Results 1 to 6 of 6
Thread: Rounding data in Vba
    Oct 2011
    From a list of dates in column B
    I used Function that returns the data in column C
    I ask what i can do to find rounding of the column D
    A B C D
    1 26/10/11 19.00 35 19.00.00 19.00
    2 26/10/11 19.04 49 19.05.00 19.00
    3 26/10/11 19.05 41 19.05.00 19.05
    4 26/10/11 19.08 20 19.05.00 19.05
    I attach a file with the data to compare, you can get in VBA this rounding in date ?
    Thanks in advance
    Quote Originally Posted by PcMax View Post
    A B C D
    I believe you want this formula...
    =MROUND(MOD(B3-TIME(0,2,30),1),MOD(TIME(0,5,0),1))
    You will need to format the cells using this...
    h:mm;@
    Oct 2011
    The suggestions require components of financial analysis.
    I added references and tested formulas.
    I thank Rick with the suggestion:
    What is the exact matches
    What do you mean by "What is the exact matches"? I don't understand what you are referring to.
    Oct 2011
    Rick, I translated: Google Traduttore
    I add a new post
    The data obtained are correct
    Thanks!
