Thread: Copy cells from Sheet2, paste to next blank row in Sheet1
    Aug 2012
    Hi.
    the code below, demand data "Sheet1" with discretion in "Sheet2"
    to find it overrides the value of "Sheet2" and put in "Sheet1"
    Sub Macro1()
        Dim rngCell As Range
        Dim lngMatchRowNum As Long
        With Sheets("Sheet1")
            For Each rngCell In .Range("A2", .Range("A" & Rows.Count).End(xlUp))
                If (IsError(Evaluate("VLOOKUP(" & Sheets("Sheet1").Range(rngCell.Address(False, False)) & ",Sheet2!A:A,1,FALSE)"))) = False Then
                    lngMatchRowNum = Evaluate("MATCH(" & Sheets("Sheet1").Range(rngCell.Address(False, False)) & ",Sheet2!A:A,0)")
                    .Range("B" & rngCell.Row & ":F" & rngCell.Row).Value = Sheets("Sheet2").Range("B" & lngMatchRowNum & ":F" & lngMatchRowNum).Value
            Next rngCell
        MsgBox "Todos os registros aplicáveis já foram atualizados."
    Now what I need is:
    If the value of "Sheet2" not found in "Sheet2" so that the value
    the "Sheet2" is inderido the next empty line (below) of "Sheet1"
    Try
    Sub kTest()
        Dim x, K1 As Range, K2, i As Long, r As Long
        Set K1 = Sheet1.Range("a1").CurrentRegion.Columns(1)
        K2 = Sheet2.Range("a1").CurrentRegion.Value2
        r = K1.Rows.Count
        For i = 2 To UBound(K2, 1)
            x = Application.Match(K2(i, 1), K1.Value2, 0)
            If IsError(x) Then
                K1.Cells(1).Offset(r).Resize(, UBound(K2, 2)) = Application.Index(K2, i, 0)
                r = r + 1
    Aug 2012
    Hi.
    Was grerat!!
    Thank you!!
  1. Replies: 13
    Last Post: 09-24-2012, 11:19 PM
  3. VBA -- Copy/Paste across sheets
    Last Post: 09-21-2012, 02:07 PM
  4. Highlighting Blank Cells
    Last Post: 08-13-2012, 07:56 AM
  5. Trapping Copy To Range Before Copy/Cut Paste
    Last Post: 04-07-2011, 07:48 PM
