Application.Caller returns Range if VBA code is called from a Cell/Range.
e.g. If a UDF(User Defined Function) is called from a Cell/Range and one wants to get the address of the Cell/Range ,where it is called from.
Then it can be achieved using the following code and as in this case it returns Range so you can also set it to some object also.
Application.Caller returns String if the caller is some control (e.g. DropDown,ListBox and CommandButton etc.) or Shape.Code:Function Test() Dim objCaller As Object '/Range Set objCaller = Application.Caller Debug.Print objCaller.Address '/Application.Caller.address Test = objCaller.Address End Function
e.g. if the following function is called from some shape/control then it will print and return shape/control's name.
Application.Caller returns Error if the caller is a VBA procedure or function.Code:Function ControlCaller() Debug.Print Application.Caller ControlCaller= Application.Caller End Function
e.g if you call the above given function ControlCaller in some procedure or function then it will return an error.
Note: Application.Caller does not work in Immediate WindowCode:Sub CallIt() Call ControlCaller() End Sub
