Thread: First Letter From Words VBA - Acronymize
    May 2011
    Hello Everyone,
    How qualify a specific problem in excel file with a formula, including a formula in formulas already existing or with vba?
    I join a file where the problem is : SPREADSHEET EXEMPLE.xlsx. I need to qualify cells from "A2" to "A31". The results in "AE", or/and "AF" or/and "AG" should be true.
    There is severals formulas in cell "A2" when you press crtl + F3. There are 3 others formulas active in AE,AF,AG.
    The problem is to include a formula like in AH, initials of the names in the first colomn, to say it's ok to qualify email or/and website.
    I don't know if it's possible with excel formulas or vba.
    Thanks a lot for your kindly help,
    Cheers,
    Try this in a code module, and use in formula
    Function ACRONYMIZE(rng As Range) As String
        Dim lng As Long
        For lng = 0 To UBound(Split(Trim(rng.Text), " "))
            ACRONYMIZE = ACRONYMIZE & Left(Split(Trim(rng.Text), " ")(lng), 1)
        Next lng
    Example = ACRONYMIZE(A2)
        Dim lng As Long
        Next lng
    Using the UBound function where I have highlighted in red does not help in making sure the acronyms returned by the function will be all upper case letters. Also, I think it would be better to use the WorksheetFunction's Trim function instead of the VB Trim function as that would reduce multiple contiguous spaces down to single spaces and avoid having to try to trim individual words in the loop. Finally, my preference for text processing functions is to make the text argument a String rather than a Range... doing this would allow the function to be more easily used by other VB code and still not affect the functionality when used as a UDF. This is how I probably would have written your ACRONYMIZE function...
    Function ACRONYMIZE(S As String) As String
         Dim X As Long, Words() As String
         Words = Split(UCase(WorksheetFunction.Trim(S)))
         For X = 0 To UBound(Words)
             ACRONYMIZE = ACRONYMIZE & Left(Words(X), 1)
  1. Converting a Column Number to a Column Letter
    Last Post: 12-17-2012, 02:29 AM
  2. Replies: 11
    Last Post: 10-07-2012, 12:05 AM
  3. Replies: 4
    Last Post: 09-26-2012, 09:04 AM
  4. Spell a Date out in Words
    By Rick Rothstein in forum Excel and VBA Tips and Tricks
    Last Post: 02-25-2012, 08:49 PM
  5. Number to Words (Rupees)
    By sa.1985 in forum Excel Help
    Last Post: 12-16-2011, 08:57 PM
