Results 1 to 8 of 8
Thread: Summing Data based on certain criteria
    Apr 2012
    I would like to add the data highlighted in Col A, which I have named "other_Income". The values applicable to these items are in Columns F, I & J
    I have used the sum function to show you what the answer should be. Could one use a range name and then an offset function to add the values based on the criteria or use sumifs?
    It would be appreciated if you could assist me with a formula to add a series of data based on crieria such as this.
    Create a new Defined Name that consist of the entire rows of 3:5,7,11:12 and name it OI (short for Other Income), then try this formula (those single spaces between OI and the column designations are on purpose)...
    =SUM(OI F:F,OI I:I,OI J:J)
    Apr 2012
    Hi Rick
    Thanks for the help, much appreciated. First time I've come accross this formula-very clever
    Regards
    Howard
    Quote Originally Posted by Howardc View Post
    Hi Rick
    Two ranges separated by a single space returns the intersection of the two ranges. And, now that I think of it some more, we can take advantage of the fact that Columns I and J are contiguous and shorten the formula to this...
    =SUM(OI F:F,OI I:J)
    And, of course, instead of using my OI defined name, you can simply change your Other_Income defined name to be the entire rows and use that in place of my OI if you are not using Other_Income anywhere else in your workbook.
    You could try this Array formula.
    =SUM(IF(ISNUMBER(MATCH(A3:A13&"",A20:A25&"",0)),IF (ISNUMBER(MATCH(F1:J1,B20:B22,0)),F3:J13)))
    where
    A20:A25 - Other income criteria,
    B20:B22 - the months
    =SUM(OI F:F,OI I:J)
    Wow ! nice one Rick, I have never seen this before.
    Apr 2012
    Hi Guys
    Thanks for the help and explanations, much appreciated
    great trick
  1. Replies: 4
    Last Post: 05-05-2013, 04:01 AM
  2. Split data based on criteria
    By Mahesh.sreekakulam in forum Excel Help
    Last Post: 06-08-2012, 09:30 PM
  3. Replies: 7
    Last Post: 03-06-2012, 07:49 AM
  4. Lookup Based on Criteria
    By maruthi in forum Excel Help
    Last Post: 02-15-2012, 08:49 AM
  5. Find Value Based On Criteria
    Last Post: 07-30-2011, 10:27 AM
