Results 1 to 10 of 29
Thread: Code Required to calculate number of days worked, normal overtime and holiday overtime
    I think we may almost know what is to be done !
    These are the some of the criteria my next code will work on: ( These are those criteria which were unclear until now ! )
    Holidays are shown in yellow background color
    Normal working days have no background color
    The data rows to be considered are those filled with dates in column E
    “TOTAL NO. OF DAYS” ( to be placed by the code in cell C34 )
    For all Months, the “TOTAL NO. OF DAYS” ( to be placed in cell C34 ) is not necessarily the number of days worked.
    The formula for calculating this is:
    _Assuming the employee is not Absent for any day, then the “TOTAL NO. OF DAYS” is always taken as 30
    _ If the employee has one or more normal days of absence, ( normal days with no total working hours ), then the formula for calculating “TOTAL NO. OF DAYS” is as follows:
    TOTAL NO. OF DAYS = 30 – ( Count of “ABSENT” )
    “ABSENT” ( to be written in some rows in Column K by the program )
    Count of “ABSENT” is the number of occurrences of ABSENT in column K in the final ( After ) Worksheet “ABSENT” is to be written in some rows of column K by the code under certain criteria.
    ( “ABSENT” is not necessarily the normal working days in which an employee is absent and / or has no total working hours. )
    “ABSENT” is to be written in column K by the code under the following criteria:
    _ For the rows of all normal days when the employee has no working hours, ( days when the employee is absent ), “ABSENT” is to be written in column K.
    _ In addition , should it occur that an employee is absent for both the days before and after a holiday, then for the ( Holiday ) row in between those two days, “ABSENT” is to be written in column K.
    ( No consideration of this ““ABSENT” criteria thereof” is made for the case of a Holiday at the first or last “Entries” )
    ( The number of “Entries” is taken as the filled dates in column E )
    Column L ( help column )
    Nelson has chosen the second code. It puts formulas in cells C34, G34, and J34.
    This requires “H” or “N” to indicate Holiday or Normal working day. This will be written by the code in column L
    _......................
    Nelson:
    Please examine the above criteria , and tell me if this is correct ?
    Hi Nelson.
    Here is the next code version:
    Here: ( Post 27 )
    http://www.excelfox.com/forum/showth...0101#post10101
    and here: ( Post 28 )
    http://www.excelfox.com/forum/showth...0102#post10102
    It is all one code ( I had to split it due to post character size restrictions )
    You need to copy the second ´part directly under the first part in the same code module
    _.........
    The code takes your Before like these:
    http://www.excelfox.com/forum/showth...0096#post10096
    http://www.excelfox.com/forum/showth...0097#post10097
    After running_..
    Sub IJAdjust_LAdd_AbsentKAdd_TotalsFormulas_AllWorkshe etsCode4()
    _.. you should get like:
    http://www.excelfox.com/forum/showth...0098#post10098
    http://www.excelfox.com/forum/showth...0099#post10099
    http://www.excelfox.com/forum/showth...0100#post10100
    _.....
    Here is just a small sample of what the code does:
    Before:
    Using Excel 2007 32 bit
    28.Dec.16
    7:00
    18:00
    11:00
    9:00
    2:00
    29.Dec.16
    30.Dec.16
    31.Dec.16
    1.Jan.17
    7:00
    18:00
    11:00
    9:00
    2:00
    12.Jan.17
    7:00
    18:00
    11:00
    9:00
    2:00
    13.Jan.17
    7:00
    18:00
    11:00
    9:00
    2:00
    14.Jan.17
    7:30
    17:30
    10:00
    9:00
    1:00
    Worksheet: Post22Before121
    After:
    28.Dec.16
    7:00
    18:00
    11:00
    9:00
    2:00
    N
    29.Dec.16
    ABSENT N
    30.Dec.16
    ABSENT
    31.Dec.16
    ABSENT N
    1.Jan.17
    7:00
    18:00
    11:00
    9:00
    2:00
    N
    9.Jan.17
    ABSENT N
    10.Jan.17
    7:00
    18:00
    11:00
    9:00
    2:00
    N
    11.Jan.17
    7:00
    18:00
    11:00
    9:00
    2:00
    N
    12.Jan.17
    7:00
    18:00
    11:00
    9:00
    2:00
    N
    13.Jan.17
    7:00
    18:00
    11:00
    10:00
    14.Jan.17
    7:30
    17:30
    10:00
    9:00
    1:00
    N
    J
    34
    TOTAL NO. OF DAYS -----> 25
    Normal Overtime ----->
    39
    Holiday Overtime ----->
    18
    J
    34
    TOTAL NO. OF DAYS -----> =30-COUNTIF(K1:K31,"ABSENT")
    =SUMIF(L1:L31,"N",J1:J31)*24
    =SUMIF(L1:L31,"H",J1:J31)*24
  1. Replies: 33
    Last Post: 01-12-2015, 10:08 AM
  2. Replies: 1
    Last Post: 07-23-2013, 10:43 PM
  3. Replies: 0
    Last Post: 09-17-2012, 02:05 PM
  5. Number of Days In A Month
    Last Post: 05-14-2011, 08:00 PM
