Thread: Strange Excel Spinner Buttons Help??
    Sep 2012
    Ok. I need a way to make buttons do the following.
    Based on whether or not (Skill Name) is formatted (blah blah vlookup true) the (Ranks) increases by 1 for each click up to a maximum equal to Cell(blah)+3
    If (Skill Name) is /not/ formatted, the (Ranks) needs to go up by .5 for each click. ....
    I am soooo out of my expertise here. the table looks like this currently
    Skill Name Total Ranks Modifier
    (Con. Form) (=sum) (button Here) (equal to other cells)
    Alchemy* 0 0 0
    Animal Empathy* 3 0 3
    Appraise* 0 0 0
    Balance* 4 0 4
    Bluff* -2 0 -2
    Skill Name formatting:
    =VLOOKUP(N13,Skills,MATCH(B3,Classskills,0),FALSE) ="C"
    Whole sheet(s) available upon request if you need more information.
    Thanks in advance for all your help.
    Welcome to ExcelFox community.
    Yes, it would be nice if you could upload a sample file which represents your actual data set. Posting an expected output for a couple of scenarios will also help.
    Sep 2012
    https://docs.google.com/open?id=0Bz9...UtablB1UWJJbjA
    Looking at the 'skills' portion on the right hand side of sheet 1.
    If the skill name is highlighted, then the button should go up one whole number per click. If the skill name isn't highlighted, then it should only go up by .5 per click.
    the maximum number in each box should be equal to your level+3. Or half of that for cross-class(non highlighted) skills.
    So lets say you are a ranger (what the sheet is set to) the first three skills are:
    Alchemy(cross class) the spinner button should go up to no more than: 5.5 (or eleven(level 8+3)clicks at .5 per click)
    Animal Empathy (class) button should go up to 11 (eleven clicks at 1 per click)
    Appraise (cross class) button should go up to 5.5 (eleven clicks at .5 per click)
  1. HP Calculator Buttons
    By Howardc in forum Word Help
    Last Post: 12-01-2012, 11:12 AM
  2. Programmatically format VBA buttons
    By Belleye in forum Excel Help
    Last Post: 09-25-2012, 11:18 AM
  3. Replies: 7
    Last Post: 08-08-2012, 10:24 AM
  4. Social Network Buttons
    By Excel Fox in forum Den Of The Fox
    Last Post: 07-10-2011, 10:15 AM
  5. How To Add Menu And Buttons To Ribbon Group
    By Excel Fox in forum Excel Ribbon and Add-Ins
    Last Post: 07-04-2011, 12:43 PM
