEADER |
3.Jan.17 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
15 |
121 |
TEAM LEADER |
4.Jan.17 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
16 |
121 |
TEAM LEADER |
5.Jan.17 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
17 |
121 |
TEAM LEADER |
6.Jan.17 |
18 |
121 |
TEAM LEADER |
7.Jan.17 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
19 |
121 |
TEAM LEADER |
8.Jan.17 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
20 |
121 |
TEAM LEADER |
9.Jan.17 |
21 |
121 |
TEAM LEADER |
10.Jan.17 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
22 |
121 |
TEAM LEADER |
11.Jan.17 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
23 |
121 |
TEAM LEADER |
12.Jan.17 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
24 |
121 |
TEAM LEADER |
13.Jan.17 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
25 |
121 |
TEAM LEADER |
14.Jan.17 |
7:30 |
17:30 |
10:00 |
9:00 |
1:00 |
26 |
121 |
TEAM LEADER |
15.Jan.17 |
7:30 |
17:30 |
10:00 |
9:00 |
1:00 |
27 |
121 |
TEAM LEADER |
16.Jan.17 |
7:30 |
17:30 |
10:00 |
9:00 |
1:00 |
28 |
121 |
TEAM LEADER |
17.Jan.17 |
7:30 |
17:30 |
10:00 |
9:00 |
1:00 |
29 |
121 |
TEAM LEADER |
18.Jan.17 |
7:00 |
18:00 |
11:00 |
9:00 |
2:00 |
30 |
19.Jan.17 |
31 |
121 |
TEAM LEADER |
20.Jan.17 |
32 |
33 |
34 |
Normal Overtime -----> |
Holiday Overtime -----> |
Worksheet: Post22Before121
HTML After using Sub IJAdjust_LAdd_AbsentKAdd_TotalsFormulas_AllWorkshe etsCode4()
After from running code (HTML) :
<b>Excel 2007 32 bit</b><table cellpadding="2.5px" rules="all" style=";background-color: #FFFFFF;border: 1px solid;border-collapse: collapse; border-color: #A6AAB6"><colgroup><col width="25px" style="background-color: #E0E0F0" /><col /><col /><col /><col /><col /><col /><col /><col /><col /></colgroup><thead><tr style=" background-color: #E0E0F0;text-align: center;color: #161120"><th></th><th>D</th><th>E</th><th>F</th><th>G</th><th>H</th><th>I</th><th>J</th><th>K</th><th>L</th></tr></thead><tbody><tr ><td style="color: #161120;text-align: center;">1</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">21.Dec.16</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">2</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">22.Dec.16</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">3</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;background-color: #FFFF00;;">23.Dec.16</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">15:00</td><td style="text-align: right;;">8:00</td><td style="text-align: right;;"></td><td style="text-align: right;;">8:00</td><td style="text-align: right;;"></td><td style=";">H</td></tr><tr ><td style="color: #161120;text-align: center;">4</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">24.Dec.16</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">5</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">25.Dec.16</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">6</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">26.Dec.16</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">7</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">27.Dec.16</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">17:00</td><td style="text-align: right;;">10:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">1:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">8</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">28.Dec.16</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">9</td><td style="text-align: right;;"></td><td style="font-weight: bold;text-align: right;;">29.Dec.16</td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style=";">ABSENT</td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">10</td><td style="text-align: right;;"></td><td style="font-weight: bold;text-align: right;background-color: #FFFF00;;">30.Dec.16</td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style=";">ABSENT</td><td style="text-align: right;;"></td></tr><tr ><td style="color: #161120;text-align: center;">11</td><td style="text-align: right;;"></td><td style="font-weight: bold;text-align: right;;">31.Dec.16</td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style=";">ABSENT</td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">12</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">1.Jan.17</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">13</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">2.Jan.17</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">14</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">3.Jan.17</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">15</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">4.Jan.17</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">16</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">5.Jan.17</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">17</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;background-color: #FFFF00;;">6.Jan.17</td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style=";">H</td></tr><tr ><td style="color: #161120;text-align: center;">18</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">7.Jan.17</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">19</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">8.Jan.17</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">20</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">9.Jan.17</td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style=";">ABSENT</td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">21</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">10.Jan.17</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">22</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">11.Jan.17</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">23</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">12.Jan.17</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">24</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;background-color: #FFFF00;;">13.Jan.17</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;"></td><td style="text-align: right;;">10:00</td><td style="text-align: right;;"></td><td style=";">H</td></tr><tr ><td style="color: #161120;text-align: center;">25</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">14.Jan.17</td><td style="text-align: right;;">7:30</td><td style="text-align: right;;">17:30</td><td style="text-align: right;;">10:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">1:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">26</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">15.Jan.17</td><td style="text-align: right;;">7:30</td><td style="text-align: right;;">17:30</td><td style="text-align: right;;">10:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">1:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">27</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">16.Jan.17</td><td style="text-align: right;;">7:30</td><td style="text-align: right;;">17:30</td><td style="text-align: right;;">10:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">1:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">28</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">17.Jan.17</td><td style="text-align: right;;">7:30</td><td style="text-align: right;;">17:30</td><td style="text-align: right;;">10:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">1:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">29</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;;">18.Jan.17</td><td style="text-align: right;;">7:00</td><td style="text-align: right;;">18:00</td><td style="text-align: right;;">11:00</td><td style="text-align: right;;">9:00</td><td style="text-align: right;;">2:00</td><td style="text-align: right;;"></td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">30</td><td style="text-align: right;;"></td><td style="font-weight: bold;text-align: right;;">19.Jan.17</td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style=";">ABSENT</td><td style=";">N</td></tr><tr ><td style="color: #161120;text-align: center;">31</td><td style=";">TEAM LEADER</td><td style="font-weight: bold;text-align: right;background-color: #FFFF00;;">20.Jan.17</td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style="text-align: right;;"></td><td style=";">H</td></tr></tbody></table><p style="width:9em;font-weight:bold;margin:0;padding:0.2em 0.6em 0.2em 0.5em;border: 1px solid #A6AAB6;border-top:none;text-align: center;background-color: #E0E0F0;color: #161120">After121</p><br /><br />
Top Part of Code 4 for Nelson
This is the first part of a single code.
The second part shpuld be copied directly under the first part in the same code module
For this Post
' http://www.excelfox.com/forum/showth...iday-overtime?
'10 ' Code 4 for Nelson ' Post 27 http://www.excelfox.com/forum/showthread.php/2144-Code-Required-to-calculate-number-of-days-worked-normal-overtime-and-holiday-overtime?p=10094#post10094
Sub IJAdjust_LAdd_AbsentKAdd_TotalsFormulas_AllWorksheetsCode4() 'http://www.excelfox.com/forum/showthread.php/2144-Code-Required-to-calculate-number-of-days-worked-normal-overtime-and-holiday-overtime?p=10078#post10078
20 Rem 1) Workbooks Info.
30 Dim Wb As Workbook ' Dim: For Object variabls: Address location to a "pointer". That has all the actual memory locations (addresses) of the various property values , and it holds all the instructions what / how to change them , should that be wanted later. That helped explain what occurs when passing an Object to a Call ed Fucntion or Sub Routine By Val ue. In such an occurance, VBA actually passes a copy of the pointer. So that has the effect of when you change things like properties on the local variable , then the changes are reflected in changes in the original object. (The copy pointer instructs how to change those values, at the actual address held in that pointer). That would normally be the sort of thing you would expect from passing by Ref erence. But as that copy pointer "dies" after the called routine ends, then any changes to the Addresses of the Object Properties in the local variable will not be reflected in the original pointer. So you cannot actually change the pointer.)
40 Set Wb = ActiveWorkbook ' Set: Fill or partially Fill: Setting to a Class will involve the use of an extra New at this code line. I will then have an Object referred to as an instance of a Class. At this point I include information on my Pointer Pigeon hole for a distinct distinguishable usage of an Object of the Class. For the case of something such as a Workbook this instancing has already been done, and in addition some values are filled in specific memory locations which are also held as part of the information in the Pigeon Hole Pointer. We will have a different Pointer for each instance. In most excel versions we already have a few instances of Worksheets. Such instances Objects can be further used., - For this a Dim to the class will be necessary, but the New must be omitted at Set. I can assign as many variables that I wish to the same existing instance
50 Dim wsStear As Worksheet ' Used for each Worksheet counting Tabs from left from 1 To Total
60 Rem 2) varables for some totals ;)
70 'Const TDays As Long = 30 'Total days just taken as 30 INITIALLY ' Long is very simple to handle, - final memory "size" type is known (123.456 and 000.001 have same "size" computer memory ) , and so a Address suggestion can be given for the next line when the variable is filled in. '( Long is a Big whole Number limit (-2,147,483,648 to 2,147,483,647) If you need some sort of validation the value should only be within the range of a Byte/Integer otherwise there's no point using anything but Long.--upon/after 32-bit, Integers (Short) need converted internally anyways, so a Long is actually faster. )
80 Dim Dte As Date, DteNo As Long ' I am hoping Dte will sort out getting a date in a format that I can use the Weekday function to see what week day it is and get that as a nuumber to check for..
90 Rem 3) Loop through worksheets and give some Totals
100 Dim Cnt As Long ' Loop Bound variable count for going through all worksheets
110 '3a) main Loop start=====================================================
120 For Cnt = 1 To Wb.Worksheets.Count ' The Worksheets collection Object Property returns the number of worksheet items in the Workbook
130 Set wsStear = Wb.Worksheets.Item(Cnt) ' At each loop the variable is set to the current Worksheet counting from the Cnt'ths tab from left
140 Dim lr As Long ' Used for last row number in column E ( The number of “Entries” is taken as the filled dates in column E )
150 Let lr = wsStear.Range("E" & Rows.Count & "").End(xlUp).Row ' The Range Object ( cell ) that is the last cell in the column of interest (CHOOSE a column typically that will always have a last Entry in any Data) ,( Row Number given by .Count Property applied to ( any Worksheet would do, so leaving unqualified is OK here, ) Spreadsheet Range Rows Property) has the Property .End ( argument "Looking back up" ) appled to it. This Returns a new Range ( cell ) object which is that of the first Range ( cell ) with something in it "looking back up" in the XL spreadsheet from that last Cell. Then the .Row Property is applied to return a long number equal to the Row number of that cell: Rows.Count is the very last row number in your Worksheet. It is different for earlier versions of Excel. The End(xlUp) is the same as pressing a Ctrl+UpArrow key combination. The final ".Row" returns the row where the cursor stops after moving up.
160 'Let lr = 30 ' maybe nelson means thís ? "...For all Month no. of days we take as 30 only..." For all Months, the “TOTAL NO. OF DAYS” ( to be placed in cell C34 ) is not necessarily the number of days worked.
