Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Macro to check values based on certain text
    Apr 2012
    I have the word "Check" in Column A. Where Check appears in cloumn A I would like to determine whether the values in the same row as where "check" appears <> (not equal) to zero. This needs to be checked on all sheets, except the sheet "Consolidated"
    I have code to do this, but when running the code, I get an error message "unable to get the sum property of the worksheet function class" -the folowing code is highlighted when I click on Debug
    If Application.WorksheetFunction.Sum(myrange) <> 0 Then
    The full code is
    Sub Check_Variance()
            Dim sh
            Dim caddress As String, lastrowSH1 As Long
            Dim startcell As Range, endcell As Range, myrange As Range
            For Each sh In Worksheets
            If UCase(sh.Name) <> "CONSOLIDATED" Then
            caddress = ""
            lastrowSH1 = Sheets(sh.Name).Range("A" & Rows.Count).End(xlUp).Row
            For Each cell In Sheets(sh.Name).Range("A1:A" & lastrowSH1)
            Debug.Print sh.Name
            Debug.Print cell.Value
            If UCase(cell.Value) = "CHECK" Then
            Set startcell = Sheets(sh.Name).Range("B" & cell.Row)
            Set endcell = Sheets(sh.Name).Range("Q" & cell.Row)
            Set myrange = Sheets(sh.Name).Range(startcell, endcell)
              For i = 1 To 26
               If cell.Offset(0, i) <> 0 Then
                If caddress = "" Then
                caddress = cell.Offset(0, i).Address
                caddress = caddress & ", " & cell.Offset(0, i).Address
               Next i
            Next cell
            If caddress <> "" Then
            MsgBox "Please check the following address(es) on " & sh.Name & vbNewLine & vbNewLine & caddress
            Next sh
    @ Howard
    Please add code tags while posting codes
    Try
        Dim sh  As Worksheet, cCell As Range
        Dim cAddress As String, lastRowSH1 As Long, i As Long
        Dim startCell As Range, endCell As Range, myRange As Range
                cAddress = ""
                With sh
                    lastRowSH1 = .Range("A" & .Rows.Count).End(xlUp).Row
                    For Each cCell In .Range("A1:A" & lastRowSH1)
                        Debug.Print sh.Name
                        Debug.Print cCell.Value
                        If UCase(cCell.Value) = "CHECK" Then
                            Set startCell = .Range("B" & cCell.Row)
                            Set endCell = .Range("Q" & cCell.Row)
                            Set myRange = .Range(startCell, endCell)
                            If Application.WorksheetFunction.Sum(myRange) <> 0 Then
                                For i = 1 To 26
                                    If cCell.Offset(0, i) <> 0 Then
                                        If cAddress = "" Then
                                            cAddress = cCell.Offset(0, i).Address
                                            cAddress = cAddress & ", " & cCell.Offset(0, i).Address
                                Next i
                    Next cCell
                    If cAddress <> "" Then
                        MsgBox "Please check the following address(es) on " & sh.Name & vbNewLine & vbNewLine & cAddress
        Next sh
    Apr 2012
    Thanks for the reply. I still get "unable to get the sum property of the worksheet function class" -the folowing code is highlighted when I click on Debug
    HTML Code:
    Your assistance is most appreciated
    Is there any error values in the sum range ?
    Apr 2012
    There are two #N/A's, which I think is causing the problem. Would it be possible to incorporate this into the macro i.e if the valiue is <> 0 or there is an error , the user must be advised via the message box
    Replace the error line with
    If Evaluate("sumif(" & myRange.Address(external:=1) & ",{"">0"",""<0""})") <> 0 Then
    Apr 2012
    Thanks for the help-code works perfectly, much appreciated. I need one small amendment. Some the values in the same row as check are for very small eg 0.0001 or (0.0001). I would like the code amended so that where the variance start is more than three decimals plances, it must be ignored
    Not sure I understood you correctly. Can you provide an example row ?
    Apr 2012
    Attached please find row of sample data. Where the variance is very small i.e tolerance showing more than three decimal places it must be ignored as tolerance is minute
    Your assistance in this regard is most appreciated
  1. Sum values based on multiple criteria
    By Jorrg1 in forum Excel Help
    Last Post: 01-07-2013, 03:04 PM
  2. Replies: 10
    Last Post: 12-10-2012, 11:28 PM
  3. Offset based on Values in Column E
    Last Post: 12-04-2012, 10:06 AM
  4. Macro to clear data based on color fill
    Last Post: 12-03-2012, 09:25 AM
  5. Loop and Check For Values In Entire Column in Excel
    By Jeff5019 in forum Excel Help
    Last Post: 05-01-2012, 10:34 PM
