Thread: Need a way to conditionally format a cell based on an adjacent cells value.
    Aug 2012
    Is there a non-macro method to conditionally formatting a cell based on the value of the cell above it? For example; A1's could be Tom, Dick, or Harry but I need A2 to be colored red if A1 is Tom, Blue if A1 is Dick, and Green if A1 is Harry.
    If there's not a non-macro method, then I gotta give in and ask how this would be coded. Trying to avoid it but if not, cest la vie.
    Thanks in advance for the help!
    Member mrmmickle1's Avatar
    Sep 2012
    Conditional Format
    Orestees,
    Look at Sheet 1 in the attachment.
    Go to conditional formatting on the Home Tab. Then Click.
    Go to Manage Rules then Click.
    You should understand what to do from there.
    Using Excel 2010
    Aug 2012
    Awesome, I just really needed to take a look at it, thanks. I first tried changing the 'applies to' formula to =$A$2, but it changed all of the rules to match A2's. So I went back in to the rules and changed them back to A1's and left the 'applies to' formula as =$A$2 and it kept it. Now A2 highlights based on A1's value. Thanks for the very helpful nudge!! Again, you are a live saver!
  1. Replies: 15
    Last Post: 06-04-2013, 07:02 PM
    Last Post: 05-30-2013, 07:28 PM
  3. Replies: 4
    Last Post: 02-22-2013, 02:24 AM
  4. Replies: 1
    Last Post: 08-21-2012, 07:36 PM
  5. Format Cells Based on Given Input
    Last Post: 08-23-2011, 11:19 AM
