Thread: VBA - Sorting by columns
    Apr 2011
    I use the code below to sort my data by rows -- is there a way I can sort columns - based upon numeric values in a row --- I suppose I could transpose the data then sort - then transpose the data again
    Public HeaderRow as long
    Sub SortAscending()
        Select Case ActiveCell.Row
            Case HeaderRow
                If IsEmpty(ActiveCell.Value) Then Exit Sub
                Static MySortType As Integer
                MySortType = xlAscending
                ActiveCell.CurrentRegion.Offset(1).Sort Key1:=ActiveCell, Order1:=MySortType, Header:=xlYes
    xl2007 - Windows 7
    xl hates the 255 number
    The sorting orientation is one of the sort method's arguments.
    To sort by columns use:
    Sub SortAscending()
       Sheet1.Cells(1).CurrentRegion.Sort Sheet1.Cells(1), 2, , , , , , 1, , , 2
    Nov 2011
    Hi Rasm,
    Here is my code that i had used in one of my project where i had to sort the Columns based on the date in their first cell value that were containing date in. As you see the range starts at G1 upto it last non blank cell to its right.Then this range got sorted on the behalf of the data in it . Date as data in my case.
    Public Sub SortDate_Columns()
        Dim rngDate     As Range
        Dim rngCell     As Range
        Dim intCol      As Integer
        With ThisWorkbook.Worksheets("TempCalls")
            Set rngDate = .Range("G1", .Range("G1").End(xlToRight))
            Set rngDate = Intersect(rngDate.CurrentRegion, rngDate.CurrentRegion.Offset(0, 6))
            With rngDate
                .Sort .Cells(1), 1, , , , , , xlYes, , , 2
        Set rngDate = Nothing
        Set rngCell = Nothing
  1. How to Add Custom List And Use in Custom Sorting
    Last Post: 06-07-2013, 10:41 PM
    Last Post: 02-23-2013, 09:18 PM
  3. Validating 2 Columns using excel VBA
    By freakszzy in forum Excel Help
    Last Post: 07-26-2012, 12:46 PM
  4. Data sorting & Graph making according filters
    Last Post: 04-05-2012, 08:56 AM
  5. Split Range into Multiple Columns VBA
    Last Post: 03-07-2012, 10:53 PM
