Thread: Extract Numeric Value From Alphanumeric Text Using VBA RegExp
    Lightbulb Extract Numeric Value From Alphanumeric Text Using VBA RegExp
    In continuation to the Excel formula based solution given at http://www.excelfox.com/forum/f13/ex...eric-text-186/, here's one using VBA regular expression
    Function ExtractNumFromAlphaNum(strAlNum As String) As Long
        Const strPatter As String = "[\d+]"
        Dim var, strOutput As String
        With CreateObject("vbscript.regexp")
            .Pattern = strPatter
            .Global = True
            Set var = .Execute(strAlNum)
            For Each var In var
                strOutput = strOutput & var
            Next var
        ExtractNumFromAlphaNum = strOutput
    Function ExtractNumFromAlphaNum(strAlNum As String) As Variant
      ...<<snip>>
    You should change your function's declared data type to Variant as I show in red above in order to stop the error that is generated when an argument containing no digits is passed into the function.
    From my standpoint, I do not think using the heavy "machinery" of the Regular Expression engine is necessary for such a simple requested functionality; here is a Function using standard built-in VBA functions that will do the same thing (note I changed the function's name to something easier to type)...
    Function GetDigits(strAlNum As String) As Variant
      Dim X As Long
      For X = 1 To Len(strAlNum)
        If Mid(strAlNum, X, 1) Like "#" Then GetDigits = GetDigits & Mid(strAlNum, X, 1)
    I like the way you term it 'heavy machinery'... I completely agree.... It's just that I wanted to share a simple method to show how this bazooka can be used.
  1. Extract Number From Alphanumeric Text
    Last Post: 09-11-2013, 10:14 PM
  2. Extracting Numeric Values From Alphanumeric Text
    Last Post: 03-21-2013, 12:04 PM
  3. Replies: 2
    Last Post: 09-24-2012, 09:20 PM
  4. Extract numbers from alphanumeric values
    By tushar.tarafdar in forum Excel Help
    Last Post: 09-20-2012, 10:16 PM
    Last Post: 02-29-2012, 08:24 PM
