Thread: Print VBA cancel command not working
    Oct 2012
    Hi all,
    I use the following code to print a worksheet.
    Private Sub CommandButton3_Click()
    If Application.Dialogs(xlDialogPrinterSetup).Show = False Then Exit Sub
    Sheets("INPUT WV").PrintOut
    I can cancel the dialogprintersetup without any error. But when i try to cancel e.g. the pdf save as dialog when i choose a pdf printer it gives me a runtime error and point to the Sheets("INPUT WV").PrintOut. When i save the pdf everything is just fine.
    Regards,
    That's because you are not going ahead with the print, and cancelling it after you select the printer. I'd just put in an
    statement before that line
  1. Replies: 2
    Last Post: 04-17-2013, 11:53 PM
  2. Print Nth Worksheet To Mth Worksheet using VBA
    By Ryan_Bernal in forum Excel Help
    Last Post: 02-28-2013, 06:57 PM
  3. VBA - Split command
    Last Post: 09-15-2012, 06:26 AM
  4. Replies: 7
    Last Post: 08-08-2012, 10:24 AM
  5. Print Selective Area
    By r_know in forum Excel Help
    Last Post: 06-21-2012, 11:09 PM