170 Let lr = wsStear.Range("E33").End(xlUp).Row ' To allow text below row 33
180 'TOTAL NO. OF DAYS The formula for calculating this is:
190 ' _Assuming the employee is not Absent for any day, then the “TOTAL NO. OF DAYS” is always taken as 30
200 ' _ If the employee has one or more normal days of absence, ( normal days with no total working hours ), then the formula for calculating “TOTAL NO. OF DAYS” is as follows:
210 ' TOTAL NO. OF DAYS = 30 – ( Count of “ABSENT” )
220 Dim FstDtaCel As Range: Set FstDtaCel = wsStear.Range("A1") 'Top Left data ' Worksheets Range(" ") Property used to return Range object of first cell in second row
230 '3b) Data arrays from worksheet. We need columns E H I J .... Date ( Column E ) and Total hrs ( Column H ) are required to use in calculations
240 Dim arrInNorm() As Variant, arrInOver() As Variant ' In the next lines the .Value2 or .Value "values" Property is applied a Range object which presents the Value or Value2 value or values in a single variable of appropriate type or a field of member Elements of varaint types.We are expecting the latter, so declare ( Dim ) a dynamic Array variable appropriately. It must be dynamic as its size will be defined at that assignment
250 Let arrInNorm() = FstDtaCel.Offset(0, 8).Resize(lr, 1).Value2 ' I ' Normal Hrs ( Column I ) are needed as they must be set to zero for Holy ?? Holidays ?? Friday ??
260 Let arrInOver() = FstDtaCel.Offset(0, 9).Resize(lr, 1).Value2 ' J ' Overtime ( Column J ) is needed as it will be changed and then used in calculations
270 Dim arrTotHrs() As Variant ' ,' ## ' arrDteClr() As Variant
280 Let arrTotHrs() = FstDtaCel.Offset(0, 7).Resize(lr, 1).Value ' H ' ' One thing you pick up when learning VBA programming is that referring to cells from one to another via an offset is both fundamental and efficient. That makes sense as Excel is all about using the offsets mentioned above. So like if you use them you can “cut out the middle man”. ( The middle man here might be considered as, for example, in VBA, using extra variables for different Range objects: A fundamental thing to do with any cell ( or strictly speaking the Range object associated to a cell ) is the Range Item Property of any range Object, through which you can “get at” any other Range object. http://www.excelforum.com/showthread.php?t=1154829&page=13&p=4563838&highlight=#post4563838 ( It is often quicker than using a separate variable for each Range object – probably as all the variable does is hold the offset , so you might as well use the offset in the first place.. )
290 ' Similarly Another thing you pick up along the way is that the cells ( or strictly speaking the Range objects associated with it ) can be organised into groups of cells which then are also called Range objects and are organised in their constituent parts exactly the same as for the single cell Range object. Once again this is all an indication of organising so that we get at information by sliding along a specific amount ( offset value). The Offset and Resize properties therefore return a new range object. I use the .Value 2 here as i seemed to get it for .Value anyway, not sure why yet, - so i thought be on the safe side , get it always and work somehow with that for now and convert as necerssary. Also 1 breadth Arrays due to Alan Intercept theory are held in such a ways as to be very effient in usage of values within
300 'Column L ( help column ) Column L ( help column )
310 ' Nelson has chosen the second code. It puts formulas in cells C34, G34, and J34.
320 ' This requires “H” or “N” to indicate Holiday or Normal working day. This will be written by the code in column L
330 Dim arrL() As String 'I know the size, but must make it dynamic as Dim declaration only takes numbers, and so I use ReDim method below wehich can also take variables or formulas
340 ReDim arrL(1 To UBound(arrInNorm(), 1), 1 To 1) ' Any array first dimension ("row") will do
350 '“ABSENT” “ABSENT” ( to be written in some rows in Column K by the program )
360 ' Count of “ABSENT” is the number of occurrences of ABSENT in column K in the final ( After ) Worksheet “ABSENT” is to be written in some rows of column K by the code under certain criteria.
370 ' ( “ABSENT” is not necessarily the normal working days in which an employee is absent and / or has no total working hours. )
380 ' “ABSENT” is to be written in column K by the code under the following criteria:
390 ' _ For the rows of all normal days when the employee has no working hours, ( days when the employee is absent ), “ABSENT” is to be written in column K.
400 ' _ In addition , should it occur that an employee is absent for both the days before and after a holiday, then for the ( Holiday ) row in between those two days, “ABSENT” is to be written in column K.
410 ' ( No consideration of this ““ABSENT” criteria thereof” is made for the case of a Holiday at the first or last “Entries” )
420 Dim arrAbscentK() As String 'K column to have ABSCENT in for person Absent on not Holiday or Holiday written in K cloumn as ABSENT
430 ReDim arrAbscentK(1 To UBound(arrInNorm(), 1), 1 To 1)
440 'Must Loop to get interior color as this will not work. ' ## ' Let arrDteClr() = FstDtaCel.Offset(0, 4).Resize(lr, 1).Interior.Color ' because .Interior property for a Range object shows only one value for the entire range which seems to be zero unless all the cells have a colour
All Sub Folder and File List from VBA Recursion routine. Explanation and Method Comparisons
Codes required for contribution to , and to be referenced from, this Thread: http://www.excelfox.com/forum/showth...lder-Using-VBA
Theses are
_ the main initial code , ( Sub ( ) ) , used in a two code solution "recursion type" solution for Looping through all Folders and Subfolders and Files , starting from an in initial Folder which is given in this code and passed to the second code,
_ a "recursion type" code. This code successively takes a Folder, looks into its subfolders, and then passes all the subfolders successively to "itself" and repeats the process of then looking into the Sub Folders, and then passes all the subfolders successively to "itself" and repeats the process of then looking into the Sub Folders, and then passes all the subfolders successively to "itself" and repeats the process of then looking into the Sub Folders, …. Etc…..
The codes are discussed in detail at that Thread , starting from this post:
Initial Code to call the recursion code given below
' Dec 2017 For Python Comparison. Tutorial Post: excelforum: Tutorial Post: ExcelFox:
'http://excelpoweruser.blogspot.de/2012/04/looping-through-folders-and-files-in.html http://www.excelforum.com/excel-programming-vba-macros/1126751-get-value-function-loop-through-all-files-in-folder-and-its-subfolders.html#post4316662 http://www.excelfox.com/forum/f5/loop-through-files-in-a-folder-using-vba-1324/
Sub VBADoStuffInFoldersInFolderRecursion() 'Main routine to "Call" the first copy of the second routine, VBALoopThroughEachFolderAndItsFile(
Rem 1A) Some Worksheets and General Variables Info
Dim Ws As Worksheet '_-Dim: Prepares "Pointer" to a "Blue Print" (or Form, Questionaire not yet filled in, a template etc.)"Pigeon Hole" in Memory, sufficient in construction to house a piece of Paper with code text giving the relevant information for the particular Variable Type. VBA is sent to it when it passes it. In a Routine it may be given a particular "Value", or ("Values" for Objects). There instructions say then how to do that and handle(store) that(those). At Dim the created Paper is like a Blue Print that has some empty spaces not yet filled in. A String is a a bit tricky. The Blue Print code line Paper in the Pigeon Hole will allow to note the string Length and an Initial start memory Location. This Location well have to change frequently as strings of different length are assigned. Instructiions will tell how to do this. Theoretically a specilal value vbNullString is set to aid in quich checks.. But..http://www.mrexcel.com/forum/excel-questions/361246-vbnullstring-2.html#post4411
Set Ws = ThisWorkbook.Worksheets.Item(1) 'Worksheets("EFFldr") 'CHANGE TO SUIT YOUR WORKSHEET '_- Set: Fill or partially Fill: Setting to a Class will involve the use of an extra New at this code line. I will then have an Object referred to as an instance of a Class. At this point I include information on my Pointer Pigeon hole for a distinct distinguishable usage of an Object of the Class. For the case of something such as a Workbook this instancing has already been done, and in addition some values are filled in specific memory locations which are also held as part of the information in the Pigeon Hole Pointer. We will have a different Pointer for each instance. In most excel versions we already have a few instances of Worksheets. Such instances Objects can be further used., - For this a Dim to the class will be necessary, but the New must be omitted at Set. I can assign as many variables that I wish to the same existing instance
Ws.Range("B3:F30").ClearContents ' This line only needed for demo code
Dim celTL As Range: Set celTL = Ws.Range("B3") 'Top left of where Listing should go
Rem 2A) Get Folder Info
Dim strWB As String ' "Pointer" to a "Blue Print" (or Form, Questionaire not yet filled in, a template etc.)"Pigeon Hole" in Memory, sufficient in construction to house a piece of Paper with code text giving the relevant information for the particular Variable Type. VBA is sent to it when it passes it. In a Routine it may be given a particular "Value", or ("Values" for Objects). There instructions say then how to do that and handle(store) that(those). At Dim the created Paper is like a Blue Print that has some empty spaces not yet filled in. A String is a a bit tricky. The Blue Print code line Paper in the Pigeon Hole will allow to note the string Length and an Initial start memory Location. This Location well have to change frequently as strings of different length are assigned. Instructiions will tell how to do this. Theoretically a specilal value vbNullString is set to aid in quich checks.. But..http://www.mrexcel.com/forum/excel-questions/361246-vbnullstring-2.html#post44116
Let strWB = ThisWorkbook.Path & "\" & "EileensFldr" ' 'CHANGE TO SUIT if you store the main Folder to be looked through somewhere other than in the same Folder as this workbook in which the codes are in
Rem 3A ) ' FileSystemObject Object
Dim FSO As Object: Set FSO = CreateObject("Scripting.FileSystemObject") 'Late Binding
'Dim FSO As Scripting.FileSystemObject 'Early Binding alternative activate a reference to the Microsoft Scripting Runtime Library ( MSRL ) in the Tools References menu of VB Editor Options.
'Set FSO = New Scripting.FileSystemObject 'Create an Instance of the Class Scripting FileSystemObject
Dim myFolder As Object 'An Object from myFolder, can be an declared as Dim myFolder As Folder also for Early Binding
Set myFolder = FSO.GetFolder(strWB) 'Set the selected Folder to the Object Folder using this Method which takes as arbument the Full String Path
Rem 4A )
Dim rCnt As Long: Let rCnt = 1: Dim CopyNumber1 As Long: Let CopyNumber1 = 1 '"Run progressin ( "down vertical" ) axis ( Row count for output ), "Down Folder chain to the right", The Count of the Copy of the called Procedue, here set to 1 for the first called copy of the second routine, which is done from this Sub( ) . Any subsequent calls of further second routine copies will be made by the current copy as it "freezes" and sets of that next copy
celTL.Value = myFolder.Path: celTL.Offset(0, 1).Value = myFolder.Name: Ws.Columns("A:C").AutoFit 'First output Row
'( -- Rem 5A) )
Call LoopThroughEachFolderAndItsFile(myFolder, celTL, rCnt, CopyNumber1) 'Up until now we just got the initial Folder. Now we go to all sub folders then all subfolders then all subfolders.......
