Results 1 to 8 of 8
Thread: Remove UserForm's TitleBar And Frame
    Every now and again, someone on a forum requests to have the title bar removed from their UserForm. The reason may simply be to remove the Exit Button (the red X in the upper right corner) or to get rid of the windows framework which is deemed "ugly" given the UserForm's design. Actually, with some simple Windows API function calls (sorry Mac users, but this code will not work for you), removing the title bar and windows border is quite easy to do. Of course, without a title bar, your user will not be able to move the UserForm around the screen. Again, the Windows API functions come to the rescue... setting up the ability to move a UserForm having no title bar is also quite easy to do. Simply put this code into your UserForm's code window and you are done.
    '**** Start of API Calls To Remove The UserForm's Title Bar ****
    Private Declare Function FindWindow Lib "user32" _
                    Alias "FindWindowA" _
                   (ByVal lpClassName As String, _
                    ByVal lpWindowName As String) As Long
    Private Declare Function GetWindowLong Lib "user32" _
                    Alias "GetWindowLongA" _
                   (ByVal hWnd As Long, _
                    ByVal nIndex As Long) As Long
    Private Declare Function SetWindowLong Lib "user32" _
                    Alias "SetWindowLongA" _
                    ByVal nIndex As Long, _
                    ByVal dwNewLong As Long) As Long
    Private Declare Function DrawMenuBar Lib "user32" _
                   (ByVal hWnd As Long) As Long
    '**** End of API Calls To Remove The UserForm's Title Bar ****
    '**** Start of API Calls To Allow User To Slide UserForm Around The Screen ****
    Private Declare Function SendMessage Lib "user32" _
                    Alias "SendMessageA" _
                    ByVal wMsg As Long, _
                    ByVal wParam As Long, _
                    lParam As Any) As Long
    Private Declare Function ReleaseCapture Lib "user32" () As Long
    Private Const WM_NCLBUTTONDOWN = &HA1
    Private Const HTCAPTION = 2
    '**** End of API Calls To Allow User To Slide UserForm Around The Screen ****
    Dim hWndForm As Long
       Dim Style As Long, Menu As Long
       hWndForm = FindWindow("ThunderDFrame", Me.Caption)
       Style = GetWindowLong(hWndForm, &HFFF0)
       Style = Style And Not &HC00000
       SetWindowLong hWndForm, &HFFF0, Style
       DrawMenuBar hWndForm
    Private Sub UserForm_MouseDown(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Single, ByVal Y As Single)
      If Button = xlPrimaryButton And Shift = 1 Then
        Call ReleaseCapture
        Call SendMessage(hWndForm, WM_NCLBUTTONDOWN, HTCAPTION, ByVal 0&)
    Note 1
    Important -- make sure to provide an "Exit" button for closing the UserForm down (remember, there will be no Exit Button on the Window frame for the users to use to do this, so you have to provide one for them).
    Note 2
    To slide the UserForm around, hold the Shift Key down, left click a blank area of the UserForm (NOT a control on the UserForm) and with the left mouse button still depressed, slide the mouse around the screen until you have it located where you want. I chose to use the Shift Key as part of this functionality for its mnemonic value (Shift Key = Shift UserForm Around), but this can be changed as needed in the If..Then statement inside the UserForm_MouseDown event procedure.
    May 2012
    Great solution works perfectly
    Oct 2016
    Rick
    I know only enough to be dangerous, so bear with me. To adapt your code above to also run/work on a 64-bit excel, would "PtrSafe" need to be added between the words Declare... Function each time it is mentioned above? Is that all that is needed?
    I do not have the 64-bit version of Excel, so I cannot check, but that does sound right from the reading I have done.
    https://www.youtube.com/watch?v=U76ZRIzBhOA&lc=UgxsozCmRd3RAmIPO5B4AaABAg. 9fxrOrrvTln9g9wr8mv2CS
    https://www.youtube.com/watch?v=U76ZRIzBhOA&lc=UgyT1lo2YMUyZ50bLeR4AaABAg. 9fz3_oaiUeK9g96yGbAX4t
    https://www.youtube.com/watch?v=U76ZRIzBhOA&lc=UgyT1lo2YMUyZ50bLeR4AaABAg. 9fz3_oaiUeK9g7lhoX-ar5
    https://www.youtube.com/watch?v=U76ZRIzBhOA&lc=Ugw6zxOMtNCfmdllKQl4AaABAg. 9g9wJCunNRa9gJGhDZ4RI2
    https://www.youtube.com/watch?v=Sh1kZD7EVj0&lc=Ugz-pow-E8FDG8gFZ4l4AaABAg.9f8Bng22e5d9f8hoJGZY-5
    https://www.youtube.com/watch?v=Sh1kZD7EVj0&lc=Ugxev2gQt7BKZ0WYMfh4AaABAg. 9f6hAjkC0ct9f8jleOui-u
    https://www.youtube.com/watch?v=Sh1kZD7EVj0&lc=Ugxg9iT7MPWGBWruIzR4AaABAg
    Quote Originally Posted by birdieman View Post
    Rick
    I don't have the 64-bit version of Excel, so I cannot check, but as far as I know, yes, that all you need to do.
    Oct 2011
    Excel version 2016 64 Bit, the code has been adapted to operate in both versions
    As Userform1
    #If VBA7 Then
        Private Declare PtrSafe Function FindWindow Lib "user32" _
        Private Declare PtrSafe Function GetWindowLong Lib "user32" _
        Private Declare PtrSafe Function SetWindowLong Lib "user32" _
        Private Declare PtrSafe Function DrawMenuBar Lib "user32" _
        Private Declare PtrSafe Function SendMessage Lib "user32" _
        Private Declare PtrSafe Function ReleaseCapture Lib "user32" () As Long
    #Else
    #End If
        Unload Me
    Private Sub UserForm_MouseDown(ByVal Button As Integer, ByVal Shift As Integer, ByVal x As Single, ByVal y As Single)
        Call ReleaseCapture
    Apr 2020
    I have been delighted with this code and have used in on several userforms with striking results. I do have a question (a challenge!) for you though. Is it possible keep the titlebar, and instead make "active?" I don't even know if that's the right term. Specifically, I need the form I have in mind to show today's date. But the form is very "busy." I wondered if, instead of putting yet another textbox on the form itself, if I could get the date to show in the titlebar in place of or next to the userform title?
    thank you.
    Sorry for the long delay in answering your question. Actually, I am not sure I know how to do what you asked for; however, given you are using a Windows' computer, why isn't the date and time displayed in the Windows Toolbar sufficient?
  1. Remove Special Characters From Text Or Remove Numbers From Text
  2. One userform and 60 Combo Boxes
    By k0st4din in forum Excel Help
    Last Post: 04-25-2013, 09:55 AM
  3. Multiple graph in userform
    By Tony in forum Excel Help
    Last Post: 10-20-2012, 09:32 AM
  4. Replies: 3
    Last Post: 12-07-2011, 09:59 PM
  5. Userform With DataGrid or FlexGrid
    Last Post: 04-09-2011, 09:05 AM
