Results 1 to 8 of 8
Thread: Macro to clear data based on color fill
Howardc Macro to clear data based on... 11-28-2012, 11:20 AM
Admin Hi try this. Sub... 11-28-2012, 05:18 PM
Howardc Thanks for the help, much... 11-28-2012, 07:00 PM
Howardc Hi admin I would like to... 11-28-2012, 08:00 PM
Admin Hi Try to modify yourself... 11-28-2012, 09:27 PM
Howardc Hi Admin Thanks for the... 11-28-2012, 09:36 PM
Admin Thanks for the feedback. ... 12-03-2012, 08:59 AM
Howardc Thanks for the links. i'm... 12-03-2012, 09:25 AM
    Apr 2012
    I would like code to clear data on all sheets from row 5 onwards where the data has been colored using the color fill, except formulas-see sample data attached
    Your assistance is most appreciated.
    I have also posted on Mr Excel.com-see link below
    Macro to clear data
    try this.
    Sub kTest()
        Dim Sht     As Worksheet
        Dim LastRow As Long
        Dim LastCol As Long
        Dim rngAll  As Range
        Dim r       As Range
        Dim c       As Range
        For Each Sht In Worksheets
            With Sht
                If .UsedRange.Cells.Count > 1 Then
                    LastRow = .Cells.Find("*", .Cells(1), , 2, 1, 2).Row
                    LastCol = .Cells.Find("*", .Cells(1), , 2, 2, 2).Column
                    Set rngAll = .Range(.Cells(5, 1), .Cells(LastRow, LastCol))
                    For Each r In rngAll.SpecialCells(2, 23).Areas
                        For Each c In r.Cells
                            If c.Interior.ColorIndex <> -4142 Then
                                c.Clear 'if you want to cleat the both the formats and data
                                'c.ClearContents'removes only data
    Apr 2012
    Thanks for the help, much appreciated
    Apr 2012
    Hi admin
    I would like to amend the code so that sheet 'main" is ignored when the colored data are cleared
    Try to modify yourself and learn VBA !
    here is the way to avoid sheet Main.
    Sub kTest()
        Dim LastRow As Long
        Dim LastCol As Long
        Dim rngAll  As Range
        Dim r       As Range
        Dim c       As Range
            If LCase$(Sht.Name) <> "main" Then
                With Sht
    Apr 2012
    Hi Admin
    Thanks for the help. Are there any good tutorials or books on VBA that you can recommend to novices?
    Have a look at http://www.excelfox.com/forum/f13/le...ful-links-144/
    Apr 2012
    Thanks for the links. i'm sure that I will find these useful
  1. Replies: 2
    Last Post: 05-30-2013, 07:28 PM
  2. Replies: 9
    Last Post: 12-04-2012, 09:45 PM
  3. Macro To Clear Certain Data Across Many Sheets
    Last Post: 12-04-2012, 09:10 AM
  4. Macro to check values based on certain text
    Last Post: 11-05-2012, 09:03 PM
  5. Replies: 4
    Last Post: 07-27-2012, 08:43 AM
