Results 1 to 10 of 11
Thread: Feed / Post Data on Web Page Using VBA
    Oct 2012
    Exclamation Feed / Post Data on Web Page Using VBA
    Thru vba i am trying to open multiple webapage one by one & post a message in form & click submit button.
    How this can be done without opening IE or with navigation option in IE.
    Post command used by webpage is as follows:
    <form method="POST" action="community/book_update.asp" onsubmit="return FrontPage_Form2_Validator(this)" language="JavaScript" name="
    <textarea rows="5" name="np_scrap_message" cols="55"></textarea><br class="
    <input type="hidden" value="97039" name="
    <input type="submit" value="Leave Message" name="
    </form>
    Vaibhav, do you want to do this without the user knowing that IE is open? Of course you have to open a web browser, although invisible!
    Oct 2012
    Any how will be fyne!!
    Thx for reply!
    Can you send the link to this web page? And exactly what you want to do.
    Oct 2012
    I am trying tp webpage one by one & then there on webpage there is a message box where i have to paste message & click on submit.
    code to execute manually is submitted above.
    i cant share web link since only member is allowed to login.
    Thanks!!
    The below code is just a basic way of doing a simple operation using VBA and IE. Without the actual weblink, it's hard to provide an exact solution....
    Dim IE as Object
    Set IE = CreateObject("InternetExplorer.Application")
    IE.Navigate "http://www.yourwebsite.com/form.aspx"
    Do Until IE.LocationURL = ""
        DoEvents
    Loop
    Do Until IE.ReadyState = 4
        DoEvents
    Loop
    IE.document.Forms("NameOfForm").elements("TextBox").Value = "Message Here"
    IE.document.Forms("NameOfForm").elements("Submit").click
    IE.Quit
    Also, search for
    getElementsByTagName
    getElementByID
    on the net. Might give you some clue....
    Oct 2012
    Thanks a ton. I will check & revert on the same!!
    Oct 2012
    working superb, Thanks!!
    Oct 2012
    Just one more request, insted of closing IE in the end is it possible to open webpage in new TAB.
    My code goes here..
    Sub go()
    Dim IE As Object
    Dim rngRange As Range
    Dim rngCell* As Range
    Set rngRange = Application.InputBox(prompt:="Please select a range with your Mouse.", _
                   Title:="SPECIFY RANGE", Type:=8)
    For Each rngCell In rngRange
    IE.Navigate rngCell.Value
        DoEvents
    Loop
    'Do Until IE.ReadyState = 4
    '    DoEvents
    'Loop
    IE.Visible = True
    IE.document.forms("Form1").elements("text").Value = ActiveSheet.Range("B2").Value '"Message Here"
    IE.document.forms("Form1").elements("submit").Click
    IE.Quit
    Next rngCell
    Thansk once again.
    Oct 2012
    Opps one more probz..... Too many session of IE remains open in background!!
    And i am getting Run Time Error 91..
    Plz help!!
    Thanks!
  1. Click On Web Link VBA
    Last Post: 12-11-2012, 09:31 PM
    Last Post: 09-08-2012, 10:50 PM
  3. Navigate Through Web links and get data
    By maruthi in forum Excel Help
    Last Post: 02-10-2012, 06:22 PM
  4. Executing XLSM file on a web page
    Last Post: 12-17-2011, 05:38 AM
  5. Capture values from IE page
    Last Post: 11-22-2011, 08:25 AM
