Results 1 to 10 of 16
Thread: Loop to two columns and Concatenate values
    Quote Originally Posted by LalitPandey87 View Post
    where is the data. i am not able to see it or you missed it
    I think the OP is answering questions across forums. The data he posted in his attachment in this forum is more than the sample data he posted in the MrExcel forum and I believe his last message is just telling me that as a response to my message (#4) in this thread. Unfortunately, the OP still did not provide an explanation of why the methods of moving upward from the blanks is handled differently for the two spaces he showed in the sample data he posted to the MrExcel forum (unfortunately, his attached file in this forum does not show the problem he exposed with his sample data in the MrExcel forum); hence, I am still confused as to what the underlying rule is for filling out the Avail column; so, unless he posts what that underlying rule is, I know I will not be able to help him further... hopefully you are understanding it sufficiently to carry on. I'll jump back in if the OP eventually posts a clear description explaining the problem I wrote to him about for his MrExcel sample data.
    My code is giving exact the same output as he shown in the attachment.
    Apr 2013
    @ LalitPandey87, thanks it works fine.
    What should i edit to only have the results (col Avail), instead of duplicating the whole table.
    br,
    ivan
    Change this line
        Const strOutPutCell             As String = "H1" 'Change accordingly
    with this one
        Const strOutPutCell             As String = "A1" 'Change accordingly
    Quote Originally Posted by ivandgreat View Post
    @ivandgreat and LalitPandey87,
    Try LalitPandey87's code against the second sample data you showed over in the MrExcel forum here...
    Loop To Last EndPt
    I get the code crashing Excel completely (if you do not stop it earlier enough using CTRL+Break). So my question is... was that second sample data real or not (it was the entire reason I did not give you a solution).
    @LalitPandey87,
    See the above link for the sample data and this link for why I did not understand how to provide any code to the OP (and for a hint at what I think is causing your code to crash when used against it)...
    Loop To Last EndPt
    @LalitPandey87,
    See the above link for the sample data ...
    Hi Rick,
    I have checked the same on second sample data and it works fine.
    I tried it again after reading your message and the data still crashed your code. Playing a hunch, I rebooted my computer and now, sure enough, your code works perfectly with that data. My computer must have picked up a "glitch" along the way which had been affecting Excel in some way. Sometimes I just hate computers!
  1. Vlookup Multiple Values By Adding Formula With Loop In VBA
    Last Post: 04-22-2013, 04:49 PM
  2. Function to Concatenate Values
    Last Post: 12-13-2012, 11:38 AM
  3. Concatenate multiple values
    By mcpizzle in forum Excel Help
    Last Post: 08-30-2012, 04:03 PM
  4. Loop and Check For Values In Entire Column in Excel
    By Jeff5019 in forum Excel Help
    Last Post: 05-01-2012, 10:34 PM
  5. Concatenate Multiple Lookup Values in Single Cell
    Last Post: 04-06-2012, 09:07 PM