' let Application.ScreenUpdating = True ' If this had been set to False earlier towards the start, as is often done, then the code might run a bit quicker by virtue of not updating the worksheet everytime an entry is made, but it is not really nacerssary unless the number of Files and Folders is massive. Even then it is probably better not to do that so that in the case of an error one has an additional way in the worksheet to see where the code stopped / errored
MsgBox "All Excel Files processed", vbInformation
Ws.Columns("A:H").AutoFit
'Rem 5A) --
_........
_._________________
Second code. Recursion routine
'Rem 5A) --
Sub VBALoopThroughEachFolderAndItsFile(ByVal fldFldr As Object, ByRef celTL As Range, ByRef rCnt As Long, ByVal CopyNumberFroNxtLvl As Long) 'In below function we have a nested loop to iterate each files also
Dim myFldrs As Object ''This is used continuously as the "steering" thing, that is to say each Sub Folder in Folder loops, in loops, in loops......etc ....can be Dim myFldrs As Folder for early bindingDim CopyNumber As Long 'equivalent to clmLvl in Rudis Q code
Let CopyNumber = CopyNumberFroNxtLvl 'This variable is local to the current running or paused copy of this routine.
'5Ab) Doing stuff for current Folder
For Each myFldrs In fldFldr.SubFolders 'SubFolders collection used to get at all Sub Folders
''''''''Doing stuff for each Folder, .. in this example giving '_-
'_- its full path including name : and just Flder Name ' -- *
Let rCnt = rCnt + 1 + 1 ''At each folder we always move down a line, and a dd amm extra line as a space between Folders ( The indication of the "column" or "down" to the right comes from the Copy Number of the Sub Procedure
Let celTL.Cells(rCnt, 1).Value = myFldrs.Path: celTL.Cells(rCnt, CopyNumber).Offset(0, 2).Value = myFldrs.Name ' -- * 'Print out current Folder Path and Name in next free row.
''''''''End doing stuff for each Folder
'5Ac) Doing stuff for current file.
Dim oFile As Object ' ... for early binding can Dim oFile As file
For Each oFile In myFldrs.Files 'Looking at all Files types initially '#####
''''''''Doing Stuff for Each File
' Dim Extension As String: Let Extension = Right(oFile.Name, (Len(oFile.Name) - (InStrRev(oFile.Name, ".")))) 'To get the bit just after the . dot. #####
' If Left(Extension, 3) = "xls" Then 'Check for your required File Type #####
Let rCnt = rCnt + 1
celTL.Cells(rCnt, CopyNumber).Offset(0, 2).Value = oFile.Name ' Do your stuff here
' Dim wkb As Workbook
On Error GoTo ErrHdlr 'In case problem opening file for example
' Set wkb = Workbooks.Open(oFile)
' wkb.Close SaveChanges:=True
' Else 'Do not do stuff for a Bad Extension ' #####
' End If ' #####
''''''''End Doing Sttuff for Each File
NxtoFile: Next oFile ' Spring Point after error handler so as to go on to next File after the File action that errored
Call LoopThroughEachFolderAndItsFile(myFldrs, celTL, rCnt, CopyNumber + 1) 'This is an example of recursion. It is actually very simple once you understand it. But it is just incredibly difficult to put in words. It is basically a Procedure that keeps calling itself as much as necessary as it goes "along", "down", or "to the right" of the Path "roots". Every time it goes off calling itself VBA runs a copy of that Procedure. It "Stacks" all info carefully for each "Copy" Run and continues to do this "drilling" down as far as it must, in this case finding the Next Folder, and then the next Folder in that, then the next Folder in that, then the next Folder in that...I think you get the point! Each time VBA makes a copy of the Routine and you go into that. The calling Routine then "freezes at its current state and all variable keep there values. The "Frozen" Routine then re starts when the copy finishes
Exit Sub 'Normal End for no Errors
Rem 6 ) Error handler section just put here for convenience
ErrHdlr: 'Hopefully we know why we are here, and after informing can continue ( to next file )
MsgBox prompt:="Error " & Err.Description & " with File " & oFile & ""
On Error GoTo -1 'This needs to be done to reset the VBA exceptional error state of being. Otherwise VBA "thinks" Errors are being handeled and will not respond again to the Error handler.
On Error GoTo 0 ' Swiches off the current error handler. I do not really need to do this. But it is good practice so the error handler is only in place at the point where i next am expecting an error
GoTo NxtoFile
_..
( Codes are also in the first Worksheet Code module of this Workbook: ( '== ' Dec 2017 For Python Comparison. https://app.box.com/s/gfuintgifu1hgw5nap3jriz2x8mp911x ) )
Dumping Logs. Recurring Excample
Dumping Logs for support of this Thread Post:
http://www.excelfox.com/forum/showth...0476#post10476
Test Function used to produce the Log below
'Going a HoldYaBackCalledYaBackClapTrapRuc - Copy number_GlobinalCntChopsLog - a few copies of this are made and run. (Recursion)
'_-=Rem 4===================??? Got me hook lochprocedue in my code , 5 times simple run then another + 29 new copies of it are run = 5+30=35 times in total calling it it a few times http://www.excelfox.com/forum/showthread.php/1324-Loop-Through-Files-In-A-Folder-Using-VBA#post10421 .... wanking myself up and down a few times
Private Function HoldYaBackCalledYaBackClapTrapRuc(ByVal lMsg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long ' ByVal CopyNumberFroNxtLvl As Long) As Long
Let GlobinalCntChopsLog = GlobinalCntChopsLog + 1: Debug.Print " Going a HoldYaBackCalledYaBackClapTrapRuc"; GlobinalCntChopsLog; "(1Msg"; lMsg; ", wParam"; wParam; ", lParam"; lParam; ") Function Copy Number_"; GlobinalCntChopsLog
'If GlobinalCntChopsLog = 2 Then Let GlobinalCntChopsLog = GlobinalCntChopsLog - 1: UnHookWindowsHookCodEx hHookTrapCrapNumber: Exit Function
If lMsg = 5 Then '_-.... ( Hook type: HCBT_ACTIVATE = 5 but not here?) ... this runs a further 29 copies of HoldYaBackCalledYaBackClapTrap all coming here, so 30 times in total
Debug.Print "Expose Interface"; Tab(30); GlobinalCntChopsLog
SetWindowPosition wParam, 0, poX, pussY, 400, 150, 40 ' SWP_NOZORDER is 4 .. but not here?? 'SWP_NOSIZE + SWP_NOZORDER ' Pull the Chainge position ...
UnHookWindowsHookCodEx hHookTrapCrapNumber ' Release the Hook 30 times this is done
Debug.Print "No InterOfCourse"; Tab(30); GlobinalCntChopsLog; Tab(50); hHookTrapCrapNumber
End If ' 5 times here then '_-....
Debug.Print "Wipe chain WRap"; Tab(30); GlobinalCntChopsLog; Tab(50); hHookTrapCrapNumber
Let HoldYaBackCalledYaBackClapTrapRuc = 0 ' Done 5+30=35 times in total '0 (or False) makes it work, all other numbers and I get no Message box
End Function ' HoldYaBackCalledYaBackClapTrapRuc
MutsNuts AkaApi working ApplicationPromptToRangeInputBox
Select Range
OK
WndNumber 66770 HandleWndOfMyParent 983700 hWndDskTop 66204 hHookTrapCrapNumber
State of Much Such Penialtration's Number HookCodeXcretion's
================== AliAs Pull of my chain AliAs my long Hook
Going a HoldYaBackCalledYaBackClapTrapRuc 1 (1Msg 3 , wParam 2623104 , lParam 2353392 ) Function Copy Number_ 1
No InterOfCourse 1 276039693
Wipe chain WRap 1 276039693
Going a HoldYaBackCalledYaBackClapTrapRuc 1 (1Msg 3 , wParam 1377832 , lParam 2353500 ) Function Copy Number_ 1
Going a HoldYaBackCalledYaBackClapTrapRuc 1 (1Msg 3 , wParam 3934358 , lParam 2353500 ) Function Copy Number_ 1
Going a HoldYaBackCalledYaBackClapTrapRuc 1 (1Msg 3 , wParam 984706 , lParam 2353480 ) Function Copy Number_ 1
Going a HoldYaBackCalledYaBackClapTrapRuc 1 (1Msg 9 , wParam 3934358 , lParam 66766 ) Function Copy Number_ 1
Going a HoldYaBackCalledYaBackClapTrapRuc 1 (1Msg 5 , wParam 2623104 , lParam 2353812 ) Function Copy Number_ 1
Expose Interface 1
Going a HoldYaBackCalledYaBackClapTrapRuc 2 (1Msg 5 , wParam 2623104 , lParam 2353500 ) Function Copy Number_ 2
Expose Interface 2
Going a HoldYaBackCalledYaBackClapTrapRuc 3 (1Msg 5 , wParam 2623104 , lParam 2353188 ) Function Copy Number_ 3
Expose Interface 3
Going a HoldYaBackCalledYaBackClapTrapRuc 4 (1Msg 5 , wParam 2623104 , lParam 2352876 ) Function Copy Number_ 4
Expose Interface 4
Going a HoldYaBackCalledYaBackClapTrapRuc 5 (1Msg 5 , wParam 2623104 , lParam 2352564 ) Function Copy Number_ 5
Expose Interface 5
Going a HoldYaBackCalledYaBackClapTrapRuc 6 (1Msg 5 , wParam 2623104 , lParam 2352252 ) Function Copy Number_ 6
Expose Interface 6
Going a HoldYaBackCalledYaBackClapTrapRuc 7 (1Msg 5 , wParam 2623104 , lParam 2351940 ) Function Copy Number_ 7
Expose Interface 7
Going a HoldYaBackCalledYaBackClapTrapRuc 8 (1Msg 5 , wParam 2623104 , lParam 2351628 ) Function Copy Number_ 8
