Hi everyone.
I'm working on a script for a while know. Everything works fine except that the updating goes very slow.
I use the code below. I have a excel sheet with a range from A8:H282. When i use the update button it takes about 2 second before the new value has been listed and updated.
The other thing is that when the listbox has been loaded the scrollbox is very very long. So it displays the range but i can scroll a lot of white space after the listed range.
Update buttonCode:Private Sub UserForm_Initialize() Dim x As Long Dim k As Long Dim j As Long Dim rng As Range Set rng = Sheets("INPUT WV LISTBOX").Range("A8:H282") Rx1 = 8 With ListBox1 .RowSource = "" For k = 1 To rng.Rows.Count 'rows For j = 1 To rng.Columns.Count .AddItem .List(k - 1, j - 1) = rng.Cells(k, j).Text 'columns Next j, k End With For j = 1 To 8 Me.Controls("TextBox" & j).Text = "" Next j End Sub
Code:Private Sub CommandButton2_Click() Dim j As Long Dim x As Long If Me.ListBox1.ListIndex = -1 Then MsgBox "No Data Selected" Exit Sub End If If Me.TextBox1.Value = "" Then Exit Sub Rx1 = Rx1 + Me.ListBox1.ListIndex 'row index With Sheets("INPUT WV LISTBOX") For j = 3 To 8 'columns Start in Column 4 but you wish to NOT change ' columns 4 through 7 so start in Column 8 .Cells(Rx1, j).Value = Me.Controls("TextBox" & j - 0).Text Next j End With Call UserForm_Initialize End Sub
