Results 1 to 7 of 7
Thread: Macro To Sort Data Ascending and Decending Using VBA
    Feb 2013
    I've never done macros before, but I thought I'd ask how to do a macro to do the following:
    1. Select Columns J:AG
    2. Sort first by Column AG in ascending order(Lowest to Highest)
    3. Sort then by Clolumn J in descending order (Highest to Lowest)
    Could I just click on a button or a cell to run this macro? Thanks!
    Try this..
    Sub ExcelFox()
        Dim lng As Long
        With Worksheets("Sheet1")
            lng = Application.Max(.Cells(.Rows.Count, "J").End(xlUp).Row, 2)
            .Sort.SortFields.Clear
            .Sort.SortFields.Add Key:=.Range("AG2:AG" & lng), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
            .Sort.SortFields.Add Key:=.Range("J2:J" & lng), SortOn:=xlSortOnValues, Order:=xlDescending, DataOption:=xlSortNormal
            .Sort.SetRange .Range("J1:AG" & lng)
            .Sort.Header = xlYes
            .Sort.MatchCase = False
            .Sort.Orientation = xlTopToBottom
            .Sort.SortMethod = xlPinYin
            .Sort.Apply
    Feb 2013
    Ok, since I'm new to this... A few questions...
    The 'macro' is called ExcelFox, right?...
    It's a module? Right? So Ican hit Alt-F11, paste this code into a Module, right?
    Then I can run it immediately or I can call it by going to 'Developer' then 'Macros', then running it, right?
    Once I run it, that's it! Right?...
    Sorry for all the 'Rights'!
    I'll try it when I get home tonight!
    Feb 2013
    Quote Originally Posted by olives View Post
    ... I'll try it when I get home tonight!
    Just tried it out, Fox! It looks good! Thanks!
    Let me ask you this... It doesn't seem to be incluidng the top row, row 1, in the sort, what do I have to change in the code to include the top row?...
    Does it have to do with this row?:
    Is the 2 at the end what I should change to 1? Thanks!
    You can insert a shape and assign the macro to this, or call the routine from within the click event of a command button.
    No that's not what you need to do. Here you go...
    Sub ExcelFox()
        Dim lng As Long
            lng = .Cells(.Rows.Count, "J").End(xlUp).Row
            .Sort.SortFields.Add Key:=.Range("AG1:AG" & lng), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
            .Sort.SortFields.Add Key:=.Range("J1:J" & lng), SortOn:=xlSortOnValues, Order:=xlDescending, DataOption:=xlSortNormal
            .Sort.Header = xlNo
            .Sort.Apply
    Feb 2013
    Sub ExcelFox()
        Dim lng As Long
            .Sort.Header = xlNo
            .Sort.Apply
    Wow! Amazing! Thanks!
  1. Sort Data Using Formula To Find Top X
    Last Post: 06-02-2013, 10:13 PM
  2. Sort data sheet by right_click of mouse
    Last Post: 12-08-2012, 07:34 PM
  3. Excel Macro to Sort Data if a value changes in defined range
    Last Post: 09-05-2012, 10:31 AM
  4. Sort Data When a Header Is Clicked
    Last Post: 08-01-2012, 06:46 AM
  5. Sort Worksheet by Color VBA
    Last Post: 10-25-2011, 02:25 AM