Expose Interface 8
Going a HoldYaBackCalledYaBackClapTrapRuc 9 (1Msg 5 , wParam 2623104 , lParam 2351316 ) Function Copy Number_ 9
Expose Interface 9
Going a HoldYaBackCalledYaBackClapTrapRuc 10 (1Msg 5 , wParam 2623104 , lParam 2351004 ) Function Copy Number_ 10
Expose Interface 10
Going a HoldYaBackCalledYaBackClapTrapRuc 11 (1Msg 5 , wParam 2623104 , lParam 2350692 ) Function Copy Number_ 11
Expose Interface 11
Going a HoldYaBackCalledYaBackClapTrapRuc 12 (1Msg 5 , wParam 2623104 , lParam 2350380 ) Function Copy Number_ 12
Expose Interface 12
Going a HoldYaBackCalledYaBackClapTrapRuc 13 (1Msg 5 , wParam 2623104 , lParam 2350068 ) Function Copy Number_ 13
Expose Interface 13
Going a HoldYaBackCalledYaBackClapTrapRuc 14 (1Msg 5 , wParam 2623104 , lParam 2349756 ) Function Copy Number_ 14
Expose Interface 14
Going a HoldYaBackCalledYaBackClapTrapRuc 15 (1Msg 5 , wParam 2623104 , lParam 2349444 ) Function Copy Number_ 15
Expose Interface 15
Going a HoldYaBackCalledYaBackClapTrapRuc 16 (1Msg 5 , wParam 2623104 , lParam 2349132 ) Function Copy Number_ 16
Expose Interface 16
Going a HoldYaBackCalledYaBackClapTrapRuc 17 (1Msg 5 , wParam 2623104 , lParam 2348820 ) Function Copy Number_ 17
Expose Interface 17
Going a HoldYaBackCalledYaBackClapTrapRuc 18 (1Msg 5 , wParam 2623104 , lParam 2348508 ) Function Copy Number_ 18
Expose Interface 18
Going a HoldYaBackCalledYaBackClapTrapRuc 19 (1Msg 5 , wParam 2623104 , lParam 2348196 ) Function Copy Number_ 19
Expose Interface 19
Going a HoldYaBackCalledYaBackClapTrapRuc 20 (1Msg 5 , wParam 2623104 , lParam 2347884 ) Function Copy Number_ 20
Expose Interface 20
Going a HoldYaBackCalledYaBackClapTrapRuc 21 (1Msg 5 , wParam 2623104 , lParam 2347572 ) Function Copy Number_ 21
Expose Interface 21
Going a HoldYaBackCalledYaBackClapTrapRuc 22 (1Msg 5 , wParam 2623104 , lParam 2347260 ) Function Copy Number_ 22
Expose Interface 22
Going a HoldYaBackCalledYaBackClapTrapRuc 23 (1Msg 5 , wParam 2623104 , lParam 2346948 ) Function Copy Number_ 23
Expose Interface 23
Going a HoldYaBackCalledYaBackClapTrapRuc 24 (1Msg 5 , wParam 2623104 , lParam 2346636 ) Function Copy Number_ 24
Expose Interface 24
Going a HoldYaBackCalledYaBackClapTrapRuc 25 (1Msg 5 , wParam 2623104 , lParam 2346324 ) Function Copy Number_ 25
Expose Interface 25
Going a HoldYaBackCalledYaBackClapTrapRuc 26 (1Msg 5 , wParam 2623104 , lParam 2346012 ) Function Copy Number_ 26
Expose Interface 26
Going a HoldYaBackCalledYaBackClapTrapRuc 27 (1Msg 5 , wParam 2623104 , lParam 2345700 ) Function Copy Number_ 27
Expose Interface 27
Going a HoldYaBackCalledYaBackClapTrapRuc 28 (1Msg 5 , wParam 2623104 , lParam 2345388 ) Function Copy Number_ 28
Expose Interface 28
Going a HoldYaBackCalledYaBackClapTrapRuc 29 (1Msg 5 , wParam 2623104 , lParam 2345076 ) Function Copy Number_ 29
Expose Interface 29
Going a HoldYaBackCalledYaBackClapTrapRuc 30 (1Msg 5 , wParam 2623104 , lParam 2344764 ) Function Copy Number_ 30
Expose Interface 30
Wipe chain WRap 30 276039693
Wipe chain WRap 29 276039693
Wipe chain WRap 28 276039693
Wipe chain WRap 27 276039693
Wipe chain WRap 26 276039693
Wipe chain WRap 25 276039693
Wipe chain WRap 24 276039693
Wipe chain WRap 23 276039693
Wipe chain WRap 22 276039693
Wipe chain WRap 21 276039693
Wipe chain WRap 20 276039693
Wipe chain WRap 19 276039693
Wipe chain WRap 18 276039693
Wipe chain WRap 17 276039693
Wipe chain WRap 16 276039693
Wipe chain WRap 15 276039693
Wipe chain WRap 14 276039693
Wipe chain WRap 13 276039693
Wipe chain WRap 12 276039693
Wipe chain WRap 11 276039693
Wipe chain WRap 10 276039693
Wipe chain WRap 9 276039693
Wipe chain WRap 8 276039693
Wipe chain WRap 7 276039693
Wipe chain WRap 6 276039693
Wipe chain WRap 5 276039693
Wipe chain WRap 4 276039693
Wipe chain WRap 3 276039693
Wipe chain WRap 2 276039693
_-.__________________________________
Windows Handleing Info:
' 1b) To hang in the Excel Window malking it effectively a Excel Msgbox... Normally if I did not do this ... don't do this .. that is to say leave it at 0 , specifically no window is 0 , and it "hanging in mid air so isn't even if it is imaginatively speaking
Public Declare Function FindWndNumber Lib "user32" Alias "FindWindowA" (Optional ByVal lpClassName As String, Optional ByVal lpWindowName As String) As Long
Dim HandleWndOfMyParent As Long ' I wanted to comment this 1b)(i) and ( 1b(ii) later ) out to leave it hanging in mid air in a virtual inadvirtual not thereness ... but somehow this complicated hook stuff does hang it somwhere but not in my Excel Window but I don't know what my parent's fart has to do with anything
' 1d) For some Misc experiments
Private Declare Function FindWindowExtremeNutty Lib "user32" Alias "FindWindowExA" (ByVal hWnd1 As Long, ByVal hWnd2 As Long, ByVal lpsz1 As String, ByVal lpsz2 As String) As Long
Dim WndNumber As Long, hWndDskTop As Long
Sub AkaApiApplicationPromptToRangeInputBox() ' This one works.. but HTF
' 1b(ii) This section is some how over written in / by the section part or some strange Addressing of HoldYaBackCalledYaBackClapTrap
Let WndNumber = FindWndNumber(lpClassName:=vbNullString, lpWindowName:=vbNullString)
Let HandleWndOfMyParent = FindWndNumber(lpClassName:="XLMAIN", lpWindowName:=vbNullString) ' This is a case where vbNullstring is important - that signifies that I am not giving it, which i do not have to. The second option is a bit flaky and does not often work. it certainly won't work if you make it "" as that is a specific string of zero. Null is a special idea in computing of not set yet / not defined - that is required if I do not want to give it
' 1d) Just some experiments, I forgot why as my brain has goine comfortably numb
Dim HeavyWindBreak As Long: Let HeavyWindBreak = HandleWndOfMyParent
Let hWndDskTop = FindWindowExtremeNutty(HandleWndOfMyParent, 0&, "XLDESK", vbNullString)
Debug.Print "WndNumber"; WndNumber; " HandleWndOfMyParent"; HandleWndOfMyParent; " hWndDskTop"; hWndDskTop; " hHookTrapCrapNumber"
Rem 3 Mess with me hook? God knows what this all does and it seems to make no difference if the proXYs poX or pussY are before or after SetWindowsHooksExample
complete-page-numbers elided to non elided wonkie poos
Code solution for this Thread
http://www.excelfox.com/forum/showth...e-page-numbers
https://www.excelforum.com/excel-pro...d-numbers.html
Sub Moshe() ' http://www.excelfox.com/forum/showthread.php/2229-complete-page-numbers
Rem 1 Make array for holding inoput data and output data - ' Input data can be handled as simple text so Array work is satisfactory
Dim arrIn() As Variant ' We know the data type can be taken as string, but I want to get the data quickly in a spreadsheet "capture" type way, using the .Value Property applied to a range object which returns a field of values for more than 1 cell returns a field of values held in Variant types, - so the type must be variant or a type mismatch runtime error will occcur
Let arrIn() = Range("A1:A" & Range("A1").CurrentRegion.Rows.Count & "").Value
Dim arrOut() As String: ReDim arrOut(1 To UBound(arrIn())) ' I can use string type to suit my final data. I also know the array size, but I must make the array a dynamic ( unknown size ) type as the Dim declare statement will only take actual numbers, but I determine my size from the size of the input array by UBound(arrIn()) : the ReDim method will accept the UBound(arrIn()) , wheras the Dim declaration syntax will not accept this, as the Dim is done at complie and not runtime
Rem 2 Effectively looping for each data row
Dim Cnt As Long ' For going through each "row"
For Cnt = 1 To UBound(arrIn()) ' Going through each element in arrIn()
'2a) split the data in a cell into an array of data. The VBA strings collection split function will return a 1 dimentsional array of string types starting at indicie 0
Dim spltEnt() As String ' For the string row split into each number entry, in other words an array of the data in a cell
If InStr(1, arrIn(Cnt, 1), ", ", vbBinaryCompare) <> 0 Then ' case more than 1 entry in cell. starting at the first character , in the current Cnt array element , I look for ", " , stipulating an excact computer match search type This Function will return eitheer the position counting from the left that it finds the first ", " or it will return 0 if it does not find at least one occurance of the ", "
Let spltEnt() = VBA.Strings.Split(arrIn(Cnt, 1), ", ", -1, vbBinaryCompare) ' we now have a number or number pair
Else ' case a single entry I cannot split by a ", " as i don't have any, ...
