Results 1 to 8 of 8
Thread: Sumif On Multiple Columns Using Multiple Criteria By Passing A Range Of Values
    May 2013
    Wink
    Sure,
    Although the criteria is exhaustive at the moment, the idea is that I will be able to delete (or select) specific criteria and the formula would update to reflect the new totals.... eventually I intend to have these criteria as 'tick boxes' so that I can select or de-select at will and the (required) forula will update automatically.
    Having tried (and failed) with the sumproduct function (it returned incorrect amounts), im thinking that an advanced filter macro followed by some kind of sum function might be the answer, but would love it the sumproduct function does have the answer! .
    Thanks again
    I am guessing this should suffice
    =SUMPRODUCT(ISNUMBER(MATCH($C$17:$C$43,$B$7:$B$10, 0)*MATCH($D$17:$D$43,$C$7:$C$10,0)*MATCH($E$17:$E$ 43,$D$7:$D$10,0))*($F$17:$F$43)*($B$17:$B$43=F7))
    May 2013
    That is EXACTLY what Im after, (and have been for a while!) Many Thanks! (I shall leave the modelling expert at work to stew over this a little longer as punishment!)
    Here's the file BTW. And yes, it's a SUMPRODUCT
  1. Replies: 3
    Last Post: 05-23-2013, 11:17 PM
  2. Sum values based on multiple criteria
    By Jorrg1 in forum Excel Help
    Last Post: 01-07-2013, 03:04 PM
  3. Replies: 4
    Last Post: 08-11-2012, 10:50 PM
  4. Sum values based on multiple criteria
    By vmath in forum Excel Help
    Last Post: 05-07-2012, 08:53 AM
  5. Fetch multiple values based on criteria
    By Lucero in forum Excel Help
    Last Post: 04-07-2012, 12:35 PM
