Results 1 to 9 of 9
Thread: Excel showing "Not responding"
    Apr 2011
    If I do very time consuming calculations (by VBA code) - then after very little time - Excel shows "Not responding". I get around that by having a counter - and then updating my application.statusbar property with a counter in brackets - so now it no longer give me the "Not responding message". So that is all good - however after 2 hours of so the statusbar stops updating - I simply get the circular "hourglass" - I can see that the application is still running (using windows 7 - can place my mouse on the taskbar on the buttom and it shows "running") - so if I let it keep on trucking - it will eventualy finish. I also know my application is still running by using Ctrl+Break - then debug. If I force the application.statusbar - then it become active again.
    Any idea how I can force the application.statusbar to remain live and not fall asleep?
    xl2007 - Windows 7
    xl hates the 255 number
    A wild guess. Add DoEvents.
    Or use
    With Application
    .ScreenUpdating=Not .ScreenUpdating:.ScreenUpdating=Not .ScreenUpdating
    Apr 2011
    I will try that thanks
    xl2007 - Windows 7
    Any updates?
    Apr 2011
    Was out of town - have not tried yet - But I will for sure
    xl2007 - Windows 7
    Apr 2011
    Fox
    Tried the screenupdating - thanks for trying - did not do the trick. I will put that on the hook - then fix it at the end of it all. I did not try the do event suggestion. I have never done a do event before.
    xl2007 - Windows 7
    You'll have to do that at the beginning and ending of the loop (if you are using one that is)
    Apr 2011
    hmmm - had this working - so as long as the activesheet has focus - It keeps updating. However if I switch to i.e. my email and then come back to xl2007 - it appears to have hung up (statusbar does not update) - however if I let it continue - it does finish. Dont waste time on it - just one of Excels quirks. I think it manages memory very badly. But I do appreciate all the help. Even if I am slow at answering at times.
    xl2007 - Windows 7
  1. VBA Versions of my "Get Field" and "Get Reverse Field" formulas
  2. Reversing a "First Middle Last" Name to "Last, First Middle" Name Format
    Last Post: 01-06-2014, 10:04 PM
  3. Replies: 5
    Last Post: 04-18-2013, 02:30 AM
  4. Follow-up to "Excel Number Format: Indian Style Comma Separation"
    Last Post: 04-14-2012, 10:46 PM
  5. Ordinal Suffix (i.e., "st", "nd", "rd" and "th")