ReDim spltEnt(0): Let spltEnt(0) = arrIn(Cnt, 1) ' ... so i just make a single element array and put the single element in it
'2b) working through each data part in a cell
Dim strOut As String 'String in each "row" '_-"Pointer" to a "Blue Print" (or Form, Questionaire not yet filled in, a template etc.)"Pigeon Hole" in Memory, sufficient in construction to house a piece of Paper with code text giving the relevant information for the particular Variable Type. VBA is sent to it when it passes it. In a Routine it may be given a particular "Value", or ("Values" for Objects). There instructions say then how to do that and handle(store) that(those). At Dim the created Paper is like a Blue Print that has some empty spaces not yet filled in. A String is a a bit tricky. The Blue Print code line Paper in the Pigeon Hole will allow to note the string Length and an Initial start memory Location. This Location well have to change frequently as strings of different length are assigned. Instructiions will tell how to do this. Theoretically a specilal value vbNullString is set to aid in quich checks.. But..http://www.mrexcel.com/forum/excel-questions/361246-vbnullstring-2.html#post44116
Dim CntX As Long ' '_-Long is very simple to handle, - final memory "size" type is known (123.456 and 000.001 have same "size" computer memory ) , and so a Address suggestion can be given for the next line when the variable is filled in. '( Long is a Big whole Number limit (-2,147,483,648 to 2,147,483,647) If you need some sort of validation the value should only be within the range of a Byte/Integer otherwise there's no point using anything but Long.--upon/after 32-bit, Integers (Short) need converted internally anyways, so a Long is actually faster. ) https://www.mrexcel.com/forum/excel-questions/803662-byte-backward-loop-4.html
For CntX = 0 To UBound(spltEnt()) ' for going through each entry in a row in other words for going through each piece of data in a cell
'2c)(i) case just data for a single page
If InStr(1, spltEnt(CntX), "-", vbBinaryCompare) = 0 Then ' case of no "-"
Let strOut = strOut & spltEnt(CntX) & ", " ' just the single number goes in the output string, strOut
Else ' we have a "-"
Dim NmbrPear() As String ' this will be am Array of 2 elements for each number pair
Let NmbrPear() = VBA.Strings.Split(spltEnt(CntX), "-", -1, vbBinaryCompare)
'2c)(ii) case no correction needed in the data
If Len(NmbrPear(0)) = Len(NmbrPear(1)) Then ' the numbers are the same
Let strOut = strOut & spltEnt(CntX) & ", " ' the same number pair goes in the output string
Else ' from here on, we need to do some adjustment before adding to the output string
'2c)(iii) cases data correction needed
Select Case Len(NmbrPear(0)) - Len(NmbrPear(1)) ' selecting the case of the difference in length of the two parts of the data "FirstNumberPart-SecondNumberPart"
Case 1 ' Like 123-24 or 12345-2345
Let NmbrPear(1) = VBA.Strings.Mid$(NmbrPear(0), 1, 1) & NmbrPear(1) ' like 1 & 24 or 1 & 2345 ' VBA strings collection Mid Function: This returns the part of ( NmbrPear(0) , the starts at character 1 , and has the length of 1 character )
Case 2 ' like 123-4
Let NmbrPear(1) = VBA.Strings.Mid$(NmbrPear(0), 1, 2) & NmbrPear(1) ' like 12 & 4
Case 3 ' like 1234-6
Let NmbrPear(1) = VBA.Strings.Mid$(NmbrPear(0), 1, 3) & NmbrPear(1) ' like 123 & 6
Case 3 ' like 12345-8
Let NmbrPear(1) = VBA.Strings.Mid$(NmbrPear(0), 1, 4) & NmbrPear(1) ' like 1234 & 8
End Select ' at this point we have corrected our second number part from the pair
Let strOut = strOut & VBA.Strings.Join(NmbrPear(), "-") & ", " ' The number pair is rejoined with the corrected second number part before adding the number parts pair to the output string
Next CntX
'2d) The string of corrected data can now be added to the array for output
Let strOut = VBA.Strings.Left$(strOut, Len(strOut) - 2) ' This removes the last unwanted ", " ' 'VBA Strings collection Left function returns a Variant- initially tries to coerces the first parameter into Variant, Left$ does not, that's why Left$ is preferable over Left, it's theoretically slightly more efficient, as it avoids the overhead/inefficieny associated with the Variant. It allows a Null to be returned if a Null is given. https://www.excelforum.com/excel-new...ml#post4084816 .. it is all to do with ya .."Null propagation".. maties ;) '_-.. http://allenbrowne.com/casu-12.html Null is a special "I do not know, / answer unknown" - handy to hav... propogetion wonks - math things like = 1+2+Null returns you null. Or string manipulation stuff like, left(Null returns you Null. Count things like Cnt (x,y,Null) will return 2 - there are two known things there..Hmm - bit iffy although you could argue that Null has not been entered yet.. may never
Let arrOut(Cnt) = strOut ' Finally the string is aded to the current "row" in the outout array
Let strOut = "" ' Empty variable holding a row string for use ijn next loop
Rem 3 I have the final data array, and so umst now paste it out where I want it.
Dim arrClmOut() As String: ReDim arrClmOut(1 To UBound(arrOut), 1 To 1) ' This is for a 1 column 2 Dimensional array which I need for the orientation of my final output
'3(i) a simple loop to fill the transposed array
Dim rCnt As Long '
For rCnt = 1 To UBound(arrOut())
Let arrClmOut(rCnt, 1) = arrOut(rCnt)
Next rCnt
'3(ii) Output to worksheet
Let Range("B1").Resize(UBound(arrOut())).Value = arrClmOut() ' The cell Top left of where the output should go is resized to the required row size, and 1 column. The .Value Property of that range object may have the values in an Array assigned to it in a simpla one line assignment
' http://www.excelfox.com/forum/showthread.php/2157-Re-Defining-multiple-variables-in-VBA?p=10192#post10192
' https://www.excelforum.com/word-programming-vba-macros/1175184-vba-word-repeat-character-in-string-a-number-of-times.html#post4591171
Function CStrSepDbl Excel VBA comma point thousand decimal separator number problem
Code for this Thread:
http://www.excelfox.com/forum/showth...0503#post10503
http://www.excelfox.com/forum/forumd...ips-and-Tricks
Function CStrSepDbl
'10 ' http://www.eileenslounge.com/viewtopic.php?f=27&t=22850#p208624
Function CStrSepDbl(Optional ByVal strNumber As String) As Double ' Return a Double based on a String Input which is asssumed to "Look" like a Number. The code will work for Leading and Trailing zeros, but will not return them. )
20 Rem 0 At the Dim stage a '_-String is "Pointer" to a "Blue Print" (or Form, Questionaire not yet filled in, a template etc.)"Pigeon Hole" in Memory, sufficient in construction to house a piece of Paper with code text giving the relevant information for the particular Variable Type. VBA is sent to it when it passes it. In a Routine it may be given a particular “Value”, or (“Values” for Objects). There instructions say then how to do that and handle(store) that(those). At Dim the created Paper is like a Blue Print that has some empty spaces not yet filled in. A String is a bit tricky. The Blue Print code line Paper in the Pigeon Hole will allow to note the string Length and an Initial start memory Location. This Location well have to change frequently as strings of different length are assigned. Instructiions will tell how to do this. Theoretically a specilal value vbNullString is set to aid in quich checks, But http://www.mrexcel.com/forum/excel-questions/361246-vbnullstring-2.html#post44116
30 If StrPtr(strNumber) = 0 Then Let CStrSepDbl = "9999999999": Exit Function '_- StrPtr(MyVaraibleNotYetUsed)=0 .. http://www.excelfox.com/forum/showthread.php/1828-How-To-React-To-The-Cancel-Button-in-a-VB-(not-Application)-InputBox?p=10463#post10463 https://www.mrexcel.com/forum/excel-questions/35206-test-inputbox-cancel-2.html?highlight=strptr#post2845398 https://www.mrexcel.com/forum/excel-questions/917689-passing-array-class-byval-byref.html#post4412382
40 Rem 1 'Adding a leading zero if no number before a comma or point, change all seperators to comma ,
50 If VBA.Strings.Left$(strNumber, 1) = "," Or VBA.Strings.Left$(strNumber, 1) = "." Then Let strNumber = "0" & strNumber ' case for like .12 or ,7 etc 'VBA Strings collection Left function returns a Variant- initially tries to coerces the first parameter into Variant, Left$ does not, that's why Left$ is preferable over Left, it's theoretically slightly more efficient, as it avoids the overhead/inefficieny associated with the Variant. It allows a Null to be returned if a Null is given. https://www.excelforum.com/excel-new...ml#post4084816 .. it is all to do with ya .."Null propagation".. maties ;) '_-.. http://allenbrowne.com/casu-12.html Null is a special "I do not know, / answer unknown" - handy to hav... propogetion wonks - math things like = 1+2+Null returns you null. Or string manipulation stuff like, left(Null returns you Null. Count things like Cnt (x,y,Null) will return 2 - there are two known things there..Hmm -bit iffy although you could argue that Null has not been entered yet..may never
60 If VBA.Strings.Left$(strNumber, 2) = "-," Or VBA.Strings.Left$(strNumber, 2) = "-." Then Let strNumber = Application.WorksheetFunction.Replace(strNumber, 1, 1, "-0") ' case for like -.12 or -,274 etc
70 Let strNumber = Replace(strNumber, ".", ",", 1, -1, vbBinaryCompare) 'Replace at start any . to a , After this point there should be either no or any amount of ,
80 'Check If a Seperator is present, then MAIN CODE is done
90 If InStr(1, strNumber, ",") > 0 Then 'Check we have at least one seperator, case we have, then..
100 Rem 2 'MAIN CODE part ====
110 'Length of String: Position of last ( Decimal ) Seperator
120 Dim LenstrNumber As Long: Let LenstrNumber = Len(strNumber): Dim posDecSep As Long: Let posDecSep = VBA.Strings.InStrRev(strNumber, ",", LenstrNumber) ' from right the positom "along" from left ( (in strNumber) , for a (",") , starting at the ( Last character ) which BTW. is the default
130 'Whole Number Part
140 Dim strHlNumber As String: Let strHlNumber = VBA.Strings.Left$(strNumber, (posDecSep - 1))
150 Let strHlNumber = Replace(strHlNumber, ",", Empty, 1, -1) 'In (strHlNumber) , I look for a (",") , and replace it with "VBA Nothing there" , considering and returning the strNumber from the start of the string , and replace all occurances ( -1 ).
160 Dim HlNumber As Long: Let HlNumber = CLng(strHlNumber) 'Long Number is a Whole Number, no fractional Part
170 'Fraction Part of Number
180 Dim strFrction As String: Let strFrction = VBA.Strings.Mid$(strNumber, (posDecSep + 1), (LenstrNumber - posDecSep)) 'Part of string (strNumber ) , starting from just after Decimal separator , and extending to a length of = ( the length of the whole strNumber minus the position of the separator )
190 Dim LenstrFrction As Long: Let LenstrFrction = Len(strFrction) 'Digits after Seperator. This must be done at the String Stage, as length of Long, Double etc will allways be 8, I think?.
200 Dim Frction As Double: Let Frction = CDbl(strFrction) 'This will convert to a Whole Double Number. Double Number can have Fractional part
210 Let Frction = Frction * 1 / (10 ^ (LenstrFrction)) 'Use 1/___, rather than a x 0.1 or 0,1 so as not to add another , . uncertainty!!
220 'Re join, using Maths to hopefully get correct Final Value
230 Dim DblReturn As Double 'Double Number to be returned in required Format after maniplulation.
240 If Left(strHlNumber, 1) <> "-" Then 'Case positive number
250 Let DblReturn = CDbl(HlNumber) + Frction 'Hopefully a simple Mathematics + will give the correct Double Number back
260 Else 'Case -ve Number
270 Let strHlNumber = Replace(strHlNumber, "-", "", 1, 1, vbBinaryCompare) ' strHlNumber * (-1) ' "Remove" -ve sign
280 Let DblReturn = (-1) * (CDbl(strHlNumber) + Frction) 'having constructed the value of the final Number we multiply by -1 to put the Minus sign back
290 End If 'End checking polarity.
300 'Final Code Line(s) At this point we have what we want. We need to place this in the "Double Type variable" , CStrSepDbl , so that an assinment like = CStrSepDbl( ) will return this final value
310 Let CStrSepDbl = DblReturn 'Final Double value to be returned by Function
320 Else 'End MAIN CODE. === We came here if we have a Whole Number with no seperator, case no seperator
330 'Simple conversion of a string "Number" with no Decimal Seperator to Double Format
340 Let CStrSepDbl = CDbl(strNumber) 'String to be returned by Function is here just a simple convert to Double ' I guess this will convert a zero length string "" to 0 also
