Hello, i have this VBA code that opens a file dialog box and allows the user browse/search for a file and select the file that is needed. The issue i'm having with this is is that when i run the macro for the first time, it does not follow all the filter constraints set (i.e show only MS project files, .mpp and also, i set the default folder to be opened to "c:\" but it opens my documents ) but after the first run, the it obeys the filter constraints and works normally, please how do i go about this.
i appreciate your suggestions.Code:Private Sub Opener() Dim fd As FileDialog Dim FileName As String Dim part As String Set fd = Application.FileDialog(msoFileDialogOpen) Dim FileChosen As Integer FileChosen = fd.Show fd.Title = "Choose Project" fd.InitialFileName = "c:\" fd.InitialView = msoFileDialogViewList fd.Filters.Clear fd.Filters.Add "MS Project Files", "*.mpp" fd.FilterIndex = 1 fd.ButtonName = "Choose this file" If FileChosen <> -1 Then 'didn't choose anything (clicked on CANCEL) MsgBox "No file opened" Exit Sub Else 'get file, and open it (NAME property 'includes path, which we need) part = fd.SelectedItems(1) 'Documents.Open (FileName) 'part = FileName Set objx = ActiveDocument.InlineShapes.AddOLEObject(ClassType:="MSProject.Project", _ FileName:=part, LinkToFile:=False, DisplayAsIcon:=False, Range:=ActiveDocument.Frames(1).Range) objx.Height = 300 objx.Width = 480 'Open object ready for typing Set objx = Nothing End If End Sub
