Thread: Extracting Numeric Values From Alphanumeric Text
    Question Extracting Numeric Values From Alphanumeric Text
    I need to extract numeric values from a cell with alphanumeric or having other character to another cell.
    There is no specific format of the cell.
    I have the similar cells in thousands.
    For eg:
    A1: ab2hgi;234kjf8r
    Result:
    22348
    Jan 2012
    Here is a macro that you can try...
    Sub ReduceToNumbersOnly()
      Dim X As Long, Z As Long, LastRow As Long, Strng As String, vArr As Variant
      Const FirstOutputCell As String = "B2"
      Const DataColumn As String = "A"
      Const StartRow As Long = 2
      LastRow = Cells(Rows.Count, DataColumn).End(xlUp).Row
      vArr = Cells(StartRow, DataColumn).Resize(LastRow - StartRow + 1)
      For X = 1 To UBound(vArr)
        Strng = ""
        For Z = 1 To Len(vArr(X, 1))
          If Mid(vArr(X, 1), Z, 1) Like "#" Then Strng = Strng & Mid(vArr(X, 1), Z, 1)
        vArr(X, 1) = Strng
      Range(FirstOutputCell).Resize(UBound(vArr)) = vArr
    The only thing you need to do is change the three constants (the Const statements) to match your actual layout. You can set the FirstOutputCell constant to your first data cell if you want to overwrite your original data with the numbers contained within them.
  1. Replies: 6
    Last Post: 06-01-2013, 03:24 PM
  2. Replies: 14
    Last Post: 05-25-2013, 06:55 AM
  3. Replies: 2
    Last Post: 03-21-2013, 08:51 PM
  4. Replies: 2
    Last Post: 09-24-2012, 09:20 PM
    Last Post: 02-29-2012, 08:24 PM