350 End If 'End checking for if a Seperator is present.
'Long code lines: Referrences http://www.mrexcel.com/forum/about-board/830361-board-wish-list-2.html http://www.mrexcel.com/forum/test-here/928092-http://www.eileenslounge.com/viewtopic.php?f=27&t=22850
Function CStrSepDblshg(strNumber As String) As Double ' http://excelxor.com/2014/09/05/index-returning-an-array-of-values/ http://www.techonthenet.com/excel/formulas/split.php
5 If Left(strNumber, 1) = "," Or Left(strNumber, 1) = "." Then Let strNumber = "0" & strNumber
20 Let strNumber = Replace(strNumber, ".", ",", 1, -1)
40 If InStr(1, strNumber, ",") > 0 Then
170 If Left(Replace(Left(strNumber, (InStrRev(strNumber, ",", Len(strNumber)) - 1)), ",", Empty, 1, 1), 1) <> "-" Then
180 Let CStrSepDblshg = CDbl(CLng(Replace(Left(strNumber, (InStrRev(strNumber, ",", Len(strNumber)) - 1)), ",", Empty, 1, 1))) + CDbl(Mid(strNumber, (InStrRev(strNumber, ",", Len(strNumber)) + 1), (Len(strNumber) - InStrRev(strNumber, ",", Len(strNumber))))) * 1 / (10 ^ (Len(Mid(strNumber, (InStrRev(strNumber, ",", Len(strNumber)) + 1), (Len(strNumber) - InStrRev(strNumber, ",", Len(strNumber)))))))
190 Else
210 Let CStrSepDblshg = (-1) * (CDbl(Replace(Left(strNumber, (InStrRev(strNumber, ",", Len(strNumber)) - 1)), ",", Empty, 1, 1) * (-1)) + CDbl(Mid(strNumber, (InStrRev(strNumber, ",", Len(strNumber)) + 1), (Len(strNumber) - InStrRev(strNumber, ",", Len(strNumber))))) * 1 / (10 ^ (Len(Mid(strNumber, (InStrRev(strNumber, ",", Len(strNumber)) + 1), (Len(strNumber) - InStrRev(strNumber, ",", Len(strNumber))))))))
220 End If
250 Else
270 Let CStrSepDblshg = CDbl(strNumber)
280 End If
Demo Code to call Function
Sub TestieCStrSepDbl() ' using adeptly named TabulatorSyncranartor ' / Introducing LSet TabulatorSyncranartor Statement : http://www.excelfox.com/forum/showthread.php/2230-Built-in-VBA-methods-and-functions-to-alter-the-contents-of-existing-character-strings
Dim LooksLikeANumber(1 To 17) As String
Let LooksLikeANumber(1) = "001,456"
Let LooksLikeANumber(2) = "1.0007"
Let LooksLikeANumber(3) = "123,456.2"
Let LooksLikeANumber(4) = "0023.345,0"
Let LooksLikeANumber(5) = "-0023.345,0"
Let LooksLikeANumber(6) = "1.007"
Let LooksLikeANumber(7) = "1.3456"
Let LooksLikeANumber(8) = "1,2345"
Let LooksLikeANumber(9) = "01,0700000"
Let LooksLikeANumber(10) = "1.3456"
Let LooksLikeANumber(11) = "1,2345"
Let LooksLikeANumber(12) = ".2345"
Let LooksLikeANumber(13) = ",4567"
Let LooksLikeANumber(14) = "-,340"
Let LooksLikeANumber(15) = "00.04"
Let LooksLikeANumber(16) = "-0,56000000"
Let LooksLikeANumber(17) = "-,56000001"
Dim Stear As Variant, MyStringsOut As String
For Each Stear In LooksLikeANumber()
Dim Retn As Double
Let Retn = CStrSepDbl(Stear)
Dim TabulatorSyncranartor As String: Let TabulatorSyncranartor = " "
LSet TabulatorSyncranartor = Stear
Let MyStringsOut = MyStringsOut & TabulatorSyncranartor & Retn & vbCrLf
Debug.Print Stear; Tab(15); Retn
Next Stear
MsgBox MyStringsOut
Code also Here:
https://pastebin.com/1kq6h9Bn
VBA to automate Send and Automatically Sending of E-Mails and Excel File Workbooks
Further notes in support of answer to this Thread:
http://www.excelfox.com/forum/showth...kbooks-at-once
http://www.excelfox.com/forum/showth...0518#post10518
Microsoft Outlook.
WTF is that and HTF do you do anything with it, and WTF is it supposed to do.
I didn't know. And still don't......
The internet is full of stuff on this, but there is no clear explanation of what it is or what it should do or how you do anything with it.
But I had a go
Microsoft Outlook: what is that ( using manually )
You would normally get the software to run on its own ( visible as it were ) in a similar way to which you might get Word or Excel to start, for example
Find it single click on it:
FindOutlook Start AllProgrammes Microsoft MicrosoftOutlook.JPG : https://imgur.com/LaGs6HA
FindOutlook Start TypeInSearchBox Outlook.JPG : https://imgur.com/IbFOSHz
Make a Desktop icon from a Copy/ paste and double click on it :
MicrosoftOutlook Make a desktop Icon to double click on.JPG : https://imgur.com/ZNNPmOI
The first time you try to open it with a click or two, a set up starts.
Outlook2003Start.JPG https://imgur.com/tSQDoTe
The main use of the Outlook software is to do Email stuff, so usually you will have at least one Email account “registered in it” You can do this at the set up or later.
I had a go,
the start was OK:
Outlook2003Start.JPG https://imgur.com/R71pKfy
Outlook2003Start2.JPG https://imgur.com/XUFMpEm
These following steps took me a few hours of Emails, Internet surfing and annoying Telephone calls to my Internet provider before I
_ chose IMAP here : Outlook2003Start3ServerType.JPG : https://imgur.com/Jmnd6Vb
_ got the two required things to put in the 2 server information bars, and other stuff to fill in this : Outlook2003Start4ServerConfiguration.JPG : https://imgur.com/NXNAt9J
Von: "Doc.AElstein@t-online.de" <Doc.AElstein@t-online.de>
An: "elston, alan" <Doc.AElstein@t-online.de>
Pop3
* Serveradresse Port* Sicherheit
Posteingang securepop.t-online.de 995 SSL / TLS
Postausgang securesmtp.t-online.de 465 SSL
E-Mails über IMAP4 abrufen
Posteingang secureimap.t-online.de 993 SSL
From: "Doc.AElstein@t-online.de" <Doc.AElstein@t-online.de>
To: "elston, alan" <Doc.AElstein@t-online.de>
pop3
Server address Port Security
Inbox securepop.t-online.de 995 SSL / TLS
Outbox securesmtp.t-online.de 465 SSL
Retrieve emails via IMAP4
Inbox secureimap.t-online.de 993 SSL
MyTelekomNameUsernamePassword.JPG : https://imgur.com/K6qZgsE
TelekomInternetConfiguration.JPG : https://imgur.com/Z3XcsJu
Then I hit Finish:
Outlook2003Start5Fertig.JPG : https://imgur.com/wIMvqBb ´
I get an error in the left Pane atz that point or later as well sometimes :
Outlook2003Start6LeftpaneErrror.JPG : https://imgur.com/35XLQv6
could not connect to the server secureimap t online.JPG : https://imgur.com/UqEZtQe
Fehler (0x800CCC0E) beim Ausführen der Aufgabe "Suchen nach neuen Nachrichten in den abonnierten Ordnern auf secureimap.t-online.de.": "Der Download des Ordners "(null)" von Konto "secureimap.t-online.de" vom IMAP-Mailserver ist fehlgeschlagen. Fehler: Die Verbindung zum Server konnte nicht hergestellt werden. Falls dieser Fehler weiterhin auftritt, wenden Sie sich an den Serveradministrator oder den Internetdienstanbieter."
Fehler (0x800CCC0E) beim Ausführen der Aufgabe "secureimap.t-online.de: Posteingang - Auf neue E-Mail überprüfen.": "Der Download des Ordners "Posteingang" von Konto "secureimap.t-online.de" vom IMAP-Mailserver ist fehlgeschlagen. Fehler: Die Verbindung zum Server konnte nicht hergestellt werden. Falls dieser Fehler weiterhin auftritt, wenden Sie sich an den Serveradministrator oder den Internetdienstanbieter."
Error (0x800CCC0E) while performing the task "Search for new messages in the subscribed folders on secureimap.t-online.de.": "Downloading the folder" (null) "from account" secureimap.t-online.de "from IMAP mail server failed Error: Unable to connect to server If this error persists, contact your server administrator or ISP. "
Error (0x800CCC0E) when executing the task "secureimap.t-online.de: Inbox - Check for new e-mail.": "The download of the folder" Inbox "of account" secureimap.t-online.de "from IMAP- Mail server failed Error: Unable to connect to server If this error persists, contact your server administrator or ISP. "
Every time I open Microsoft Outlook after that I get a pop up : could not connect to the server secureimap t online.JPG : https://imgur.com/UqEZtQe
Es Konnte keine Verbindung zum Server hergestellt werden. secureimap.t-online.de befindet sich jetzt im Offlinemodus
It could not connect to the server. secureimap.t-online.de is now in offline mode
So I am still none the wiser, but It is worth doing all that anyway as you may need some of that information later in one or more of the ways to send an Email using VBA.
_1 ) Way 1) Use the CDO (Collaboration Data Objects ) object library available in VBA
Main Code , Sub PetrasDailyProWay1_COM_Way() ,
Function Code for solution to this Thread and Post
Option Explicit ' Daily Diet plan, Sending of Notes and an Excel File
Sub PetrasDailyProWay1_COM_Way() ' Allow access to deep down cods wollops from Microsoft to collaborating in particular in the form of messaging. An available library of ddl library functions and associated things is available on request, the Microsoft CDO for Windows 2000. We require some of these ' CDO is an object library that exposes the interfaces of the Messaging Application Programming Interface (MAPI). API: interfaces that are fairly easy to use from a fairly higher level from within a higher level programming language. In other words this allows you to get at and use some of the stuff to do with the COM OLE Bollocks from within a programming language such as VBA API is often referring loosely to do with using certain shipped with Windows software in Folders often having the extension dll. This extension , or rather the dll stands for direct link libraries. These are special sort of executable files of functions shared by many other (Windows based usually) software’s.
' Rem1 The deep down fundamental stuff , which includes stuff been there the longest goes by the name of Component Object Model. Stuff which is often, but not always, later stuff, or at a slightly higher level of the computer workings, or slightly more to a specific application ( an actual running "runtime" usage / at an instance in time , "instance of" ) orientated goes to the name of Object Linking and Embedding. At this lower level, there are protocols for communicating between things, and things relate are grouped into the to Office application available Library, CDO. An important object there goes by the name of Message.
'Rem 1) Library made available ====================#
With CreateObject("CDO.Message") ' Folders mostly but not always are in some way referenced using dll, either as noted with the extension or maybe refered to as dll Files or dll API files.
