Excel version 2016 64 Bit, the code has been adapted to operate in both versions
As Userform1
Code:'**** Start of API Calls To Remove The UserForm's Title Bar **** Option Explicit #If VBA7 Then Private Declare PtrSafe Function FindWindow Lib "user32" _ Alias "FindWindowA" _ (ByVal lpClassName As String, _ ByVal lpWindowName As String) As Long Private Declare PtrSafe Function GetWindowLong Lib "user32" _ Alias "GetWindowLongA" _ (ByVal hWnd As Long, _ ByVal nIndex As Long) As Long Private Declare PtrSafe Function SetWindowLong Lib "user32" _ Alias "SetWindowLongA" _ (ByVal hWnd As Long, _ ByVal nIndex As Long, _ ByVal dwNewLong As Long) As Long Private Declare PtrSafe Function DrawMenuBar Lib "user32" _ (ByVal hWnd As Long) As Long '**** End of API Calls To Remove The UserForm's Title Bar **** '**** Start of API Calls To Allow User To Slide UserForm Around The Screen **** Private Declare PtrSafe Function SendMessage Lib "user32" _ Alias "SendMessageA" _ (ByVal hWnd As Long, _ ByVal wMsg As Long, _ ByVal wParam As Long, _ lParam As Any) As Long Private Declare PtrSafe Function ReleaseCapture Lib "user32" () As Long #Else Private Declare Function FindWindow Lib "user32" _ Alias "FindWindowA" _ (ByVal lpClassName As String, _ ByVal lpWindowName As String) As Long Private Declare Function GetWindowLong Lib "user32" _ Alias "GetWindowLongA" _ (ByVal hWnd As Long, _ ByVal nIndex As Long) As Long Private Declare Function SetWindowLong Lib "user32" _ Alias "SetWindowLongA" _ (ByVal hWnd As Long, _ ByVal nIndex As Long, _ ByVal dwNewLong As Long) As Long Private Declare Function DrawMenuBar Lib "user32" _ (ByVal hWnd As Long) As Long '**** End of API Calls To Remove The UserForm's Title Bar **** '**** Start of API Calls To Allow User To Slide UserForm Around The Screen **** Private Declare Function SendMessage Lib "user32" _ Alias "SendMessageA" _ (ByVal hWnd As Long, _ ByVal wMsg As Long, _ ByVal wParam As Long, _ lParam As Any) As Long Private Declare Function ReleaseCapture Lib "user32" () As Long #End If Private Const WM_NCLBUTTONDOWN = &HA1 Private Const HTCAPTION = 2 '**** End of API Calls To Allow User To Slide UserForm Around The Screen **** Dim hWndForm As Long Private Sub CommandButton1_Click() Unload Me End Sub Private Sub UserForm_Initialize() Dim Style As Long, Menu As Long hWndForm = FindWindow("ThunderDFrame", Me.Caption) Style = GetWindowLong(hWndForm, &HFFF0) Style = Style And Not &HC00000 SetWindowLong hWndForm, &HFFF0, Style DrawMenuBar hWndForm End Sub Private Sub UserForm_MouseDown(ByVal Button As Integer, ByVal Shift As Integer, ByVal x As Single, ByVal y As Single) If Button = xlPrimaryButton And Shift = 1 Then Call ReleaseCapture Call SendMessage(hWndForm, WM_NCLBUTTONDOWN, HTCAPTION, ByVal 0&) End If End Sub
