Thread: Worksheet Change Event
    Dec 2012
    Dear Gurus,
    i have question, can a macro be run if a particular cell value would be changed?
    for instance Cell A2 Value is = Interim Report and if the value is changed to Final Report then a macro should run for instance a msgbox to pop "Text Changed"
    would this be possible?
    thanks.
    Step1:- Right click on sheet1 tab and click on View code
    Step2:- Paste below code
    	    If Target.Address(0, 0) = "A2" Then
    	        MsgBox "Text changed.", vbInformation, "Text changed message..."
    Dec 2012
    Pandey,
    this was very helpful. you should be MVP of excel. thanks very much. Happy New Year!
    Quote Originally Posted by LalitPandey87 View Post
  1. Replies: 8
    Last Post: 04-16-2013, 02:04 PM
  2. Change Display Range Based On Change of Dropdown Values
    Last Post: 03-29-2013, 04:58 AM
  3. Print Nth Worksheet To Mth Worksheet using VBA
    By Ryan_Bernal in forum Excel Help
    Last Post: 02-28-2013, 06:57 PM
  4. Worksheet_Change event
    By Excelfun in forum Excel Help
    Last Post: 11-21-2012, 07:24 AM
  5. help with after insert event in Access 10
    By richlyn in forum Access Help
    Last Post: 03-03-2012, 10:49 PM
