Thread: Changing Slideshow viewing mode to kiosk using vba
    May 2013
    Hello all,
    Additionally this is all part of a large macro which is designed to switch the slideshow from presenter mode to kiosk mode when at a specific slide. The code I am using is below.
    Sub Kioskmode()
    With ActivePresentation.SlideShowSettings
    .ShowType = ppShowTypeKiosk ' or ppShowTypeSpeaker etc
    .LoopUntilStopped = msoFalse
    .ShowWithNarration = msoTrue
    .ShowWithAnimation = msoTrue
    .RangeType = ppShowAll
    .AdvanceMode = ppSlideShowUseSlideTimings
    .PointerColor.RGB = RGB(Red:=255, Green:=0, Blue:=0)
    .Run
    Sub switchmodes()
    Call Kioskmode
    ActivePresentation.SlideShowWindow.View.Exit
    ActivePresentation.SlideShowSettings.Run
    ActivePresentation.SlideShowWindow.View.GotoSlide (3)
    Is there a better/smoother way to do this without slideshows closing and opening and jumping between slides? Ideally I would like to click a button on slide x and move to slide y changing to kiosk mode on route.
    If this is not possible is there a way to open a slideshow at a specific slide. I am currently using the code below. This opens the slideshow, then moves to the selected slide (3). This looks messy though as it shows slide 1 briefly then slide 3. Any ideas on how to open at slide 3 instead without going via slide 1?
    Sub Openslideshow()
    ActivePresentation.SlideShowSettings.Run.
    Thanks for your help!
    To open a slideshow at a specific slide, just hide all the previous slides and save it as a PowerPoint Show. Now, although you can still start from slide 1 from within the application (if you have the file open, and not in Kiosk mode), when the 'Show' loads, it will always show the first 'non-hidden' slide.
  1. Combobox Not Working In Excel Workbook Shared Mode
    Last Post: 06-03-2013, 01:25 PM
  2. VBA Code Works Only in debug Mode.
    Last Post: 06-17-2012, 06:14 AM
  3. Changing Hyperlink To Another Sheet By Changing Value Of Cell
    Last Post: 04-30-2011, 11:55 PM
  4. Replies: 0
    Last Post: 04-03-2011, 07:57 PM
