Results 1 to 10 of 36
Thread: Distribute ranges as per Plan
  1. #10
    Member ayazgreat's Avatar
    Mar 2012
    Charles I really appreciate your effort but the problem is still same, I, maybe, can not make you understand what kind of result I want to have if say to you that if a range start from 1027244000 and ends to 10027246187 = Qty 2188 then as per my data range distribution is like that
    my sample
    IDs Start Range End Range Qty
    A 1027244000 1027244443 444
    B 1027244444 1027244943 500
    C 1027244944 1027245043 100
    D 1027245044 1027245287 244
    E 1027245288 1027246087 800
    H 1027246088 1027246187 100
    in your result why next distribution range is not changed
    A 1027244000 1027246187 444
    B 1027244000 1027246187 500
    C 1027244000 1027246187 100
    D 1027244000 1027246187 244
    E 1027244000 1027246187 800
    H 1027244000 1027246187 100
    Why Start Number and End Number is same of ID B,C,D,E,H as same of ID A ? Why isn't range changed after a next ID as per its Plan given Qty, it should be distributed like I am mentioning in my result.
    See my attached workbook how am I distributing the same through a formula only for a single range like I have mentioned above range distribution.
  1. Replies: 5
    Last Post: 05-28-2013, 03:00 AM
  2. Intersection of Overlapping Ranges:Space Operator
  3. List all the name ranges in an excel sheet with scope
    Last Post: 03-28-2012, 07:27 AM
  4. Delete Name Ranges by Scope VBA
    Last Post: 12-20-2011, 03:54 AM
  5. List Unique/Common Values From Two Ranges
    Last Post: 09-16-2011, 08:34 AM
