I spent last day or so trying to create a macro that would update the data source of the series in the chart. I went thorugh dozens of solutions which I found on the net and none of them are doing what I need them to do.
The problem is that the series of data on the chart pull data from different columns of the data source table.
This is what I get when I update the Data Source and record the macro:
what I would like to replace it with is the following:Code:ActiveChart.SetSourceData Source:=Sheets(1).Range("L12:L65,N12:N65")
The problem is that why I do this, it does not treat it the same way as the original line, it also includes all the columns in between the two data ranges.Code:Dim MyDataSource1 as Range Dim MyDataSource2 as Range LastCellColumnL = .... LastCellColumnN = ... Set MyDataSource1 = ActiveSheets.Range(L12, LastCellColumnL) Set MyDataSource2 = ActiveSheets.Range(N12, LastCellColumnN) ActiveChart.SetSourceData Source:=Sheets(1).Range(MyDataSource1,MyDataSource2)
How to make
to work like:Code:ActiveChart.SetSourceData Source:=Sheets(1).Range(MyDataSource1,MyDataSource2)
and only include the two columns like in the original line here?Code:ActiveChart.SetSourceData Source:=Sheets(1).Range("L12:L65,N12:N65")
Rafal
