Results 1 to 10 of 16
Thread: Timespan Starting With Active Cell Value Using Input Box Value
    May 2013
    I have this code that works great. When I click on the macro "TimeSpanCheck"
    Sub TimeSpanCheck()
    Dim Break               As Long
    Dim Prompt              As String
    Dim Title               As String
    Dim StartTime           As Date
    Dim EndTime             As Date
    Dim Duration            As Date
    Dim Cel                 As Range
        If ActiveSheet Is Nothing Then
            Beep
            GoTo ExitSub:
        Prompt = "Select the start time."
        Title = "Start Time Specification"
        Set Cel = Application.InputBox(Prompt, Title, , , , , , 8)
        If Cel Is Nothing Then
            GoTo ExitSub:
        StartTime = CDate(Cel.Value)
        Prompt = "Select the end time."
        Title = "End Time Specification"
            GoTo ExitSub:
        EndTime = CDate(Cel.Value)
        Prompt = "Enter the break time in minutes to deduct."
        Title = "Break Time Specification"
        Break = Val(InputBox(Prompt, Title, 60))
        If Break < 0 Then
            Break = 0
        If EndTime > StartTime Then
            Duration = EndTime - StartTime - TimeSerial(0, Break, 0)
            Duration = EndTime - StartTime - TimeSerial(0, Break, 0) + 1
        Prompt = "The duration is: " & Format(Duration, "h:mm")
        Title = "Calcuation Results"
        MsgBox Prompt, vbInformation, Title
    ExitSub:
        Set Cel = Nothing
    However it prompt me for the start time when I usually start this with the active cell that I am in and I have to click in the cell again.
    So I attempted to modify my code and have the first input box start up with the active cell value (Time Value). I got it to work however it is giving me the wrong time value. If I go back to the original one it is correct. I believe it has to do with perhaps "StartTime = CDate(Cel.Value)" converting the input cell value. the original is reading the time value.
    Here is my code not calculating correctly.
    Sub ActiveCellTimeSpanCheck()
    Dim Break               As Long
    Dim Title               As String
    Dim EndTime             As Date
    Dim Cel                 As Range
            Beep
            GoTo ExitSub:
        ActiveCell = CDate(Cel.Value)
        'Want to always start with the active Cell
        Set Cel = Application.InputBox(Prompt, Title, CDate(ActiveCell.Value))
        'My original line : Set Cel = Application.InputBox(Prompt, Title, , , , , , 8)' works great but have to select first
    '    On Error GoTo 0
    '    If Cel Is Nothing Then
    '        GoTo ExitSub:
    '    End If
    '    StartTime = CDate(Cel.Value)
            GoTo ExitSub:
        If Break < 0 Then
            Break = 0
    ExitSub:
        Set Cel = Nothing
    This code unlike the original give me the wrong time
    Example original code Start time 8:00 AM End Time 5:00 PM minus an hour lunch result is 8:00 the modified code result is 16:00
    anyone see what I am doing incorrectly Thanks
    Welcome to ExcelFox!
    Try this
    Dim Break               As Long
    Dim Title               As String
    Dim EndTime             As Date
    Dim Cel                 As Range
    Dim varSTime            As Variant
            Beep
            GoTo ExitSub:
        varSTime = Application.InputBox(Prompt, Title, CDate(ActiveCell.Value))
    '    On Error GoTo 0
    '        GoTo ExitSub:
    '    End If
        StartTime = CDate(varSTime)
            GoTo ExitSub:
        If Break < 0 Then
            Break = 0
    ExitSub:
        Set Cel = Nothing
    May 2013
    Thank you for the direction and solution. I did several tests with the adjusted code and it worked like the original. Thank you
    Quote Originally Posted by Smd747 View Post
    Just to follow up...
    Admin's solution does not actually work like you intended your original code to... in your original code, you were able to select the cell that contained the date if your active cell was not the correct one, Admin's solution would have you typing the date in under that circumstance. The following method would default the InputBox to the active cell's address, but would allow you to select a different cell if the active cell was not on the correct date to begin with (no typing required)...
    Set Cel = Application.InputBox(Prompt, Title, ActiveCell.Address, , , , , 8)
    May 2013
    In hind site, Ideally what I would like is when iI click the macro button that activates the code it prompts me for the ending time because the start time was automatically captured as being the active cell. with this code. Mod it confirms the active cell time is correct but I still have to click ok to get the prompt for the ending time
    The above will save me a click
    I'm think that at the end you get a message box that shows what the start was, what the ending time was and the break time deducted. And of course what the answer the is as a complete check
    Do not know if this is possible
    Still testing your suggestion will post test results later
    Something like this maybe...
    Sub GetStartEndTime()
      Dim StartTime As Date, EndTime As Date, TimeDiff As String
      StartTime = ActiveCell.Value
      EndTime = Application.InputBox("Select the cell with the ending time...", Type:=8)
      TimeDiff = Format(EndTime - StartTime, "h"" hours and ""m"" minutes""")
      MsgBox "Start time: " & StartTime & vbLf & "End time: " & EndTime & vbLf & "Time difference: " & TimeDiff
    May 2013
    Your mod works very well, I like the hours and minutes to the value, thats really cool. Is it possible to add the break value to this code to say minus 60 minutes the value of the input which is either 30 or 60 ? this way I don't have to mentally deduct it from the times to get the value. Thanks you for the help and direction
    May 2013
    I am thinking something like this, but can not get it to work yet
    Sub TestGetStartEndTime()
      Dim StartTime As Date, EndTime As Date, BreakTime As Date, TimeDiff As String
      BreakTime = CDate(1.00)
      MsgBox "Start time: " & StartTime & vbLf & "End time: " & EndTime & vbLf & "Time difference: " & TimeDiff - BreakTime
    Keep getting error code 13
    May 2013
    First hiccup with the new code. It does not account for overnight . When I click active cell 6:00 PM and ending cell 2:30 AM it give me 16 hours
    Do I need to use the mod function??
    Try it like this and let me know if it works for you or not...
    Sub GetStartEndTime2()
      Dim StartTime As Date, EndTime As Date, BreakTime As Long, TimeDiff As String
      BreakTime = 60 'Not sure how you plane to calculate 30 or 60, but it goes here
      TimeDiff = Format(24 + EndTime - StartTime - TimeSerial(0, BreakTime, 0), _
                 "h"" hours and ""m"" minutes which excludes a " & BreakTime & " minute break.""")
  1. Highlight Active Cell’s Row and Column
  2. Replies: 8
    Last Post: 04-16-2013, 02:04 PM
  3. List of Dates In DropDown Starting From Today()
    Last Post: 04-10-2013, 05:58 PM
  4. How to Lock or Unlock row basis previous cell input?
    Last Post: 07-25-2012, 02:40 PM
  5. Sample VB programs for Starting VB
    By sumit.dutt in forum Excel Help
    Last Post: 12-27-2011, 07:04 PM
