Results 1 to 10 of 17
Thread: Lookup All Corresponding Values Match Criteria In Adjacent Column Array Formula
    Jan 2013
    Dear friends
    i want array formula help in my project
    pls refer my sheet @ https://docs.google.com/file/d/0B01x...it?usp=sharing
    thanks
    dhaval shah
    Nov 2011
    Can you please share any sample file ?
    Regards
    Prince
    Hi Dhaval,
    Are you talking about the same which you have already posted at below mentioned link
    https://groups.google.com/forum/#!to...B1-25-false%5D
    Try this and follow the steps:
    Select cell S14:S32, press F2 and paste below formuls and confirm it with CSE
    =IFERROR(INDEX($B$1:$N$35068,IFERROR(SMALL(IFERROR(INT(SUBSTITUTE(($D$1:$D$35068 <=$T$11)*($E$1:$E$35068 = $S$13)*($B$1:$B$11180 = $T$10)*($M$1:$M$35068 <> 0),0,""))*ROW($A$1:$A$35068),""), ROW($A$1:$A$35068)),""),1),"")
    Select cell T14:T32, press F2 and paste below formuls and confirm it with CSE
    =IFERROR(INDEX($B$1:$N$35068,IFERROR(SMALL(IFERROR(INT(SUBSTITUTE(($D$1:$D$35068 <=$T$11)*($E$1:$E$35068 = $S$13)*($B$1:$B$11180 = $T$10)*($M$1:$M$35068 <> 0),0,""))*ROW($A$1:$A$35068),""), ROW($A$1:$A$35068)),""),3),"")
    Select cell U14:U32, press F2 and paste below formuls and confirm it with CSE
    =IFERROR(INDEX($B$1:$N$35068,IFERROR(SMALL(IFERROR(INT(SUBSTITUTE(($D$1:$D$35068 <=$T$11)*($E$1:$E$35068 = $S$13)*($B$1:$B$11180 = $T$10)*($M$1:$M$35068 <> 0),0,""))*ROW($A$1:$A$35068),""), ROW($A$1:$A$35068)),""),4),"")
    Select cell V14:V32, press F2 and paste below formuls and confirm it with CSE
    =IFERROR(INDEX($B$1:$N$35068,IFERROR(SMALL(IFERROR(INT(SUBSTITUTE(($D$1:$D$35068 <=$T$11)*($E$1:$E$35068 = $S$13)*($B$1:$B$11180 = $T$10)*($M$1:$M$35068 <> 0),0,""))*ROW($A$1:$A$35068),""), ROW($A$1:$A$35068)),""),12),"")
    Select cell W14:W32 press F2 and paste below formuls and confirm it with CSE
    =IFERROR(INDEX($B$1:$N$35068,IFERROR(SMALL(IFERROR(INT(SUBSTITUTE(($D$1:$D$35068<=$T$11)*($E$1:$E$35068=$S$13)*($B$1:$B$11180 = $T$10)*($M$1:$M$35068<>0),0,""))*ROW($A$1:$A$35068),""),ROW($A$1:$A$35068)),""),13),"")
    Select cell X14:X32, press F2 and paste below formuls and confirm it with CSE
    =IFERROR(INDEX($B$1:$N$35068,IFERROR(SMALL(IFERROR(INT(SUBSTITUTE(($D$1:$D$35068 >=$T$11)*($E$1:$E$35068 = $X$13)*($B$1:$B$11180 = $T$10)*($M$1:$M$35068 <> 0),0,""))*ROW($A$1:$A$35068),""), ROW($A$1:$A$35068)),""),1),"")
    Select cell Y14:Y32, press F2 and paste below formuls and confirm it with CSE
    =IFERROR(INDEX($B$1:$N$35068,IFERROR(SMALL(IFERROR(INT(SUBSTITUTE(($D$1:$D$35068 >=$T$11)*($E$1:$E$35068 = $X$13)*($B$1:$B$11180 = $T$10)*($M$1:$M$35068 <> 0),0,""))*ROW($A$1:$A$35068),""), ROW($A$1:$A$35068)),""),3),"")
    Select cell Z14:Z32, press F2 and paste below formuls and confirm it with CSE
    =IFERROR(INDEX($B$1:$N$35068,IFERROR(SMALL(IFERROR(INT(SUBSTITUTE(($D$1:$D$35068 >=$T$11)*($E$1:$E$35068 = $X$13)*($B$1:$B$11180 = $T$10)*($M$1:$M$35068 <> 0),0,""))*ROW($A$1:$A$35068),""), ROW($A$1:$A$35068)),""),4),"")
    Select cell AA14:AA32, press F2 and paste below formuls and confirm it with CSE
    =IFERROR(INDEX($B$1:$N$35068,IFERROR(SMALL(IFERROR(INT(SUBSTITUTE(($D$1:$D$35068 >=$T$11)*($E$1:$E$35068 = $X$13)*($B$1:$B$11180 = $T$10)*($M$1:$M$35068 <> 0),0,""))*ROW($A$1:$A$35068),""), ROW($A$1:$A$35068)),""),12),"")
    Select cell AB14:AB32, press F2 and paste below formuls and confirm it with CSE
    =IFERROR(INDEX($B$1:$N$35068,IFERROR(SMALL(IFERROR(INT(SUBSTITUTE(($D$1:$D$35068>=$T$11)*($E$1:$E$35068=$X$13)*($B$1:$B$11180 = $T$10)*($M$1:$M$35068<>0),0,""))*ROW($A$1:$A$35068),""),ROW($A$1:$A$35068)),""),13),"")
    Hope this is what you are asking for.
    Jan 2013
    Hello Lalitji
    its working for one stock only if there is much more Stocks then Formula not working pls refer my sheet
    Jan 2013
    Sir
    Pls have a look at https://docs.google.com/file/d/0B01x...it?usp=sharing
    in excelsheet pls refer sheet3
    if i select any Stocks from S10 the out put is not as per what i want
    I didn't get you. If you drag the old formula it is giving result if it is not correct please share file with the desired output.
    Jan 2013
    Sir ,
    i send a detail e-mail for desire output
    Dhaval Shah
    98240 35253
    Jan 2013
    Sir ,
    Here with send a download link of my desire out put ................
    https://docs.google.com/file/d/0B57o...it?usp=sharing
    Dhaval Shah
    Have you tried with the new solution which i have given you in my previous post. I have changed it as according to the file which you have just shared.
  1. Replies: 6
    Last Post: 05-22-2013, 02:23 AM
  2. Replies: 4
    Last Post: 04-24-2013, 10:04 AM
  3. Replies: 3
    Last Post: 03-12-2013, 12:54 PM
  4. Replies: 3
  5. Replies: 3
    Last Post: 04-08-2012, 09:44 AM
