Thread: Custom Format Conditional With Square Bracket
    Nov 2012
    I am need of some help I would like to have one cell following three conditions
    When inputted value into cell (E2) the conditions are as follows
    If the Value is greater then or equal too 10 then should display 0
    If the Value is between 11-15 Should display $500
    If the Value is equal to 16 or greater should display $800
    Thank you Thank you for anyone that can help have a great day.
    Adam
    I assume you meant
    1. If the value is less than or equal to 10, then display 0
    2. If the value is between and equal to 11 and 15, then display $500
    3. If the value is greater than or equal to 16, then display $800
    Use this conditional format with Custom Format
    [>=16]"$800";[>=11]"$500";"0"
    Nov 2012
    Thank you so very much for the help I understand. since I am a novice at excel can you guide me to perform this function please. I have tried to insert the formula above into the conditional formatting pop up window but nothing is happening. Really Really appreciate the help.
  1. Replies: 21
    Last Post: 05-27-2013, 08:45 PM
  2. Red Green Amber Three Color Conditional Format
    Last Post: 03-07-2013, 06:50 PM
  3. Replies: 2
    Last Post: 02-06-2013, 12:00 PM
  4. Conditional Format Based On Percentage Variance
    By srizki in forum Excel Help
    Last Post: 10-09-2012, 03:28 AM
  5. Replies: 4
    Last Post: 07-27-2012, 08:43 AM
