Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: don't copy filtered data if no active cells
    I think the earlier code would work. Just replace the Jun and Jul values with the following
    Jun = DateSerial(2012, 6, 1)
    Jul = DateSerial(2012, 7, 1)
  2. #22
    OK. Here is the code for Jun.
    Sub Jun()
    '*********************** January KPI Report **************************
        Dim wksRawData As Worksheet
        Dim wksHKKot As Worksheet
        Dim wksHKHam As Worksheet
        Dim wksXMNSHAHam As Worksheet
        Dim rngRawData As Range
        Dim lngCount As Long
        Dim Jun As Date
        Dim Jul As Date
        Dim HK As String
        Dim KT As String
        Dim HAM As String
        Dim XMN As String
        Dim SHA As String
        Dim LastRow As Long
        Dim ETS_Col As String
        Dim Pol_Col As String
        Dim PoD_Col As String
        Set wksRawData = Worksheets("Raw Data")
        Set wksHKKot = Worksheets("HKG to Kotka")
        Set wksHKHam = Worksheets("HKG to Hamburg")
        Set wksXMNSHAHam = Worksheets("XMN | SHA to Hamburg")
        HK = "Hong Kong"
        KT = "Kotka"
        HAM = "Hamburg"
        XMN = "Xiamen"
        SHA = "Shanghai"
        With wksRawData
            If .AutoFilterMode Then .AutoFilterMode = False 'remove autofilter
            LastRow = .Range("k" & .Rows.Count).End(xlUp).Row
            Set rngRawData = .Range("a5:w" & LastRow) 'set the range
            ETS_Col = "'" & .Name & "'!k6:k" & LastRow
            Pol_Col = "'" & .Name & "'!n6:n" & LastRow
            PoD_Col = "'" & .Name & "'!o6:o" & LastRow
        ' **************** Hong Kong to Kotka ***********************************
        'count whether any shipment exist in June from Hong Kong to Kotka
        lngCount = Evaluate("sumproduct(--(month(" & ETS_Col & ")=month(""" & Jun & """+0)),--(" & Pol_Col & "=""" & HK & """),--(" & PoD_Col & "=""" & KT & """))")
        'if exist
        If lngCount Then
            With rngRawData
                .AutoFilter field:=11, Criteria1:=">=" & Jun, Operator:=xlAnd, _
                        Criteria2:="<" & Jul, Operator:=xlAnd
                .AutoFilter field:=14, Criteria1:=HK
                .AutoFilter field:=15, Criteria1:=KT
                Set rng = .Cells(1).Offset(1).Resize(.Rows.Count - 1, .Columns.Count).SpecialCells(12)
            wksHKKot.Range("A11:W40").ClearContents
            rng.Copy wksHKKot.Range("A11")
            wksRawData.ShowAllData
            MsgBox "No Shipments from Hong Kong to Kotka in June"
     ' **************** Hong Kong to Hamburg ***********************************
        'reset lngCount
        lngCount = 0
        'count whether any shipment exist in June from Hong Kong to Hamburg
        lngCount = Evaluate("sumproduct(--(month(" & ETS_Col & ")=month(""" & Jun & """+0)),--(" & Pol_Col & "=""" & HK & """),--(" & PoD_Col & "=""" & HAM & """))")
        'if exist
        If lngCount Then
            With rngRawData
                .AutoFilter field:=15, Criteria1:=HAM
            wksHKHam.Range("A11:W40").ClearContents
            rng.Copy wksHKHam.Range("A11")
            MsgBox "No Shipments from Hong Kong to Hamburg in June"
      ' **************** Xiamen | Shanghai to Hamburg ***********************************
        'reset lngCount
        lngCount = 0
        'count whether any shipment exist in June from Xiamen and Shanghai to Hamburg
        lngCount = Evaluate("sumproduct(--(month(" & ETS_Col & ")=month(""" & Jun & """+0)),--(" & Pol_Col & "=""" & SHA & """)+(" & Pol_Col & "=""" & XMN & """),--(" & PoD_Col & "=""" & HAM & """))")
        'if exist
        If lngCount Then
            With rngRawData
                .AutoFilter field:=14, Criteria1:=SHA, Operator:=xlOr, _
                Criteria2:=XMN
            wksXMNSHAHam.Range("A11:W40").ClearContents
            rng.Copy wksXMNSHAHam.Range("A11")
            MsgBox "No Shipments Xiamen or Shanghai to Hamburg in June"
        Set wksRawData = Nothing
        Set wksHKKot = Nothing
        Set wksHKHam = Nothing
        Set wksXMNSHAHam = Nothing
  3. #23
    Hi Admin, Thank so much to the time you are spending on this but still not working for me. On the spread sheet there are no rows in June from Hong Kong to Kotka to the msgbox should show but the lngCount = 1 when code is passed
    Sorry. Xander
  4. #24
    I got the msgbox saying 'No shipments from Hong Kong to Kotka in June'
    Are you sure that you completely replaced the code with the above one ?
  5. #25
    Yes I made sure to copy the whole code. Don't know how lngCount is finding 1 row as there are non against the Criteria. I am running Excell 2003. Would that make a difference? I cant see where we would differ on our workbooks?
