Results 1 to 8 of 8
Thread: Difference Between 'On Error GoTo 0' And 'On Error GoTo -1'
    Member Transformer's Avatar
    Mar 2012
    Lightbulb Difference Between 'On Error GoTo 0' And 'On Error GoTo -1'
    It disables the current error handler.So it is used to resume execution normally (without any error handler).
    Sub ErrorHandler()
        Dim dblValue        As Double
        ThisWorkbook.Worksheets("A").Range("A1") = "Transformer" ' Subscript out of range error will occur if there is no sheet named "A" in the Workbook
        'On Error GoTo 0 'error handler disabled..next error will not be handled.Uncomment the line to check the effect.
        dblValue = 1 / 0 ' Division by Zero error
        MsgBox "Ingnored all the errors."
    In above example if one uncomments the line On Error GoTo 0 then it will not handle the error that comes after this statement.
    On Error GoTo -1
    When an error occurs within a procedure, an exception object is created. On Error GoTo -1 is used to set this exception object to nothing.
    If it is not done then next error handler statement (e.g. On Error GoTo errHandler / On Error Resume Next ...) will not work.
    To check the effect of not using it comment the line 'On error GoTo -1' in the snippet given below.
    Sub ErrorTest()
        On Error GoTo ErrHandler1
        dblValue = 1 / 0
    ErrHandler1:
        MsgBox "Exception Caught"
        On Error GoTo -1           'Comment this line to check the effect
        On Error GoTo ErrHandler2
        dblValue = 1 / 0
    ErrHandler2:
        MsgBox "Again caught it."
    But if you use Resume Next as an error handler then an exception object is not created.
    Sub ErrorTest()
        dblValue = 1 / 0
        dblValue = 1 / 0
        'No need to set exception object to nothing as it has not been created
    ErrHandler:
    More examples to understand the same.
    Sub ErrorTestUserHandler()
            For lngloop = 1 To 10
                dblValue = 1 / 0
    ErrHandler:
                MsgBox "Caught it."
                On Error GoTo -1 'Comment this line and run it again to see the effect
    Sub ErrorTestResumeNext()
                dblValue = 1 / 0
                MsgBox "Caught it."
    Regards,
    Transformer
    Nice explanation buddy. Really helps us to understand why and how to use error handling in VBA.
    To the point explanation. Before this i also don't even know the use of on error goto -1 and now my confusion is clear. thanks excelfox and transformer.
    May 2014
    Finally I found an explanation for GoTo 0 that I could understand.
    The GoTo -1 and the no exception object with Resume Next made it a 10 out of 10 post.
    Thanks so much for posting this!!!
    Quote Originally Posted by skywriter View Post
    .... the no exception object with Resume Next made it a 10 out of 10 .....
    ... Agreed. That jem of info was the bit missing by me...now I see ( I think ) why despite an error "occuring", ( andbeing "Handeled by the Resume Next ) I can follow it by enabling another error handler without resetting the exception-- in the case of Resume Next I see now there is no acception raised. It had been explained to me as "surpressing the errror", which I read as something else.. ( not quite sure what - I was puzzeled ) - now I understand ( I think! )
    Thanks for Sharing
    . Hi,
    . A Couple of follow up questions.
    . 1 ) Would you describe On Error GoTo 0 and On Error GoTo -1 as error statements,
    And
    . 2 ) On Error Resume Next and On Error GoTo some_label/line_number as error handlers.
    . Thus we have in VBA 2 types of “error handlers”. I ask as the literature is often confusing, ( possibly caused partly by the GoTo 0 and GoTo -1 which do not actually “go anywhere” I believe ).
    . One is often mislead in thinking in terms of 4 “error handlers”
    Last edited by DocAElstein; 05-27-2015 at 08:55 PM. Reason: Editor lost some spaces between words!!??
    P.s. Just for info: Similar Blog is here
    On Error WTF? | Excel Matters
    Edit April 2018
    Also see here:
    http://www.excelfox.com/forum/showth...GoRoT-N0Nula-1
  1. Get External Data Error
    Last Post: 01-05-2013, 08:20 PM
  2. #Value Error in Working File
    By Suhail in forum Excel Help
    Last Post: 11-19-2012, 11:39 PM
  3. Swapping columns Error 2
    By jomili in forum Excel Help
    Last Post: 11-16-2012, 08:52 PM
  4. Excel Error
    By aarbuckle in forum Excel Help
    Last Post: 03-13-2012, 03:12 AM
  5. On Error Statement (Visual Basic)
    Last Post: 10-12-2011, 09:06 AM