'Rem 2 ' Intraction protocols are given requird infomation and then set
'2a) 'With --------------------* my Created LCDCW Library, (LCD 1.0 Library ) (Linking Configuration Data_Cods Wollups) which are used and items configured for the Exchange at Microsoft’s protocol thereof; http://schemas.microsoft.com/cdo/configuration/ ......This section provides the configuration information for the remote SMTP server
Dim LCD_CW As String: Let LCD_CW = "http://schemas.microsoft.com/cdo/configuration/" ' Linking Configuration Data : defines the majority of fields used to set configurations for various Linking Collaboration (LCD) Objects Cods Wollops: These configuration fields are set using an implementation of the IConfiguration.Fields collection. https://msdn.microsoft.com/en-us/library/ms872853(v=exchg.65).aspx
.Configuration(LCD_CW & "smtpusessl") = True ' ' ' HTTPS (Hyper Text Transfer Protocol Secure) appears in the URL when a website is secured by an SSL certificate. The details of the certificate, including the issuing authority and the corporate name of the website owner, can be viewed by clicking on the lock symbol on the browser bar. in short, it's the standard technology for keeping an internet connection secure and safeguarding any sensitive data that is being sent between two systems, preventing criminals from reading and modifying any information transferred, including potential personal details. ' SSL protocol has always been used to encrypt and secure transmitted data
.Configuration(LCD_CW & "smtpauthenticate") = 1 ' ... possibly this also needed .. When you also get the Authentication Required Error you can add this three lines.
' ' Sever info
.Configuration(LCD_CW & "smtpserver") = "smtp.gmail.com" ' "securesmtp.t-online.de" '"smtp.gmail.com" "smtp.mail.yahoo.com" "smtp.live.com" "pod51017.outlook.com" "smtp-mail.outlook.com" "smtp.live.com" "securesmtp.t-online.de" 465 SMTP is just used to mean the common stuff..... Simple Mail Transport Protocol (SMTP) server is used to send outgoing e-mails. The SMTP server receives emails from your Mail program and sends them over the Internet to their destination.
' The mechanism to use to send messages.
.Configuration(LCD_CW & "sendusing") = 2 ' Based on the LCD_OLE Data Base of type DBTYPE_I4
.Configuration(LCD_CW & "smtpserverport") = 25 ' 465or25fort-online ' 465 'or 587 'or 25 ' The port of type somehow refered to by the last line
.Configuration(LCD_CW & "sendusername") = "excelvbaexp@gmail.com" ' "Doc.AElstein@t-online.de" ' .... "server rejected your response". AFAIK : This will happen if you haven't setup an account in Outlook Express or Windows Mail .... Runtime error '-2147220975 (800440211)': The message could not be sent to the SMTP server. The transport error code is 0x80040217. The server response is not available
.Configuration(LCD_CW & "sendpassword") = "Bollocks" ' "Bollox"
' Optional - How long to try ( End remote SMTP server configuration section )
.Configuration(LCD_CW & "smtpconnectiontimeout") = 30 ' Or there Abouts ;) :)
' Intraction protocol is Set/ Updated
.Configuration.Fields.Update ' 'Not all infomation is given, some will have defaults. - possibly this might be needed initially .. .Configuration.Load -1 ' CDO Source Defaults
'End With ' -------------------* my Created LCDCW Library ( Linking Configuration Data Cods Wollups) which are used and items configured for the Exchange at Microsoft's protocol therof;
'2b) ' Data to be sent
'.To = "Doc.AElstein@t-online.de"
.To = "excelvbaexp@gmail.com"
.CC = ""
.BCC = ""
.from = """Alan"" <Doc.AElstein@t-online.de>"
.Subject = "Bollox"
'.TextBody = "Hi" & vbNewLine & vbNewLine & "Please find the Excel workbook attached."
.HTMLBody = MyLengthyStreaming
.AddAttachment "G:\ALERMK2014Marz2016\NeueBlancoAb27.01.2014\AbJan2016\Übersicht aktuell.xlsx" ' ' Full File path and name. File must be closed
Rem 3 Do it
.Send
End With ' CreateObject("CDO.Message") (Rem 1 Library End =======#
Public Function MyLengthyStreaming() As String
Rem 1 Make a long string from a Microsoft Word doc
'1(i) makes available the Library of stuff, objects, Methods etc.
Dim Fso As Object: Set Fso = CreateObject("Scripting.FileSystemObject")
'1(ii) makes the big File Object " Full path and file name of Word doc saved as .htm "
Dim FileObject As Object: Set FileObject = Fso.GetFile("G:\ALERMK2014Marz2016\NeueBlancoAb27.01.2014\AbJan2016\ProMessage.htm"): Debug.Print FileObject
'1(iii) sets up the data "stream highway"
Dim Textreme As Object: Set Textreme = FileObject.OpenAsTextStream(iomode:=1, Format:=-2) ' reading only, Opens using system default https://msdn.microsoft.com/en-us/library/aa265341(v=vs.60).aspx
'1(iv) pulls in the data, in our case into a simple string variable
Let MyLengthyStreaming = Textreme.ReadAll ' Let MyLengthyStreaming = Replace(MyLengthyStreaming, "align=center x:publishsource=", "align=left x:publishsource=")
Textreme.Close
Set Textreme = Nothing
Set Fso = Nothing
Rem 2 possible additions to MyLengthyStreaming
Last bit of Function ( must go here in the excelfox Test Sub Forum in HTML Tags as there are HTML Tags in the final text string string and this makes a mess in normal BB code tags, because in excelfox Test Forum HTML is activated ) :
HTML Code:
Let MyLengthyStreaming = "<p><span style=""color: #ff00ff;"">Start=========== " & Format(Now(), "DD MMMM YYYY") & " " & Now() & " ------------------------------------</span></p>" & MyLengthyStreaming & "<p><span style=""color: #ff00ff;"">-- " & Format(Now(), "DD MMMM YYYY") & " " & Now() & " ==End, Sent from Doc.AElstein Mail ======</span></p>"
HTML Code seen in Text Editor
HTML as seen in Text Editor, for this Post:
http://www.excelfox.com/forum/showth...0524#post10524
OpenProMessageHTMLWithTextEditor.JPG : https://imgur.com/4zev9Kv
ProMessageHTMLInTextEditor.JPG : https://imgur.com/eTUd17q
HTML Code:
<body lang=DE style='tab-interval:35.4pt'>
<div class=WordSection1>
<p style='margin:0cm;margin-bottom:.0001pt'><span style='font-size:10.0pt;
font-family:"Times","serif";color:black'>T <span class=SpellE>Andale</span>
Mono</span></p>
<p style='margin:0cm;margin-bottom:.0001pt'><span style='color:red'> </span><span
style='font-size:10.0pt;font-family:"Arial","sans-serif";color:red'>T Arial</span></p>
<p style='margin:0cm;margin-bottom:.0001pt'><span style='font-family:"Arial Black","sans-serif";
color:#FF9900'>T Arial Black</span></p>
font-family:"Comic Sans MS";color:#99CC00'>T Comic <span class=SpellE>Sans</span>
MS</span></p>
font-family:"Courier New";color:#33CCCC'>T Courier New</span></p>
font-family:"Georgia","serif";color:#3366FF'>T Georgia</span></p>
font-family:"Helvetica","sans-serif";color:purple'>T <span class=SpellE>Helvetics</span></span></p>
font-family:"Impact","sans-serif";color:#999999'>T Impact</span></p>
font-family:"Tahoma","sans-serif";color:#993300'>T <span class=SpellE>Tahoma</span></span></p>
font-family:"monaco","serif";color:fuchsia'>T Terminal</span></p>
color:olive'>T Times New Roman</span></p>
font-family:"Trebuchet MS","sans-serif";color:#FF6600'>T <span class=SpellE>Trebuchet</span>
MS</span></p>
<p class=MsoNormalCxSpFirst><o:p> </o:p></p>
<p class=MsoNormalCxSpMiddle><span style='font-size:9.0pt;line-height:115%;
font-family:"Verdana","sans-serif";color:#C00000'>W9 <span class=SpellE>Verdana</span><o:p></o:p></span></p>
<p class=MsoNormalCxSpMiddle><span style='font-family:"Arial Narrow","sans-serif";
color:red'>W11 Arial <span class=SpellE>Narrow</span><o:p></o:p></span></p>
<p class=MsoNormalCxSpMiddle><span style='font-size:14.0pt;line-height:115%;
font-family:"Batang","serif";color:#FFC000'>W14 <span class=SpellE>Batang</span><o:p></o:p></span></p>
<p class=MsoNormalCxSpMiddle><span style='font-size:16.0pt;line-height:115%;
mso-ascii-font-family:Calibri;mso-fareast-font-family:Batang;mso-hansi-font-family:
Calibri;color:#92D050'>W16 Calibri<o:p></o:p></span></p>
<p class=MsoNormalCxSpMiddle><span style='font-size:18.0pt;line-height:115%;
font-family:"Cambria Math","serif";mso-fareast-font-family:Batang;color:#00B050'>W18
<span class=SpellE>Cambri</span> <span class=SpellE>Math</span><o:p></o:p></span></p>
<p class=MsoNormalCxSpMiddle><span style='font-size:20.0pt;line-height:115%;
font-family:FangSong;color:#00B050'>W20 <span class=SpellE>FangSong</span><o:p></o:p></span></p>
<p class=MsoNormalCxSpMiddle><span style='font-size:22.0pt;line-height:115%;
font-family:"Gungsuh","serif";color:#00B0F0'>W22 <span class=SpellE>Gungsuh</span><o:p></o:p></span></p>
<p class=MsoNormalCxSpMiddle><span style='font-size:24.0pt;line-height:115%;
font-family:GungsuhChe;color:#0070C0'>W24 <span class=SpellE>GungsuhChe</span></span><span
style='font-size:24.0pt;line-height:115%;font-family:"Franklin Gothic Heavy","sans-serif";
mso-fareast-font-family:Batang;color:#0070C0'> <o:p></o:p></span></p>
<p class=MsoNormalCxSpMiddle><span style='font-size:26.0pt;line-height:115%;
font-family:"Times New Roman","serif";mso-fareast-font-family:Batang;
color:#002060'>W26 Times New Roman<o:p></o:p></span></p>
<p class=MsoNormalCxSpLast><span style='font-size:28.0pt;line-height:115%;
font-family:"Franklin Gothic Heavy","sans-serif";mso-fareast-font-family:Batang;
color:#7030A0'>W28 Franklin <span class=SpellE>Gothic</span><span
style='mso-spacerun:yes'> </span>Heavy<o:p></o:p></span></p>
</div>
</body>
</html>
Modified initial function and additional second function for German telekom EMail workaround
Function codes discussed in this Post:
http://www.excelfox.com/forum/showth...0527#post10527
Dim FileObject As Object: Set FileObject = Fso.GetFile("G:\ALERMK2014Marz2016\NeueBlancoAb27.01.2014\AbJan2016\ProMessageTelekom.htm"): Debug.Print FileObject
Textreme.Close
Set Fso = Nothing
Let MyLengthyStreaming = MyLenghtyDiesScreaming_Telekom(MyLengthyStreaming) ' After this code line is done we have the string modified so that it gives the correct results in German Telekom Freemail t-online.de