  6. #26
    I'm now convinced its because of cell format of my sheets. When I run the code line by line it filters June and there are no rows visible so the filter using Jun & Jul is not looking for 01/06/2012 / 01/07/2012 on my sheet because the date 06/06/2012 does exist. I have made sure the date is UK but still doesnt work I'm sure its a little setting making it not work as code is great.
    p.s. Im having trouble getting my profile pic
  7. #27
    I think i have it sussed. I just amended date to the previous and seems to be picking up the data.
    Jan = #1/1/2012#
    Feb = #1/2/2012#
    My last problem is that my boss has decided he wants to filter by ETA not ETS so I need to change to column. I tried to do this by changing Ets_Col to Eta_Col and amending the code but its not liking it.
        Dim Jan As Date
        Dim Feb As Date
        Dim HK As String
        Dim KT As String
        Dim HAM As String
        Dim XMN As String
        Dim SHA As String
        Dim LastRow As Long
        Dim Eta_Col As String
        Jan = #1/1/2012#
        Feb = #1/2/2012#
        HK = "Hong Kong"
        KT = "Kotka"
        HAM = "Hamburg"
        XMN = "Xiamen"
        SHA = "Shanghai"
        With wksRawData
            LastRow = .Range("l" & .Rows.Count).End(xlUp).Row
            Eta_Col = "'" & .Name & "'!L6:L" & LastRow
        'count whether any shipment exist in January from Hong Kong to Kotka
        lngCount = Evaluate("sumproduct(--(month(" & Eta_Col & ")=month(""" & Jan & """+0)),--(" & Pol_Col & "=""" & HK & """),--(" & PoD_Col & "=""" & KT & """))")
    problem ocurres on the last line of above code
    Thanks so much
  8. #28
    It's working absolutely fine here. No clue why this isn't working at your end
    I have tested this in both xl 2003 and 2007. BTW, I have changed the formula little bit so that it would take care of the year and month
    lngCount = Evaluate("sumproduct(--(text(" & ETS_Col & ",""mmyy"")=text(""" & Jun & """+0,""mmyy"")),--(" & Pol_Col & "=""" & HK & """),--(" & PoD_Col & "=""" & KT & """))")
    change the bold part in other two formulas as well.
    For the next 10 days, I'll have limited access of net. So I might not able to answer your queries in time.
  9. #29
    Just seen your post. replace Jan with cdate(jan), untested though.
  10. #30
    Let Joy be unconfined!! code works like a dream. Thanks for all your help :o Just in time for deadline tomorrow.
    Final code:
    Sub Jan()
        Dim Jan As Date
        Dim Feb As Date
        Dim HK As String
        Dim KT As String
        Dim HAM As String
        Dim XMN As String
        Dim SHA As String
        Dim LastRow As Long
        Jan = #1/1/2012#
        Feb = #1/2/2012#
        HK = "Hong Kong"
        KT = "Kotka"
        HAM = "Hamburg"
        XMN = "Xiamen"
        SHA = "Shanghai"
        With wksRawData
            LastRow = .Range("L" & .Rows.Count).End(xlUp).Row
        lngCount = Evaluate("sumproduct(--(text(" & Eta_Col & ",""mmyy"")=text(""" & Jan & """+0,""mmyy"")),--(" & Pol_Col & "=""" & HK & """),--(" & PoD_Col & "=""" & KT & """))")
        'if exist
        If lngCount Then
            With rngRawData
                .AutoFilter field:=12, Criteria1:=">=" & Jan, Operator:=xlAnd, _
                        Criteria2:="<" & Feb, Operator:=xlAnd
            MsgBox "No Shipments from Hong Kong to Kotka in January"
        'reset lngCount
        lngCount = 0
        'count whether any shipment exist in January from Hong Kong to Hamburg
        lngCount = Evaluate("sumproduct(--(text(" & Eta_Col & ",""mmyy"")=text(""" & Jan & """+0,""mmyy"")),--(" & Pol_Col & "=""" & HK & """),--(" & PoD_Col & "=""" & HAM & """))")
        'if exist
        If lngCount Then
            With rngRawData
            MsgBox "No Shipments from Hong Kong to Hamburg in January"
        'reset lngCount
        lngCount = 0
        'count whether any shipment exist in January from Xiamen and Shanghai to Hamburg
        lngCount = Evaluate("sumproduct(--(text(" & Eta_Col & ",""mmyy"")=text(""" & Jan & """+0,""mmyy"")),--(" & Pol_Col & "=""" & SHA & """)+(" & Pol_Col & "=""" & XMN & """),--(" & PoD_Col & "=""" & HAM & """))")
        'if exist
        If lngCount Then
            With rngRawData
                Criteria2:=XMN
            MsgBox "No Shipments Xiamen or Shanghai to Hamburg in January"
  1. Highlighting All the Cells of Active sheet which contains a particular String:
    By littleiitin in forum Excel and VBA Tips and Tricks
    Last Post: 10-18-2013, 04:19 PM
  2. Macro to copy data in specific Columns
    Last Post: 04-19-2013, 10:42 AM
  3. Replies: 2
    Last Post: 02-11-2013, 08:13 PM
  4. Copy selected data to other excel sheet
    By dhiraj.ch185 in forum Excel Help
    Last Post: 02-02-2012, 06:23 AM
  5. Unique Count on a Filtered Range
    Last Post: 08-14-2011, 04:29 AM
