I am hoping to get some help on creating a formula that basically has a big IF statement. I hope this makes sense, so here goes. I am looking to find the "age" or "elapsed days" of an ID from when they created an account to when they stopped. This might be very complex and if there's not a way to calculate the Elapsed days (even though that's what I prefer), perhaps there is some formula that can return a value like a "1" or "True" or something that lets me know the statement is true.
A kind person on this forum helped me with the original formula when there were only a couple of variables, but he stated that the below new criteria is a little too complex. His original formula is an array and it worked beautifully. However, I need to add a little more variables to the equation.
I thank you in advance for your help in recommending any solution for this.
original formula
{=IF(D2>0,A2-INDEX(A$2:D$16,MATCH(B2&"1",B$2:B$16&C$2:C$16,0),1 ),"")}
New formulas needed or revised from the above:
Formula 1: If the ID in column 2 are the same, and if there is a value in column 3 (Create) and a value in Column 4 (Suspend) AND there is no value in Column 5 (Stopped), then subtract the dates in column 1 for Create and Suspend. My manual calculation result is in the column called "Elapsed Days (Create to Suspend but NO Stopped)
Formula 2: If the ID in column 2 are the same, and if there is a value in column 3 (Create) and a value in Column 4 (Suspend) AND there is no value in Column 5 (Stopped) OR Column 6 (Unsuspend), then subtract the dates in column 1 for Create and Suspend. My manual calculation result is in the column called "Elapsed Days (Suspend Only, No stopped or Unsuspend)"
Formula 3: The ID in column 2 does not have to be the same, but if there is a value in column 3 only (Create) and there is no value in the Suspend, Stopped, or Unsuspend columns, then place a "1" in the cell. My manual calc is the "Create Only" column.
Elapsed Days calc.xlsx
Event Date ID CREATE Suspend STOPPED Unsuspend Elapsed Days (Create to Suspend but NO Stopped) Elapsed Days (Suspend Only, No stopped or Unsuspend) Create Only 2/10/11 207135 1 3/8/11 207135 1 3/10/11 207135 1 2/10/11 207316 1 1 2/13/11 207785 1 2/20/11 207785 1 7 3/1/11 207785 1 2/22/11 209566 1 1 2/22/11 209575 1 7/13/11 209575 2 8/13/11 209575 1 2/22/11 209577 1 5/1/11 209577 1 68 2/22/11 209636 1 5/9/11 209636 1 11/7/11 209636 2 2/23/11 209685 1 2/23/11 209694 1 9/13/11 209694 1 1 202 5/6/11 210567 1 1
