Results 1 to 10 of 10
Thread: Evaluate("SUM
    Oct 2011
    Evaluate("SUM
    With this code I get the expected result ...
    Sub Test_A()
        Dim Riga As Long
        Dim Dn As Long
        Dim rng As Variant
        Dim Num As Integer
        Num = Cells(2, 12)              'Value = 10
        Dn = Range("C" & Rows.Count).End(xlUp).Row
        rng = Range("IV1:IV" & Dn)      'Range without any data
        For Riga = Num + 1 To UBound(rng)
            rng(Riga, 1) = Evaluate("SUM(C" & Riga - Num + 1 & ":" & "C" & Riga & ")/L2")   '=SUM(C2:C11)/L2
        Range("O1:O" & Dn) = rng
    I used an array to avoid delays with 500,000 rows to update.
    Definitely worth a general overhaul to improve the code.
    Can you provide a written description and/or provide a before and after view of the worksheet (or both) so that we have some idea what this code is doing? I have a gut feeling just looking at the shape of the code that it can be made more efficient, but without a clearer understanding of what the code is attempting to do for you, I won't know for sure.
    Oct 2011
    I'm working with data from a list.
    The calculations are based on a calculation of personal mobile media.
    Seeking advice to improve and correct parts of the code.
    (The code I wrote is the result of my own interpretation)
    Sub snb()
      sn = Sheets(1).Columns(3).SpecialCells(2)
      For j = 11 To UBound(sn)
        sn(j, 1) = (sn(j, 1) + sn(j - 1, 1) + sn(j - 2, 1) + sn(j - 3, 1) + sn(j - 4, 1) + sn(j - 5, 1) + sn(j - 6, 1) + sn(j - 7, 1) + sn(j - 8, 1) + sn(j - 9, 1)) / 10
      Cells(1, 15).Resize(UBound(sn)) = sn
      Cells(2, 15).Resize(9).ClearContents
    Oct 2011
    Did you mean like this:
    Sub snb()
      Sn = Sheets(1).Columns(3).SpecialCells(2)
      Sn1 = Sn
      For j = 11 To UBound(Sn)
        Sn1(j, 1) = (Sn(j, 1) + Sn(j - 1, 1) + Sn(j - 2, 1) + Sn(j - 3, 1) + Sn(j - 4, 1) + Sn(j - 5, 1) + Sn(j - 6, 1) + Sn(j - 7, 1) + Sn(j - 8, 1) + Sn(j - 9, 1)) / 10
      Cells(1, 15).Resize(UBound(Sn)) = Sn1
    Keep in mind that the value 10 in range L2 I can edit ( 1, 2,,,10, 11, 12,,, ecc)
    This code seems to produce the same answer as the code you posted...
    Sub Test_B()
      Dim LastRow As Long
      LastRow = Range("C" & Rows.Count).End(xlUp).Row
      With Range("O" & Range("L2").Value + 1 & ":O" & LastRow)
        .Formula = "=SUM(OFFSET(C$1:C$" & Range("L2").Value & ",ROW(A1),0))/L$2"
        .Value = .Value
    Oct 2011
    Sub Test_C()
      Dim LastRow As Long
      Dim MediaL2 As Long
      MediaL2 = Range("L2").Value
      With Range("O" & MediaL2 + 1 & ":O" & LastRow)
        .Formula = "=SUM(OFFSET(C$1:C$" & MediaL2 & ",ROW(A1),0))/" & MediaL2
        .Value = .Value
      Cells(1, 15).Resize(MediaL2).ClearContents
    I only had to add the last line to delete the values ​​of a previous increase when the value of L2.
    Thanks for the directions suggested
    Quote Originally Posted by PcMax View Post
    Sub Test_C()
      Dim LastRow As Long
      Dim MediaL2 As Long
        .Value = .Value
    If I understand the purpose of that last line (highlighted in red) correctly, shouldn't it appear at the top of the code rather than the bottom? Located at the bottom, there are circumstances when it would clear values that were just placed, right?
    Oct 2011
    In my tests I'm not deleting data you just entered, to be sure the rule is to place the first cycle:
    Thank you for the valuable suggestions
    Nevermind... I had misunderstood your intent when I first read your added code line... I see what you are doing now. I am glad everything is working for you now.
  1. VBA Versions of my "Get Field" and "Get Reverse Field" formulas
  2. Reversing a "First Middle Last" Name to "Last, First Middle" Name Format
    Last Post: 01-06-2014, 10:04 PM
  3. Replies: 5
    Last Post: 04-18-2013, 02:30 AM
  4. Follow-up to "Excel Number Format: Indian Style Comma Separation"
    Last Post: 04-14-2012, 10:46 PM
  5. Ordinal Suffix (i.e., "st", "nd", "rd" and "th")
