Thread: VBA Code to extract subtotals
Howardc VBA Code to extract subtotals 11-30-2012, 09:57 PM
Charles HI, The following code may... 12-02-2012, 02:06 AM
Howardc Hi Charles Thanks for the... 12-02-2012, 01:15 PM
    Apr 2012
    I am looking for VBA code to extract the row number and sub-total in Col B in sheet 1, where the value is not zero for eg if the sub-total value is for eg 50, -50 etc., but to ignore zeroes
    I would like row numbers containing the sub-total values that are not zero to be extracted to sheet2.
    I have manually extracted the Row # in Col A and the value in Col B on Sheet2 to give an idea of what the extraction must look like
    Your assistance in this regard is most appreciated
    Member Charles's Avatar
    Aug 2012
    HI,
    The following code may help.
    Sub Total_Extraction()
    Dim c As Variant
    Dim Ffind As Long
    Dim Slrow As Long
    ''' Doing seach for the formula "SubTotal ''
    With Sheets("Sheet1").Range("B1:B" & Sheets("Sheet1").Range("B65536").End(xlUp).Row)
        Set c = .Find("SUBTOTAL", Lookat:=xlPart)
        If Not c Is Nothing Then
            '''' get row nr and Value in cell copy to sheet2 ''
            Ffind = c.Row
            '' See if value < 0 '' if it is finish code''
            If Cells(c.Row, 2).Value < 0 Then
                Slrow = Sheets("Sheet2").Range("A65536").End(xlUp).Row + 1
                Sheets("Sheet2").Range("A" & Slrow).Value = c.Row
                Sheets("Sheet2").Range("B" & Slrow).Value = Sheets("Sheet1").Cells(c.Row, 2).Value
            Do
                Set c = .FindNext(c)
                If c.Row = Ffind Then Exit Sub
            Loop While c.Row <> Ffind
    Apr 2012
    Hi Charles
    Thanks for the help, much appreciated
    I made one small change , I needed to include positive and negative calues <> zero -see snippet of code below
    If Cells(c.Row, 2).Value <> 0 Then ....
    If Cells(c.Row, 2).Value <> 0 Then .....
    Are there any good VBA books your can recommend for novices?
  1. VBA To Extract Email Address From Text
    By dunndealpr in forum Excel Help
    Last Post: 06-05-2019, 03:56 PM
  2. Calculating Subtotals Within Groups of Data Using UNION
    Last Post: 05-24-2013, 11:54 AM
  3. Replies: 2
    Last Post: 03-21-2013, 08:51 PM
  4. VBA Code to Extract data
    Last Post: 07-24-2012, 11:37 PM
  5. VBA Function To Extract Decimal Numbers
    By PcMax in forum Excel Help
    Last Post: 11-19-2011, 09:42 PM
