Results 1 to 10 of 13
Thread: How to make Dynamic range (width) with OFFset function
    Aug 2011
    In the attached sheet i need to sum the daily sales record for indivusal sales person. Is there a way to make the dynamic width (single row) using Offset function of any other formula so that it only sum the data till the last non blank cell.
    Dynamic Width.xlsx
    Rajesh
    Member Charles's Avatar
    Aug 2012
    Aug 2011
    Thanks, Charles.
    A code will also work for me.
    Aug 2012
    In this copy I did not use a formula for the worksheet.
    I set the code to provide the Value of each Total.
    I have a "Interface " sheet with a Button. When you click it the code will run.
    You can the select the sheet to check the result.
    Member Rajan_Verma's Avatar
    Two solution are here for you
    if you filled the cell continously ,
    =SUM(OFFSET(Sheet1!C2,,,1,COUNT(Sheet1!C2:T2)))
    if you fill the cells not continously
    =SUM(C2:INDEX(C2:T2,1,MATCH(999999999,C2:T2,1)))
    Rajan
    Aug 2011
    Thanks Rajan and Charles, both the solutions are working perfect.
    Rajesh
    Aug 2012
    Thanks for letting us know.
    Aug 2011
    Hi Charles,
    Can I use a formula instead Application function.
    Rajesh
    Aug 2012
    HI,
    What do you mean?
    Are you anting to use the "Formula" in the vba code?
    Or in the worksheet
    Aug 2011
    Thanks for your reply.
    if possible In the VB code , else in the worksheet will also work.
  1. Replies: 2
    Last Post: 05-13-2013, 12:03 AM
  2. How To Make A Custom VBA Function Available In All Workbooks
    Last Post: 04-11-2013, 02:01 PM
  3. Offset based on Values in Column E
    Last Post: 12-04-2012, 10:06 AM
  4. Dynamic Chart Query
    Last Post: 11-26-2012, 04:50 PM
    Last Post: 11-08-2011, 08:52 AM
