Thread: require formula help to copy data from sheet to sheet
    Dec 2012
    I need a little help. I have a spreadsheet that has lots of data that gets updated weekly.
    Currently i filter the data and copy the parts i want, to other worksheets, however this is very time consuming. I do have some restrictions due to the fact that i work on a government system. I need to use formulas no VB.A Can you help me?
    I have a simple example
    the worksheet has different types of animals with size, type, color and tabs that match the animals. I need the entire row(S) to be copied
    can you help me create a formula that sorts the animals in column A and then copies the sorted ROWS to the tabs that match
    Member Charles's Avatar
    Aug 2012
    Terry,
    Welcome to the forum.
    I'm not a "Formula" person. But I know it can be done with code.
    Perhaps another member with Formula knowledge can address this to you.
    It may help if you can attach a redacted copy of the workbook so we get get a better ideal as to help you.
    I don't think if there is any way to filter data using formula only. Can do easily with the help of macro.
  1. Replies: 1
    Last Post: 05-19-2013, 02:37 PM
    Last Post: 03-21-2013, 10:38 PM
  3. Dynamic Worksheet Generator Sheet Copy
    By mfaisalrazzak in forum Excel Help
    Last Post: 03-01-2013, 05:38 PM
  4. Replies: 1
    Last Post: 02-10-2013, 06:21 PM
  5. Copy selected data to other excel sheet
    By dhiraj.ch185 in forum Excel Help
    Last Post: 02-02-2012, 06:23 AM
