Results 1 to 8 of 8
Thread: Formula Following Order Of Calculation BODMAS
    Mar 2013
    Here is how i calculated
    Volume of discharges - 30 litres
    There is 3.6 litres of water added to the 30 litres
    Then
    100ml sample taken from the discharges (30+3.6) and then spun in a centrifuge = 60% solids in tube is the result
    Now if i remove the 3.6 litres of water i should get 67% solids...i used this below
    Calculated = 60*(30+3.5)/30
    I need to know if this is the correct answer and then how to set up in a spreadsheet please
    Thanks for any help
    Paul
    Mar 2013
    Using your formula in excel
    =60*(30+3.5)/30
    Gives the answer of 67.2.
    To put this into excel
    =60*(30+3.5)/30
    copy and paste this.
    Mar 2013
    Thanks Stalker
    Using the figures in my 1st post have i calculated the correct answer as well
    Mar 2013
    Please have i calculated the correct result
    Thank you
    Paul
    Mar 2013
    Hello, your first post has conflicting information, first you say
    then your calculation states
    Which i did not pick up on at first, i do apologise.
    If your data is 3.5 then the result is 67.0
    If your data is 3.6 then the result is 67.2
    Does that help?
    Mar 2013
    Thanks Stalker
    Yes that all makes sense
    I am just now enquiring if 60% is solid material and i remove the water that the solids now should be 67.2%...i now understand the calculation in Excel but am enquiring if the actual result is the correct answer.....with all the figures used above i need to know if removing the water from the sample will now be 67.2% solids instead of 60% with water
    Thanks again
    Mar 2013
    Hi Paul_P,
    The mathematics behind it are sound.
    = 60*(30+3.5)/30
    Excel will do the following calculations:
    30+3.5 = 33.5
    60*33.5 = 2010
    2010/30 = 67
    -or-
    30+3.6= 33.6
    60*33.6= 2016
    2016/30 = 67.2
    The equation in brackets will be handled first by excel.
    Mar 2013
    Hi Stalker
    Thanks for your help
    Appreciated
    Paul
  1. Hours Calculation between two times
    Last Post: 11-21-2012, 05:04 PM
  2. List of files in chronological order
    Last Post: 11-12-2012, 10:16 PM
  3. Unique Random Number In Ascending Order
    Last Post: 11-04-2012, 04:15 PM
  4. Replies: 11
    Last Post: 10-07-2012, 12:05 AM
  5. Calculation with different condition in a cell
    Last Post: 04-04-2012, 08:38 AM
