Thread: Lookup From Cell Range By Matching Row and Column
    Mar 2013
    Hello All,
    I have attached a sheet where i need formulas or maybe a Lookup function to achieve result.
    1. I enter a solid number from Row 9 into J3 (merged cell)
    2. I enter a FILL numbers from Column B into J4 (merged cell)
    3. The result should then show 91 in cell J4 (merged cell)...which formula or Lookup function do i use?
    Paultable.xlsx
    Try this... =INDEX($F$12:$AP$35,MATCH(J4,$B$12:$B$35,0),MATCH( J3,$F$9:$AP$9,0))
    Mar 2013
    Thank you Excel Fox
    Appreciated
  1. Replies: 4
    Last Post: 06-01-2013, 01:08 PM
  2. Highlight Active Cell’s Row and Column
  3. Replies: 7
    Last Post: 04-21-2013, 07:50 PM
  4. Replies: 4
    Last Post: 02-22-2013, 02:24 AM
  5. Copy Row To A New Sheet If A Value Found In Adjacent Column
    Last Post: 08-17-2012, 05:42 PM
