Thread: Excel 97 2003 File Created In 2007 Does Not Work In 2003
    Nov 2012
    Hi friends,
    caught in a labyrinth from which I can not go. Attachment, which is the big macro problem:
    On my PC excel file works flawlessly. How: pressing the macro searches for a match in column E42: Well according to demand and make a new sheet and the information it carries, but it is on my computer when I go to work does not work, but the file is actually the same. the other thing is that it starts from the branch down D42 cells than other countries and D are hidden.
    Then look in column E42: E -> DB + number (BD 1000, BD 2000, BD ................... BD9000; ......... BD42000 ..........) then make a new worksheet name (BD1000 and so for all others) and transfer the entire column (columns) of D41:BB41 and down. As an introduction to the pictures you will see.
    Nov 2012
    Hi friends,
    I submitted a working macro that somewhere must be touched to my work. Nobody can respond and help me, it is very difficult to implement??
    Nov 2012
    Hi friends,
    Is it possible that no one can help me?
    I very urgently, and no one responds, you can even write another code, I have no explanation for why so gets home office is 2007 in my work office 2003 but the macro works like office 2003. I checked and everything is included libraries, everything that does not jeopardize my job, but .......
    I checked the code (in 2007), and it doesn't seem to have any code that may not work in 2003. Anyway, I've made a minor modification in the code.
    Option ExplicitOption Base 1
    Sub ContractListt()
        Dim AllCells As Range
        Dim cell As Range, Rng As Range
        Dim NoDupes As New Collection
        Dim lrow As Long, Rlrow As Long
        Dim Myval As Integer
        Dim wks As Worksheet
        Dim Item As Variant
        Dim Hdrarray As Variant
        Dim cnt As Long
        Dim Ctempws As Worksheet
        Set Ctempws = Sheets("Template")
        lrow = Sheets("BD").Range("E" & Rows.Count).End(xlUp).Row
        Set AllCells = Range("E42:E" & lrow)
        For Each cell In AllCells
            NoDupes.Add cell.Value, CStr(cell.Value)
        Next cell
        For Each Item In NoDupes
            Range("D41:BB41").Select
            Selection.AutoFilter
            With Selection
                .AutoFilter Field:=2, Criteria1:=Item
            Set Rng = ActiveSheet.AutoFilter.Range
            Myval = Range("D42:D" & lrow).SpecialCells(xlCellTypeVisible).Count
            Rlrow = Sheets(Item).Range("D" & Rows.Count).End(xlUp).Row + 1
            If Err = 9 Then
                Ctempws.Copy after:=Worksheets(Worksheets.Count)
                ActiveSheet.Name = Item
                With Sheets(Item)
                    Rlrow = .Range("D" & Rows.Count).End(xlUp).Row + 1
                    Rng.Offset(1, 0).Resize(Rng.Rows.Count - 1).Copy
                    .Cells(Rlrow, 4).PasteSpecial xlValue
                    Application.CutCopyMode = xlCopy
                    Sheets(Item).Cells.EntireColumn.AutoFit
                    Sheets(Item).Range("D41").Select
                    Sheets("BD").Activate
                Sheets(Item).Cells(Rlrow, 4).PasteSpecial xlValue
                Sheets(Item).Range("D42").Select
        Next Item
    Can you check if you've enabled macro (ie, the macro security should not be high)
  1. Excel 2003 Classic Menu in Excel 2007-2010
    By Excel Fox in forum Classic Menu
    Last Post: 09-10-2014, 10:29 PM
  2. Replies: 1
    Last Post: 03-07-2013, 11:42 AM
  3. Replies: 1
    Last Post: 02-14-2013, 11:08 AM
  4. Version 2003 to 2007
    By PcMax in forum Excel Help
    Last Post: 11-23-2011, 07:52 PM
  5. Excel 2003 Classic Menu for 2007-10
    By Admin in forum Greetings and Inception
    Last Post: 09-09-2011, 11:51 PM
