While it is more efficient to use the formulas posted in these two articles when parsing delimited text...
Get Field from Delimited Text String
Get "Reversed" Field from Delimited Text String
there are times when you might want to do so inside your own VB code. Now, there is nothing hard about doing this, you would simply use the Split function, and that is all I am doing here, but I thought it might be useful to combine the two functionalities of the above two cited articles into a single function that can be called as needed, so, here is that function....
The function has three required arguments and two optional arguments. The first required argument is the text string that you want to parse, the second required argument is the text (one or more characters) to use as the delimiter and the third required argument is the field number that you want the function to return (first field is numbered 1, second field is numbered 2, etc.). The optional fourth argument specifies whether the fields should be counted from the front (left to right) or the back (right to left) of the text being parsed... the default for this argument is True meaning count the fields from the front, set it to False to have the function count fields from the back. And the optional fifth argument controls whether the delimiter should be case sensitive or not (True for case sensitive, False for not case sensitive).Code:Function GetField(TextIn As String, Delimiter As String, FieldNumber As Long, _ Optional FromFront As Boolean = True, _ Optional CaseSensitive As Boolean = False) As Variant Dim Fields() As String Fields = Split(TextIn, Delimiter, , Abs(CaseSensitive)) If FromFront Then GetField = Fields(FieldNumber - 1) Else GetField = Fields(UBound(Fields) - FieldNumber + 1) End If End Function
