Results 1 to 8 of 8
Thread: Offset based on Values in Column E
  1. #5
    Member mrmmickle1's Avatar
    Sep 2012
    Troubleshooting Code with Error in Process
    After using the below code for a few days I have realized that it is not functioning properly in regards to one value: "Pre Test" When this value is found instead of inserting the value: "Gate 1" as I anticipate it inserts "Gate 2". I am unsure of why this is happening. I need it to insert "Gate 1" as later in the code I use this value to Outline the data into groups.
    Here is the code and file I am having trouble with:
    ub FormatQuantumDataDumpCS()
    ' Rearranges Data into the correct format and inserts correct titles for Header Row
        Columns("B:E").Select
        Selection.Delete Shift:=xlToLeft
        Columns("C:N").Select
        Columns("D:E").Select
        Columns("F:J").Select
        Columns("I:AA").Select
        Range("A1").Select
        ActiveCell.FormulaR1C1 = "W/O #"
        Columns("D:D").Select
        Selection.Cut
        Columns("B:B").Select
        Selection.Insert Shift:=xlToRight
        Selection.Cut
        Columns("C:C").Select
        Range("C1").Select
        ActiveCell.FormulaR1C1 = "Model"
        Columns("E:E").Select
        Selection.Cut
        Range("E1").Select
        ActiveCell.FormulaR1C1 = "Date In"
        Columns("G:G").Select
        Selection.Cut
        Columns("F:F").Select
        Range("F1").Select
        ActiveCell.FormulaR1C1 = "Date Quoted"
        Columns("H:H").Select
        Selection.Cut
        Range("G1").Select
        ActiveCell.FormulaR1C1 = "Date App"
        Selection.Insert Shift:=xlToRight, CopyOrigin:=xlFormatFromLeftOrAbove
        Columns("I:I").Select
        Range("H1").Select
        ActiveCell.FormulaR1C1 = "Ship Date"
        Range("I1").Select
        ActiveCell.FormulaR1C1 = "Cost Analysis"
        Range("J1").Select
        ActiveCell.FormulaR1C1 = "Revenue"
        Range("K1").Select
        ActiveCell.FormulaR1C1 = "Margin"
        Range("L1").Select
        ActiveCell.FormulaR1C1 = "Credit"
        Range("M1").Select
        ActiveCell.FormulaR1C1 = "Notes"
        Range("N1").Select
        ActiveCell.FormulaR1C1 = "Unique"
        Columns("A:A").ColumnWidth = 27    'This is where I change column width and format Column J to Currency
        Columns("M:M").ColumnWidth = 36
        Columns("J:J").ColumnWidth = 20
        Columns("J:J").Select
        Selection.NumberFormat = "$#,##0.00"
        Range("A1").Select
    Sub GroupStatusbyInsertingUniqueValueCS()
    'Searches for values in column D and if Found, Inserts New value (Replacement) in Column N
        Dim i As Long, j As Long, r As Range, ff As String
        Dim SearchKeys1, SearchKeys2, SearchKeys3, SearchKeys4, SearhKeys5, SearchKeys6, _
        SearchKeys7, SearchKeys8, SearchKeys9, SearchKeys10, SearchKeysAll, Replacement
        SearchKeys1 = Array("Pre Test", "Open", "Received", "Preliminary Ins", "Insp-APU", "Pending", "Inspection", "Clean", "Pre-Test")
        SearchKeys2 = Array("Approved", "Disassemble", "RETURN AS IS", "Waiting Parts", "Waiting Compone", "Assembly", _
        "Test", "Post Test", "QEC", "QC", "QC Discrepancy", "Shipping Prep", "Assembly-APU")
        SearchKeys3 = Array("Customer Servic")
        SearchKeys4 = Array("Lease")
        SearchKeys5 = Array("Quote on Hold", "Quote")
        SearchKeys6 = Array("Closed", "Invoicing")
        SearchKeys7 = Array("Parking Lot")
        SearchKeys8 = Array("Waiting App.")
        SearchKeys9 = Array("Weld", "Balance Shop", "Cancelled", "Strip Coating", "Waiting Concess", "Machine Shop", "NDT", _
        "Grind Shop", "Paint", "Plating", "Chrome/Cad", "Chrome Strip", "Shot Peen", "Outside Vendor", "Waiting manual", "Quoted for Exch", _
        "Sub-Assembly", "Insp-LH", "Assembly-LH", "PO AN LRU", "Harness-LG", "concession")
        SearchKeysAll = Array(SearchKeys1, SearchKeys2, SearchKeys3, SearchKeys4, SearchKeys5, _
        SearchKeys6, SearchKeys7, SearchKeys8, SearchKeys9)
        Replacement = Array("GATE 1", "GATE 2", "CUSTOMER SERVICE", "LEASE", "QUOTE", "SHIPPED", "SURPLUS PARTS", "WAITING APPROVAL", "OTHER")
        With Intersect(ActiveSheet.UsedRange, Columns(4))
            For i = LBound(Replacement) To UBound(Replacement)
                For j = LBound(SearchKeysAll(i)) To UBound(SearchKeysAll(i))
                    Set r = .Find(SearchKeysAll(i)(j), lookat:=2)
                    If Not r Is Nothing Then
                        ff = r.Address
                        Do
                            Set r = .FindNext(r)
                            r.Offset(, 10) = Replacement(i)
                        Loop Until r.Address = ff
    I run the code in this sequence:
    Sub CorrectSequence()
    Call FormatQuantumDataDumpCS
    Call GroupStatusbyInsertingUniqueValueCS
    Can any one help me to fix this code were it will use the replacement "Gate 1" when the value "Pre Test" is found? ANy advice or help would be much appreciated.
    Using Excel 2010
  1. Replies: 10
  2. Replies: 17
    Last Post: 05-22-2013, 11:58 PM
  3. How to make Dynamic range (width) with OFFset function
    Last Post: 12-01-2012, 11:03 PM
  4. Group Pivot Data Based On Row Values In One Column
    Last Post: 10-09-2012, 11:46 PM
  5. Replies: 3