' The second function below is mainly intended to make a modification to get the correct results in German Telekom Freemail t-online.de , but also the large html text not required from the start and a small amount at the end is also removed. (It does not need to be removed as it appears that it is ignored)
Public Function MyLenghtyDiesScreaming_Telekom(ByVal MyLengfyScream As String) As String ' Effectively this Dim's MyLenghtyDiesScreaming_Telekom as a String variable and MyLenghtyDiesScreaming_Telekom can be used as such in this function code. Assigning a variable to this in a main code will cause the value held by VBA in the variable MyLenghtyDiesScreaming_Telekom at that point to be out in the assigned variable, but fist the main code will be paused at this "calling" code line whilst the Function code is carried out. So we have the chance to do something in the function to fill that variable, MyLenghtyDiesScreaming_Telekom . We can take one or more things in in the ( ) to use . In this case we want to take a string in and then return it modified , hence the last code line is simply MyLenghtyDiesScreaming_Telekom = MyLengfyScream
Dim CntPus As Long ' A number constant for the positions of characters used in a couple of places. Long is very simple to handle, - final memory "size" type is known (123.456 and 000.001 have same "size" computer memory ) , and so a Address suggestion can be given for the next line when the variable is filled in. '( Long is a Big whole Number limit (-2,147,483,648 to 2,147,483,647) If you need some sort of validation the value should only be within the range of a Byte/Integer otherwise there's no point using anything but Long.--upon/after 32-bit, Integers (Short) need converted internally anyways, so a Long is actually faster. ) https://www.mrexcel.com/forum/excel-questions/803662-byte-backward-loop-4.html
' Take off all the first lot on unecessary required HTML
Let CntPus = InStr(1, MyLengfyScream, "<div class=WordSection1>", vbTextCompare) ' return the position (starting from the fist character , Looking in the string , for that text , doing a text comparison which is case insensitive )
Let MyLengfyScream = Mid(MyLengfyScream, CntPus + 26)
' Add to this array below all possible fonts in quotes I have to use Variant type as the VBA Array( ) Method used below pruduces a 1 dimmansional Array of Variant types. I may assing a dynamic Array of variant types to what the VBA Array( ) Function returns
Dim arsFonts() As Variant: Let arsFonts() = Array("""Andale Mono""", """Times""", """serif""", """Arial""", """sans-serif""", """Arial Black""", """Comic Sans MS""", """Courier New""", """Georgia""", """Helvetics""", """Impact""", """Tahoma""", """Terminal""", """monaco""", """Times New Roman""", """Trebuchet MS""", """Verdana""", """Arial Narrow""", """Batang""", """Calibri""", """Cambri Math""", """FangSong""", """Gungsuh""", """GungsuhChe""", """Franklin Gothic Heavy""")
Dim arschFont As Variant ' It is a required syntax that the stearing element in the For Each loop to be Variant type or Object type, ( the object type can be Object or ther specific object. if I do not specify specifically then VBVA defaults to all simialr ngs in the thing you are going through ' http://www.excelfox.com/forum/showthread.php/2157-Re-Defining-multiple-variables-in-VBA?p=10192#post10192
' Look for things like "Font" and replace the " with an arbitrary string like ScrotumSack , so "Font" becomes ScrotumSackFontScrotumSack
For Each arschFont In arsFonts() ' Loop to look for and replce each Font held in "s with the same font but in 's
If InStr(1, MyLengfyScream, arschFont, vbTextCompare) > 1 Then ' case a Font in quotes , like "font" , so for that font in quotes... and ...
Dim FontSingleScrQuote As String: Let FontSingleScrQuote = Replace(arschFont, """", "ScrotumSack", 1, 2, vbBinaryCompare) ' ...Make a that font in ScrotumSack like ScrotumSackfontScrotumSack ... and ... I use ScrotumSack arbitrarily as I find it funny and I doubt anyone else does.. does use it, so I won't have that already in the text. I cannot go straight to using the ' because if I do that now then I won't be able to distinguisch the existing ' which I want to change to " in the next bit
Let MyLengfyScream = Replace(MyLengfyScream, arschFont, FontSingleScrQuote, 1, -1, vbTextCompare) ' .... replace all "fonts" with ScrotumSackfontsScrotumSack
Else ' no arsch Font in My lengfy scream
Next arschFont
' replace any ' with " This is mainly intended to replace enclosed in ' strings like askjhhsa ='kasjhScrotumSackfontScrotumSackfcb qwq 63 = Bollocks' jdgsjag with askjhhsa ="kasjhScrotumSackfontScrotumSackfcb qwq 63 = Bollocks" jdgsjag
Let MyLengfyScream = Replace(MyLengfyScream, "'", """", 1, -1, vbTextCompare)
' Scratch my Scrotum sacks, - that is to say replace them with a with ' I can do this now since the existing ' have been changeed to " so the ScrotumSacks , which were originally "s , can now be chnged to 's
Let MyLengfyScream = Replace(MyLengfyScream, "ScrotumSack", "'", 1, -1, vbTextCompare)
' take last unecessary bit of HTML off
Let CntPus = InStrRev(MyLengfyScream, "</div>", -1, vbTextCompare) ' get the position counting from the left but looking from the right ( in MyLengfyScream , of </div> , start looking from end , make text comparison which is case insensitive )
Let MyLengfyScream = Left(MyLengfyScream, CntPus - 1)
' Finally we set here what is actually returned by virtue of effectively putting something in the pseudo variable MyLenghtyDiesScreaming_Telekom
Let MyLenghtyDiesScreaming_Telekom = MyLengfyScream
Code for RaghavendraPrabhu Make macro create unique files only once.If files exist amend them.
For this Post in main Excel Forum
http://www.excelfox.com/forum/showth...ist-amend-them
' https://stackoverflow.com/questions/46368771/how-to-create-a-new-workbook-for-each-unique-value-in-a-column?rq=1
' http://www.excelfox.com/forum/showthread.php/2237-Make-macro-create-unique-files-only-once-If-files-exist-amend-them
Sub ExportByName()
Dim unique(1000) As String
Dim wb(1000) As Workbook
Dim ws As Worksheet
Dim x As Long
Dim y As Long
Dim ct As Long
Dim uCol As Long
'On Error GoTo ErrHandler
'Application.ScreenUpdating = False
'Application.Calculation = xlCalculationManual
'Your main worksheet
Set ws = ActiveWorkbook.Sheets("Sheet1")
'Column G
uCol = 7
ct = 0
'get a unique list of users
For x = 2 To ws.Cells(ws.Rows.Count, uCol).End(xlUp).Row
If CountIfArray(ActiveSheet.Cells(x, uCol), unique()) = 0 Then
unique(ct) = ActiveSheet.Cells(x, uCol).Text
ct = ct + 1
Next x
'loop through the unique list
For x = 0 To ws.Cells(ws.Rows.Count, uCol).End(xlUp).Row - 1
If unique(x) <> "" Then
If Dir(ThisWorkbook.Path & "\" & unique(x) & ".xlsx", vbNormal) = "" Then 'If unique file does not exist
'add workbook
Workbooks.Add: Set wb(x) = ActiveWorkbook
ws.Range(ws.Cells(1, 1), ws.Cells(1, uCol)).Copy wb(x).Sheets(1).Cells(1, 1)
Else ' open workbook
Workbooks.Open Filename:=ThisWorkbook.Path & "\" & unique(x) & ".xlsx"
'loop to find matching items in ws and copy over
For y = 2 To ws.Cells(ws.Rows.Count, uCol).End(xlUp).Row
If ws.Cells(y, uCol) = unique(x) Then
'copy full formula over
'ws.Range(ws.Cells(y, 1), ws.Cells(y, uCol)).Copy wb(x).Sheets(1).Cells(WorksheetFunction.CountA(wb(x).Sheets(1).Columns(uCol)) + 1, 1)
'to copy and paste values
wb(x).Sheets(1).Cells(WorksheetFunction.CountA(wb(x).Sheets(1).Columns(uCol)) + 1, 1).PasteSpecial (xlPasteValues)
wb(x).Sheets(1).Cells(WorksheetFunction.CountA(wb(x).Sheets(1).Columns(uCol)), 6).Value = Format(Date, "dd mmm yyyy")
Next y
'autofit
wb(x).Sheets(1).Columns.AutoFit
'save when done
wb(x).SaveAs ThisWorkbook.Path & "\" & unique(x) & ".xlsx", FileFormat:=xlOpenXMLWorkbook, CreateBackup:=False ' & " " & Format(Now(), "mm-dd-yy")
wb(x).Close SaveChanges:=True
'once reaching blank parts of the array, quit loop
Exit For
Next x
' Master File change to current date:
Dim Lr As Long: Let Lr = ws.Cells(Rows.Count, 6).End(xlUp).Row
ws.Range("F2:F" & Lr & "").Value = Format(Date, "dd mmm yyyy")
' Application.ScreenUpdating = True
' Application.Calculation = xlCalculationAutomatic
ErrHandler:
Public Function CountIfArray(lookup_value As String, lookup_array As Variant)
CountIfArray = Application.Count(Application.Match(lookup_value, lookup_array, 0))
Second Code for RaghavendraPrabhu Make macro create unique files only once.If files exist amend them.
http://www.excelfox.com/forum/showth...0541#post10541
Sub ExportByName()
Dim ws As Worksheet
Dim x As Long
Dim y As Long
Dim ct As Long
Dim uCol As Long
'Your main worksheet info.
Let uCol = 7 'Column G
Dim Strt As Long, Stp As Long: Let Strt = ws.Cells(ws.Rows.Count, 6).End(xlUp).Row + 1: Stp = ws.Cells(ws.Rows.Count, uCol).End(xlUp).Row
Let ws.Range("F" & Strt & ":F" & Stp & "").Value = Format(Date, "dd mmm yyyy") ' adding the dates to the new rows
Let ws.Range("A" & Strt & ":A" & Stp & "").Value = Application.Evaluate("=row(" & Strt & ":" & Stp & ")-1") ' adding the S.no. to the new rows
ct = 0
ct = ct + 1
Next x
'add workbook
'loop to find matching items in ws starting from where column F ( 6 ) has no entry and copy over
'For y = ws.Cells(ws.Rows.Count, 6).End(xlUp).Row + 1 To ws.Cells(ws.Rows.Count, uCol).End(xlUp).Row
For y = Strt To Stp
wb(x).Sheets(1).Cells(WorksheetFunction.CountA(wb(x).Sheets(1).Columns(uCol)) + 1, 1).PasteSpecial Paste:=xlPasteValuesAndNumberFormats
'wb(x).Sheets(1).Cells(WorksheetFunction.CountA(wb(x).Sheets(1).Columns(uCol)), 6).Value = Format(Date, "dd mmm yyyy")
Next y
'autofit
'save when done
Exit For
Next x
'' Master File change to current date:
'Dim Lr As Long: Let Lr = ws.Cells(Rows.Count, 6).End(xlUp).Row
' ws.Range("F2:F" & Lr & "").Value = Format(Date, "dd mmm yyyy")
ErrHandler:
