Thread: Enter SUM SUMIFS Formula Using VBA
    Feb 2013
    Hello,
    The function below works perfectly in a spreadsheet; however I would like to enter it as VBA code. As you can see, there are two columns with multiple conditions and one column with a single condition. Thanks in advance. - Rick
    =SUM(SUMIFS($ER$11:$ER$100000,$C$11:$C$100000,{"00 002","00942","00102","00302"},$J$11:$J$100000,{"A" },$K$11:$K$100000,{"S";"N";"M";"P";"X"}))
    is this what you need?
    SomeRange.Formula = "=SUM(SUMIFS($ER$11:$ER$100000,$C$11:$C$100000,{""00 002"",""00942"",""00102"",""00302""},$J$11:$J$100000,{""A""},$K$11:$K$100000,{""S"";""N"";""M"";""P"";""X""}))"
    Feb 2013
    Yes, thank you.
    The double quotes threw me off. It works fine in VBA.
  1. Sum Of The Digits In A Cell Using Formula
    By venkat1926 in forum Excel Help
    Last Post: 04-30-2013, 07:11 PM
  2. Replies: 11
    Last Post: 04-07-2013, 07:51 PM
  3. Sum Ifs Formula needed with Max Date range
    By trankim in forum Excel Help
    Last Post: 09-19-2012, 09:50 AM
  4. SUMIFS multiple criteria from same column
    Last Post: 06-30-2012, 01:56 PM
    Last Post: 03-31-2012, 10:46 PM
