Thread: Change Display Range Based On Change of Dropdown Values
    Dec 2012
    Greetings
    I have 3 options in a Dropdown List Box..Cold,Hot & Caustic...is it possible to achieve the following
    1. if i select "CAUSTIC" from dropdown list then it shows the 7 steps
    2. If i select "COLD"from dropdown list it only shows the STEP 1 (hides the rest of the steps)
    3. If i select "HOT" from dropdown list it only shows the First 3 STEPS (hides the rest of the steps)
    XL-2010
    Rich
    Mar 2013
    First Select from Step 2 to Step 7 and type this (=$AC$2="cold") formula in conditional formatting.
    And Select from Step 4 to Step 7 and type this (=$AC$2="hot") formula in conditional formatting.
    Finally, font and border and background color have must change to white color in conditional formatting.
    Member Charles's Avatar
    Aug 2012
    I used a Worksheet Change event for this.
    Any time you change the selection the data in the desired location with change.
    If you want to see all of the data you look at the code and then create another code that will display the
    Data. Or select "Caustic" and you will see all ot data. you can then change it if you wish.
    If you like the answer, please click " * " below Member name to say thanks.
  1. Replies: 1
    Last Post: 05-03-2013, 04:41 PM
  2. Replies: 8
    Last Post: 04-16-2013, 02:04 PM
  3. Change Number Written In Words To Numeric Values
    Last Post: 04-03-2013, 03:01 PM
  4. Save Workbook For Each Change Made In A Range
    By Stalker in forum Excel Help
    Last Post: 03-22-2013, 08:54 PM
  5. Change listbox value
    By Tony in forum Excel Help
    Last Post: 12-04-2012, 08:58 PM
