Thread: Hide/Unhide Columns with Listbox
    May 2011
    In the Listbox, for example i select the months of January, March and December, I want only show me the columns with the name of the selected months in the row 10 and the other columns are hidden.
    Can you help me?
    Greetings.
    Hi obed_cruz
    Welcome to ExcelFox
    Use this in the userform
    Private Sub MOSTAR_MES_Click()
    Dim rngCell As Range
    Dim rngUnion As Range
    Dim lngListLoop As Long
    Dim strMostar As String
    For lngListLoop = 0 To ListBox1.ListCount - 1
        If ListBox1.Selected(lngListLoop) Then
            strMostar = strMostar & "|" & ListBox1.List(lngListLoop)
    Next lngListLoop
    Application.Calculation = xlCalculationManual
    For Each rngCell In Range("D10:SP10")
        If InStr(1, strMostar, "|" & Trim(rngCell.Value)) Then
            If Not rngUnion Is Nothing Then
                Set rngUnion = Application.Union(rngUnion, rngCell)
                Set rngUnion = rngCell
    Next rngCell
        Range("D10:SP10").EntireColumn.Hidden = True
        rngUnion.EntireColumn.Hidden = False
    Application.Calculation = xlCalculationAutomatic
    May 2011
    Thanks Excel Fox,
    The code works perfectly.
    Congratulations on your wonderful forum.
    Grettings
  1. Maximum columns in a ListBox
    Last Post: 05-04-2020, 12:44 PM
  2. VBA To Hide And Unhide Rows
    Last Post: 05-08-2013, 03:14 AM
  3. Change listbox value
    By Tony in forum Excel Help
    Last Post: 12-04-2012, 08:58 PM
  4. Hide and Unhide Rows and Columns
    Last Post: 05-11-2011, 12:00 AM
    Last Post: 05-06-2011, 02:59 AM
